    ⌛ Sale Ending | 30% Off Profile Builder 4 ends 30th September
    Problem Laying Out Views
    layout
    23 Posts 4 Posters 2.0k Views 4 Watching
      Jim57
      In many ways I like Layout but this bug consistently drives me wild.
      I made this drawing in SU, drawing the small countertop in line but displacing it vertically so I could show a section without making pieces invisible for the purpose of the view. In the perspective view on p. 2, I show the two counters. I'd prefer to have them in relationship, as it's easier to understand the concept, but I'm willing to settle.
      Trying to place the small counter in approximate scale and similar attitude is pretty much impossible. I alternate between image edit mode and layout mode, and also between Preserve Scale on Resize and not.
      When I edit the image, I can change the attitude in limited ways by orbiting. One part of the object is pinned and it rotates around that, but I can't change which part. Scrolling, I can change the field of view but not the size. I cannot position the camera so that the object is in the same attitude as the other counter: if I align the y axis, the z axis is out. So I settle for coming close.
      Then I adjust the size. Image edit doesn't adjust the size, so I go to layout mode. Drag the frame to resize, the crop goes out of adjustment. Lock the resize and change the crop and the size goes out. Adjust the attitude again and the view and scale are way skewed. Repeat, repeat, repeat, repeat, getting incrementally better until it's (barely) good enough.
      I don't do these drawings to be good enough, I do them to give fabricators, installers, and clients a strong sense of what I want. This adjustment process takes a long time and gives poor results. It's hard to describe how frustrating it is when the scale, attitude and view jump radically every time you change modes, and it can take twenty minutes or more to get a decent view. And heaven help you if you have to edit the SU file, repositioning anything means you have to start over.
      Jim
      See p. 2, small counter
        Jim,
        I don't think this is a bug. I think it is something you're doing but I'm not entirely certain about what you're trying to accomplish. In your LO file, your viewports show as modified which effectively breaks their relationship with the scenes in SU. You also have Object Snap turned off so it would be difficult to align geometry in separate viewports.
        I expect I am misunderstanding what it is you want to do but does this come close?
          Jim57
          Dave—
          That almost works. I don't believe it is possible to isolate a top view of the small top, though it is possible to crop an end view down to show just the section of the counter.
          Another of my frustrations with Layout is that there is no true Object Snap— it snaps viewports, but not the objects in them. I turned off Object Snap so it would be possible to align the objects in the viewports. Nudging viewports with the arrow keys left the objects misaligned by half a click.
          It sounds like you set up your presentation views in SU scenes. I start that way, but often have to modify. In SU you can't see the page and how the views fit together because there is no reference to the size of the finished page and no absolute scale.
          You are confusing cause and effect regarding modified scenes. They were modified precisely because of the issue I'm complaining about. When adjusting and cropping to fit on a presentation page, sometimes the view or frame needs to be altered, and when shifting it the scale shifts or the view jumps. Several times while making this Layout page, the act of double clicking on the viewport to orient the view jumped the whole image out of the viewport frame, so the object was no longer visible at all. Simultaneously it changes scale radically, from (in this case) 1" : 1' to more like 1:23.54 or some such.
          I am not exaggerating when I say that I had to start over framing the images on page 2 8-10 times because of these shifts. This was a quick drawing because I only had the issue in two viewport. 2/3 of the time I spent on this document was in dealing with this issue.
          Best,
          Jim
            Jim57
            Dave—
            Here's a workflow:
            Go to page 2 of this Layout.
            Double click on the viewport of the small top, as if you have to Orbit the view.
            Image shrinks to about 1/2 size and displaces to the left, so about 1/8 of the top is cut off.
            See the attached file.
            Note that what I've listed above is ALL I have done— I did not orbit or scale the view, just double clicked.
            This is on a fresh install of Layout 3.0.16845 on a new install of 10.7.2 on an iMac 2.93 GHz i7 with 16 MB of Ram, but it's been like this for he last two years at least on this computer, back to 10.6.8
            Best,
            Jim
            Kitchen Counter.layout
              Jim,
              I just looked your latest LO file. It came while I was typing the following. You are inducing your problems because you won't use scenes in SU.
              Is this more like what you're trying to achieve with the small counter top rotated as it was in your LO file.
              This was effortless to create
              @jim57 said:
              Dave—
              Sure. It is possible to isolate a top view of the small top.
              Yes there is. Leave object snap turned on. Set the precision snap point to some point on the viewport you're moving and snap that point to a point on the reference viewport.
              This is the way it Layout and SketchUp are intended to be used together.
              I'm not confusing anything. Changing the size of the viewport in itself doesn't create modified scenes but going into model edit mode will. It is possible to resize the viewport without changing the scale of the geometry inside it.
