    [Plugin] Canvas v1.1.3
    98 Posts 31 Posters 83.7k Views 31 Watching
    • BoxB
      Win7 64bit
      Most recent SU, updated a few days ago.
      • guanjinG
        guanjin
        I got loaded error message, thank you!
        • renderizaR
          renderiza
          Box::
          I tested the plugin on another computer so I could check if groups worked and they didn't...now I am confused as to why groups work on my computer.
          guanjin::
          For the Plugin to load the "RND_0_Menu.rb" must be placed on the plugins folder as well. If you do have the file already then this is another issue I need to look into.
          [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
          • jolranJ
            jolran
            Hi Rafael.
            As for your last suggestion it is really good idea and I am sure if I don't do it someone else might give it a shot. However if the material opacity is 2% for example painting multiple plane objects on top of each other gives a nice effect (The brush hairs is an example).
            I did not think of that! Thats neat use of it.
            I do think YOU should be the one doing the edits, it's your plugin, man πŸ˜„
            I had a quick peek at the code and have a hunch why there seams to be some troubles with detecting groups.
            The way your doing it now is that you accept anything that's not nil, face or edge ?
            Maybe it would be better to trap for groups or components specifically.
            I mean assign the group or component to a variable. If not that variable prompt user.
            Just an idea to solve the problem. Anyway Keep up the good work! It's a nice concept!
            • renderizaR
              renderiza
              Update RND_Canvas v1.0.1 Beta
              Fixed::
              1.0.1 Beta:: 4/5/2013
              * Fixed some spelling mistakes
              * Changed "Sketchup.send_action(21022)" to "Sketchup.send_action('selectSelectionTool:')"
              * Shortened some if statements
              * Now tool should works with both Groups and Components
              Note::
              While reading this post http://sketchucation.com/forums/viewtopic.php?f=323&t=40482 I found a solution for making groups work with the tool.
              TIG mentioned the following...
              You can only use entities.add_instance() of a definition, BUT there's no built in group.definition method πŸ˜’ , BUT all components, groups and images are all just types of instances of a definition.
              To find a group's definition you have to find its entities' parent which is the definition - so
              defn = group.entities.parent
              ComponentDefinition
              just as the much snappier method defn = instance.definition does for a component-instance !
              The second argument of the entities.add_instance(defn, tr) is the transformation used to place/manipulate the new instance...
              So I added this...
              if @@sel.is_a? Sketchup;;Group
               defn = @@sel.entities.parent ### You can find group definition by adding this
               @@ents.add_instance(defn, t)
              If anyone is kind enough to test if the tool works with groups I will be very thankful! πŸ‘
              • BoxB
                Yep, groups works for me as smooth as a baby's bottom.
                • guanjinG
                  guanjin
                  guanjin::
                  Thanks[/quote]
                  My plugin folder, thank you!
                  • renderizaR
                    renderiza
                    guanjin::
                    Thomthom develped a Debugging utility to check if there's files in the Plugins folder that's ended up in Window's VirtualStore.
                    Please download this here http://sketchucation.com/forums/viewtopic.php?f=180&t=48399
                    Make sure you have admin rights to move the files to 'Plugins' folder.
                    Have you tried running Sketchup as an Admin ?
                    Have you double-checked that you/ALL have FULL security permissions to the Plugins folder and all of its contents including subfolders and their contents ?
                    No 'Compatibility Files...' button/links at all ?
                    Again solving this issue might take couple of tries but hopefully with your help we can solve it. Thanks!
                    • srxS
                      srx
                      πŸ‘ Great! It is like instancing brush from rendering application, like Thea. Thanks.
                      www.saurus.rs
                      • C
                        cuttingedge
                        great plugin. Can we control some parameters?, My components gets stacked at each other sometimes
                          3dsmax9
                          in the RND_Canvas v1.0.1 Beta.rar file this file is missing RND_0_Menu.rb so download the RND_0_Menu.rbz guanjin
                          this is very cool but can you make it add a comp or groupe with just one click every time you click one time an component will be added it will be very usful.
                          • KrisidiousK
                            Krisidious
                            what is the difference between this and spray paint can?
                            By: Kristoff Rand
                            • guanjinG
                              guanjin
                              Or can not be loaded, the same problem! 😞 😞
                              • guanjinG
                                guanjin
                                • guanjinG
                                  guanjin
                                  Issue is resolved, I reinstall sketchup8, and then test the normal use, thank you, it is tough!
                                  • renderizaR
                                    renderiza
                                    srx::
                                    Thank you
                                    cuttingedge::
                                    There is no parameter controls at the moment but its on my to do list.
                                    3dsmax9::
                                    Added RND_0_Menu.rb to Rar File...Thank you for pointing it out. πŸ‘
                                    Thanks for your suggestion I will look into it but in the mean time please check 'Repeat Copy' by Chris Fullmer here... http://sketchucation.com/forums/viewtopic.php?t=26117
                                    Krisidious::
                                    What makes Canvas unique is the constant copies you get without having to do multiple clicks.
                                    guanjin::
                                    I am glad you were able to resolve the issue. πŸ‘
                                    • guanjinG
                                      guanjin
                                      guanjin::
                                      I am glad you were able to resolve the issue. πŸ‘[/quote]
                                      Increase the size of the adjustment distance the better, some randomness, overlapping other components, will produce along the Z axis superimposed.
                                      • sicksickisckS
                                        sicksickisck
                                        hah nice tool! and work very fine for me :]
                                        • renderizaR
                                          renderiza
                                          Update RND_Canvas v1.0.2 Beta
                                          New::
                                          1.0.2 Beta:: 4/8/2013
                                          • Add:: Multiple -- Adds Multiple Groups or Components while holding left mouse button
                                          • Add:: Single -- Adds Single Groups or Components while holding left mouse button
                                          • Don't Add:: If pointer on top of face
                                          • Select:: Normal or Random Input Position
                                          http://sketchucation.com/forums/download/file.php?id=104057
                                          "Add:: On Edge" will be available on v1.0.3
                                          Note:
                                          Added new features that some of you were suggesting and if you have any more suggestions let me know.
                                          Now you can choose to add only one group or component per click use "Add:: Single".
                                          Also for people that want to avoid having groups or components overlaps use the "Don't Add:: If pointer on top of face".
                                          ::A tip:: When using "Don't Add:: If pointer on top of face" I suggest having the Group or Component Axis on center
                                          For adding some randomness while adding groups or components click :Select:: Random Input Position"
                                          That is it I hope you like the new features for "Canvas"! πŸ‘
                                          • guanjinG
                                            guanjin
                                            New::
                                            Note:
                                            The so quickly update the functionality I want,Renderiza: Great, you're God.
                                            πŸ‘ 😍
                                            • 1 / 5
