    SImple plugin- care to help?
    20 Posts 6 Posters 1.3k Views 6 Watching
    • Subsonic MikeS
      Subsonic Mike
      I know that works, im trying to cut out that extra click. I could save me a lot of time πŸ˜„
      Thanks anyway
      Design Crash Learn
        If you make a vey little move after the last click of your Line tool when your face is drawn, click it and it continues to works! πŸ’š
          If you don't want lost time just press L with the other hand when you have made your last click of the ! πŸ’š
          • BoxB
            I'm not sure I understand what you are asking for.
            You don't have to click at each junction, just draw one continuous line and it will intersect with the lines it crosses.
            Or am I missing something.
            both horizontals drawn as single lines.
            • Subsonic MikeS
              Subsonic Mike
              Heres a picture to help me describe.
              https://lh3.googleusercontent.com/-MME5ExeFvAQ/UW8sbt4jJTI/AAAAAAAAFyY/mO57uqXenXU/s905/sketchup+help.jpg
              Im often connecting 2 curves, to do this i draw triangles, 3 are shown. My problem is when I get to where the pencil is show, i click and it stops drawing a line. I want be be able to continue drawing a line when a face is made.
              Making more sense? πŸ˜›
              Micahel
              Design Crash Learn
              • BoxB
                Sorry, understand now.
                I think there is a way, but it escapes me right now.
                • sdmitchS
                  sdmitch
                  Do you want the faces or just the lines? Are you stitching the curves together to form a surface?
                  http://sdmitch.blogspot.com/
                  • cottyC
                    cotty
                    Did you activate this checkbox in the preferences?
                    From the help:
                    "Continue line drawing: Use the Continue line drawing checkbox to force the Line tool to treat an end point as the start point of a new line, saving you one extra click required establish a new start point for the second line."
                    my SketchUp gallery
                    • cottyC
                      cotty
                      Ok, my suggestion stops working after a face is created. Workaround:
                      • group the faces
                      • make lines (without faces)
                      • explode faces groups
                      • plugin makefaces to add missing faces
                      my SketchUp gallery
                      • Subsonic MikeS
                        Subsonic Mike
                        SDmitch, I am stitching faces together. I just want a plugin that means when a face is made, when a triangle is made, i dont have to click again to keep drawing the line
                        Cotty, I have that box enable.
                        I will post more when I get back from school, bye for now
                        Micahel
                        Design Crash Learn
                        • BoxB
                          I agree it would be a handy feature to be able to turn on and off, so let me see if I can describe it.
                          The normal action of the pencil tool is for a line to form behind the cursor even after clicks until such time as it forms a closed loop. The closing of the loop forms a face and the line drops from the pencil. So stitching between two lines means, click line one, click line two, click line one, face forms line drops off, click line one again to start next loop, click line two, face forms line drops...............
                          Better would be if able to ignore the natural drop at the form loop stage so that stitching becomes.
                          Click line one, click line two, click line one, face forms, click line two, face forms, click line one, face forms.........
                          Tig's 2D tools does it, but obviously not in 3D. Also tools on surface, but it needs a surface to start with and that kinda defeats the purpose.
                          • cottyC
                            cotty
                            • group the faces
                            A screencast for these steps...
                            my SketchUp gallery
                            • sdmitchS
                              sdmitch
                              Mike, I sent you, via PM, a plugin to try. I think it will do what you want.
                                Is there a reason why you wouldn't just use one of the plugins to automate stitching the curves together. If your time is that valuable, I'm sure you could save more time using Curviloft or one of the other tools to do what you want to do manually.
                                • Subsonic MikeS
                                  Subsonic Mike
                                  The reason I wanted a plugin like this is because the loft tool sometimes fails to stich two faces and so I have to go manual
                                  Design Crash Learn
                                    Is it possible that the times it fails it's because of the way you've got things set up? Maybe a simple change to the way you're drawing would allow the plugin to work and then you're all set.
                                    • Subsonic MikeS
                                      Subsonic Mike
                                      Im not sure, I just have 2 quite different curves and it connects the top to the bottom, it doesn't bother me to much
                                      Design Crash Learn
                                        Perhaps if you posted a sample SKP file in which you have trouble getting Loft to work, the problem could be sorted out so you could avoid having the problem at all.
                                        • Subsonic MikeS
                                          Subsonic Mike
                                          Na, it works well enough and I have what I came for so I don't really want to continue discussing my lofting technique. It works well enough, for now πŸ˜›
                                          Thanks all
                                          Michael
                                          Design Crash Learn