              Pardon my honesty but I think you are creating the problems for yourself by not utilizing scenes in SketchUp and using them as the viewports in LO. I turned out more than 50 projects in LayOut last year and there's probably a dozen so far this year. Not one of those has a single modified viewport. All of them have a combination of perspective and 2D scaled views.
                sonder
                Jim:
                Dave is spot on with this one. This is not a bug, but how you are using LO. LO's strength is how it ties to the SU model. This is done by preserving scenes. Once you have a "modified" scene, it no longer has the direct tie to all the elements saved in a given scene. As for object snap, LO absolutely snaps to items with the model and not just the viewport. If that were the case, how would the dimension tool work?
                You need to really focus on your SU model and how it is organized and use the scenes to define your LO display. This is probably the number one biggest mistake made by LO users, so don't feel bad, you are not alone. Once you figure out how LO and SU talk to each other you will really see how powerful it is.
                  Have you just tried dragging the corners of the viewport. Don't double click on the viewport first.
                  • sfto1S Offline
                    sfto1
                    Sonder or Dave,
                    I have a scene in Sketchup, which is then inserted in LO. The viewport in LO is intended to be small because I just want a thumbnail. I zoom out to see the scene because the scene is cropped in LO. It displays that the scene is modified. How can I adjust the "size of the scene" without getting the modified tag or cropping?
                    The scale box is grayed out and will not let me adjust there.
                    • sfto1S Offline
                      sfto1
                      I think I figured it out. I have to toggle the "preserve scale on re-size" button on and off as I adjust the size of the viewport.
                      That toggle needs to be off as I re-size, so image/scene/port is constrained with diagonal re-size+shift (the scale will adjust - scene view stays the same) and then I toggle it back on, should I need to manually crop the port.
                        Jim57
                        Okay, try this:
                        Draw something large in two parts and export a simple orthogonal view, say top view.
                        Open in Layout
                        Crop the view to a particular scale, fitting the page while you show part A.
                        Option-Click-Drag
                        Crop the view to show part B
                        Try to align A and B
                        ===>When I do this, I find I can easily align the viewports with Object Snap. However, I cannot align the visible part, the actual object I am representing, with Object Snap. I often have to turn off Object Snap so I can align them freehand— sometimes the nudge keys (arrows) are not accurate enough.
                        If you call the viewports "Objects" in Layout, then yes, you can align them. I can see why a programmer would think in those terms. However, as a user, I am only concerned with aligning the visible parts. Object Snap does not work that way. I wish it did, it would make my drawings easier and neater.
                        Failing that, guidelines. Or the ability to place a "snap mark" on the visible object. Or some other workaround. I've tried drawing lines but they are too coarse. I settle for moving the objects near each other and doing it by eye.
                        Best,
                        Jim
                          Jim57
                          Actually, Dave, I do set up scenes in Sketchup. I use them for my Layout views.
                          You don't seem to get the issues. Did you compare the two Layouts to see the difference made by simply putting a viewport in Edit Mode? The scale jumps from the scale I specified and the view jumps from what was defined.
                          When I check and uncheck the Preserve Scale box, without editing the drawing, the view and scale shift radically. Typically, the scale is reduced by somewhere near 50% and the view moves enough that some or all of the image is cut off by the boundaries of the viewport.
                          In this example, I want to show both tops on one sheet of paper at 1":1' scale. I use two viewports, one with each top, rather than try to define an 8.5' x 11' plot in SU and place the tops inside that to set up a scene which I can move to Layout. There are reasons I draw them in their proper orientation in SU, and also reasons why I don't show them that way in LO. One way is for drafting, the other way is for presenting to a fabricator.
                          Yet when I change the viewport I get a jumping of scale and view. If you don't see this as a bug I don't understand why.
                          Please note: I do not change the SU drawing for this to happen. I am not using another program in between. This is just Layout. It does not change my SU file or the SU scene,, but it changes the LO viewport.
                          It's possible this is a question of semantics, so I'll put in terms of my expectations: I expect to be able to edit a viewport in LO and leave Edit Mode with those changes intact. Likewise, I expect to enter Edit Mode, and not have the act of entering Edit change the view. I can do this fifty times and it acts this way every time. Am I wrong to expect Edit to be predictable? Why is there an Edit Mode if it does not allow you to save your edits?
                          Best,
                          Jim
                            sonder
                            Jim: are you rendering after you edit? If not your scene is "modified". I'm not sure what the issue with object snap is? I often align interior elevations as an example with all floor levels aligned - same for building sections where two sections are cutting through the same area. I align these views based upon snap points of the SU model, not the layout viewport. Again as I stated if object snap did not work, the dimension tool in LO would be useless.
                            I hate to be the bearer of bad news, but I see this as input error, not a software bug.
                            • sfto1S Offline
                              sfto1
                              Jim,
                              I think I understand your issue/complaint. Let me give it a whirl.
                              When you import a SU model into LO you have been clicking (double clicking I believe) on the window/viewport and entering 3D edit mode to set the scale, maybe pan and zoom too. I have been making that mistake until recently. You only need to click on the viewport once in order to make it the active window/viewport. In other words, you apply a scene and scale to the active viewport, not in the active viewport like many are familiar doing in ACAD.
