    SImple plugin- care to help?
    20 Posts 6 Posters 816 Views 6 Watching
    • Subsonic MikeS Offline
      Subsonic Mike
      Hello all!
      Just a simple post this time;
      I just want to know if there is a plugin that means, if you hold ctrl or alt or shift, while using the line tool the line becomes continues and doesn't stop drawing when a face is made.
      Im sure it would be easy to write in ruby, but for the life of me I cant to learn it 😞
      All help is appreciated!
      Thanks,
        Michael
      Design Crash Learn
        Subsonic Mike
        I know that works, im trying to cut out that extra click. I could save me a lot of time πŸ˜„
        Thanks anyway
        Design Crash Learn
          If you make a vey little move after the last click of your Line tool when your face is drawn, click it and it continues to works! πŸ’š
            If you don't want lost time just press L with the other hand when you have made your last click of the ! πŸ’š
            • BoxB Offline
              I'm not sure I understand what you are asking for.
              You don't have to click at each junction, just draw one continuous line and it will intersect with the lines it crosses.
              Or am I missing something.
              both horizontals drawn as single lines.
                Subsonic Mike
                Heres a picture to help me describe.
                https://lh3.googleusercontent.com/-MME5ExeFvAQ/UW8sbt4jJTI/AAAAAAAAFyY/mO57uqXenXU/s905/sketchup+help.jpg
                Im often connecting 2 curves, to do this i draw triangles, 3 are shown. My problem is when I get to where the pencil is show, i click and it stops drawing a line. I want be be able to continue drawing a line when a face is made.
                Making more sense? πŸ˜›
                Micahel
                Design Crash Learn
                • BoxB Offline
                  Sorry, understand now.
                  I think there is a way, but it escapes me right now.
                  • sdmitchS Offline
                    sdmitch
                    Do you want the faces or just the lines? Are you stitching the curves together to form a surface?
                    http://sdmitch.blogspot.com/
                    • cottyC Offline
                      cotty
                      Did you activate this checkbox in the preferences?
                      From the help:
                      "Continue line drawing: Use the Continue line drawing checkbox to force the Line tool to treat an end point as the start point of a new line, saving you one extra click required establish a new start point for the second line."
                      my SketchUp gallery
                      • cottyC Offline
                        cotty
                        Ok, my suggestion stops working after a face is created. Workaround:
                        • group the faces
                        • make lines (without faces)
                        • explode faces groups
                        • plugin makefaces to add missing faces
                        my SketchUp gallery
                          Subsonic Mike
                          SDmitch, I am stitching faces together. I just want a plugin that means when a face is made, when a triangle is made, i dont have to click again to keep drawing the line
                          Cotty, I have that box enable.
                          I will post more when I get back from school, bye for now
                          Micahel
                          Design Crash Learn
                          • BoxB Offline
                            I agree it would be a handy feature to be able to turn on and off, so let me see if I can describe it.
                            The normal action of the pencil tool is for a line to form behind the cursor even after clicks until such time as it forms a closed loop. The closing of the loop forms a face and the line drops from the pencil. So stitching between two lines means, click line one, click line two, click line one, face forms line drops off, click line one again to start next loop, click line two, face forms line drops...............
                            Better would be if able to ignore the natural drop at the form loop stage so that stitching becomes.
                            Click line one, click line two, click line one, face forms, click line two, face forms, click line one, face forms.........
                            Tig's 2D tools does it, but obviously not in 3D. Also tools on surface, but it needs a surface to start with and that kinda defeats the purpose.
                            • cottyC Offline
                              cotty
                              • group the faces
                              A screencast for these steps...
                              my SketchUp gallery
                              • sdmitchS Offline
                                sdmitch
                                Mike, I sent you, via PM, a plugin to try. I think it will do what you want.
                                  Is there a reason why you wouldn't just use one of the plugins to automate stitching the curves together. If your time is that valuable, I'm sure you could save more time using Curviloft or one of the other tools to do what you want to do manually.
                                    Subsonic Mike
                                    The reason I wanted a plugin like this is because the loft tool sometimes fails to stich two faces and so I have to go manual
                                    Design Crash Learn
                                      Is it possible that the times it fails it's because of the way you've got things set up? Maybe a simple change to the way you're drawing would allow the plugin to work and then you're all set.
                                        Subsonic Mike
                                        Im not sure, I just have 2 quite different curves and it connects the top to the bottom, it doesn't bother me to much
                                        Design Crash Learn
                                          Perhaps if you posted a sample SKP file in which you have trouble getting Loft to work, the problem could be sorted out so you could avoid having the problem at all.
                                            Subsonic Mike
                                            Na, it works well enough and I have what I came for so I don't really want to continue discussing my lofting technique. It works well enough, for now πŸ˜›
                                            Thanks all
                                            Michael
                                            Design Crash Learn