                              From there you make sure that you have the "preserve scale" toggle on. Once sure that "preserve scale" is on, then you can re-size and locate your viewport as needed by adjusting the borders of the port. Do not pan inside the port, do not re-size inside the port, do not zoom inside the port etc.
                              If you need to crop the image, do so using the borders (after clicking once only to make it active), then orient or re-orient it accordingly. Do not do it by sliding the image in the viewport.
                              Again, I have been making the mistake in treating the viewports in LO like they were viewports in ACAD paper space. 😳 LO is different. I have had to train myself to remember LO is not ACAD. If you follow these steps, I believe this frustrating issue will go away for you.
                              I hope this is helpful.
                                quote]Draw something large in two parts and export a simple orthogonal view, say top view.
                                Open in Layout
                                Option-Click-Drag
                                Try to align A and B[/quote]
                                Done. None of the viewports were shown as Modified. And I never had to open any viewport in LO to edit it.
                                Or do you want it in Parallel Projection?
                                If you want to do this in Perspective, it's not going to work but that's not the fault of either LayOut or SketchUp. That's the way perspective works. To be honest, I don't know why you wouldn't just set up the view you want as a single scene in SketchUp and leave it as a single view in LayOut.
                                Jim, I'm with Nick on this one.
                                  Jim57
                                  Folks—
                                  Okay, the discussion is split into two parts. This post is about Object Snap.
                                  Okay, Sonder mentioned Rendering and I found my problem: my drawings were set up for Raster. When I set them up for Vector I can snap visual objects, not just Viewports. Problem Solved!
                                  I'm on the fly, and will check back later to look at the other issue, Jumping Views.
                                  Best,
                                  Jim
                                    sonder
                                    Jim
                                    Object snap works regardless of vector, hybrid or raster.
                                    Again, your issue is related to scenes being "modified".
                                    Best,
                                    Nick
                                      Jim57
                                      With a fresh drawing, I make three objects.
                                      Save Top, Front, Side, Perspective
                                      Export to Layout
                                      Set Scene to Perspective
                                      Check Maintain Scale
                                      Crop Viewport
                                      Uncheck Maintain Scale
                                      ===>Image shrinks
                                      ===>Image remains the same size, does not revert to original size
                                      Option-Click-Drag another Viewport
                                      Set Scene to Top
                                      Maintain Scale checked
                                      Stretch Viewport
                                      ===>Image of object enlarges
                                      From this experiment, it seems that when you:
                                      Change a Viewport's Size
                                      ===>Image Size changes to correspond with the new Viewport size.
                                      Note that the process is not reversible: if you re-check Maintain Scale, the Image does not go back to the original size. Note also that the Scenes are as listed on SU, that is, not modified.
                                      This same sequence happens whether working to a specific scale or leaving the scale undefined
                                      While I'm happy to have found the explanation, I still find this confusing. Is there a benefit to this behavior that I'm not seeing?
                                      I often change scale and size of Viewport to fit items in a readable way onto small pages, while using as few scales as possible. It would be much easier for me if Layout updated its information of the relative size of the Viewport and the image it contains so the image size doesn't shift when Maintain Scale is changed.
                                      Best,
                                      Jim
                                        Jim57
                                        Sonder—
                                        I'm glad that works for you, that's how I feel Layout should work.
                                        My experience is that when I switch from Raster to Vector, all of a sudden I can align them. Switching back to Raster, once the image is rendered I can bring them close but they are no longer automatically aligned, and the Snap function often pulls them away from alignment.
                                        I tried it with a fresh drawing, not modifying the scenes. Same behavior.
                                        Best,
                                        Jim
                                          sonder
                                          Jim:
                                          You are skipping a step. As soon as you crop the viewport, or change the status of scale preservation, you need to re-render the scene unless you have it set to automatically update. (note the triangle with the exclamation point that appears each time you do one of these commands).
                                          There is a reason for LO to work this way. It allows you to size viewports to any size you like, remove scale (for perspectives, since they can't be scaled anyway, and preserve scales for items that you want rendered to a specific scale. For preserved scales, it lets you optimize the size of the viewport for the given drawing.
                                          Preserving scale is solely for the purpose of 2D or 3d Axonometric content. It's use in 3d perspectives would only be to maintain a particular scale of the image on a given page.
                                          LO is functioning fine, you just need to understand how it works.
                                            Jim57
                                            Sonder—
                                            I am sorry, I did not mention that I do indeed have render set to auto.
                                            When I talk about preserving the scale of a perspective, I mean the image size. There is no assigned scale, technically I guess it's the amount of zoom.
                                            I don't know what else I can say. I listed my workflow exactly as I did it, no steps left out. The size of the image jumps, often affecting the amount of image visible. The jumps are unwelcome. What results do you get when you try what I described?
                                            As for your comment that this behavior lets you size drawings on the page, I can only assume that this is not what happens when you do what I listed. I say that precisely because it does NOT allow me to size drawings on the page, it radically alters the size of the drawings from what I specified.
                                            Best,
                                            Jim
