    Construction & Working Drawings - Discussion
    layout
    453 Posts 114 Posters 489.2k Views 114 Watching
      sonder
      Welcome Barry! Layout definitely has its quirks currently. However, over time I have completely adapted. It is so much faster for me to create a full set of CD's than I could with ACAD. The use of the single 3d model also relieves so much stress about coordination. As for the section and plan linework I use, yes you do need to update that information in the model. That is generally a task that only takes minutes.
      I recently got my structural engineer addicted to the process. So far it is really impressive. I'll post some images of our first project that is getting submitted to the building department this April. It is a good sized home - 5,100 sf and every drawing in the set will be a product of SU and LO.
      • barrymillikenB Offline
        barrymilliken
        I agree Nick: If I didn't have Visio I'd be doing exactly what you are doing. The advantages of Visio in preliminary (2D) site and plan design, where Sketchup is weak, (and Acad is terrible) are too great to ignore. This discussion is about CDs I know, but I'm usually producing design floor plans and 3D models for 3 schemes on any project before starting CDs.
        Once I'm doing CD's the single 3D model for the selected scheme is the basis for coordination: The only disadvantage I face when I change the model: I have to export and import jpegs for each view affected whereas you just do an update from within Layout. It's a tradeoff I think is better in my situation.
        • pbacotP Offline
          Barry,
          Looking for Visio on the web, I found no reference for it's ability to anything like CAD. Interesting. Is it somehow part of Office? I don't have it in mine.
          For me a hangup in Layout is the slowness, because there are so many steps to end product. SU to setup scenes, to Layout to print pdf (huge files) then view in viewer.
          Add to that that I must draw in 2d to start (sorry, have not progressed to drawing only in SU) I'd have several softwares involved. Tough for deadlines. And you must save constantly (slow) because SU and LO will crash on you.
          Nevertheless I am doing some of my elevations in SU-LO! It's just painful when some little thing is off and I must go back to SU model to fix, save (slow), update the LO file (slow), print (slow) again, for a large pdf (slow) file... when in CAD it is add a couple lines and print pdf (nice clean file), done.
          Petr
            sonder
            I don't do any work in 2D anymore except for producing 2d documents. I design everything in 3d from the start. I really enjoy this method more than creating a 2d concept. My first step on any project is to model the site in 3d with all info projected on the 3d mesh - setbacks, easments, property lines, trees physically located etc. I then start modeling the home and immediately reference the home to the site. This way I always have a very clear understanding of the home design's relationship to site topography, features and boundary limitations.
            It also helps me keep in check, height limitations. With the existing site modeled I also project a copy of the ground plane within the setback to the required height for the development - typically 28-35 feet. I save that geometry on a layer that I can toggle on and off while the massing of the home develops.
            I've simply found this flow method works wonderful for me. It took me a while to break from looking at a home in 2 dimensions, but once I did, it was remarkable how quickly I could develop a design.
              barrymilliken
              Pbacot: see http://en.wikipedia.org/wiki/Microsoft_Visio
              The "professional" version includes dozens of architectural smartshapes.
              Before Microsoft bought Viaio from Shapeware, they were making a concerted effort to compete with AutoCad, even buying intellicad as a transitional strategy: see
              http://en.wikipedia.org/wiki/IntelliCAD
              But when they sold to Microsoft that effort was deemphasized.
              Nick Sonder: Re designing from the start in 3D: sometimes I do that if the site terrain is a major factor (as with your ski houses) but most of my work in on flat sites and except for a few exterior steps, terrain does not play a factor in designing the floor plan. I'm a big believer that the focus of CAD should be Design, not Drafting. And the failure of most CAD software is that it's mainly aimed at drafting not design. And I believe that in early preliminary design for most projects (not if you are designing Bilbao Museum) 2D manipulation of accurately dimensioned spaces (as opposed to physical building objects) is important. As I said before: I never ever have to draw anything by hand. And therfore everything I do in Visio flows directly into Sketchup.
              • smarqueS Offline
                smarque
                I am busy with the Site Plan in a set of working drawings. The scene includes a few items from the model itself as well as a series of colored lines for things like set-back lines, roof line outlines, decks, sewage line, paved areas, boundary lines, 2D trees, retaining walls, the actual locality block plan, the house walls, stairs, gazebo outline, contour lines and so on. Each of these lines are a different color and I have set up a separate style with Profile 2 and the edges to color “by material”. A lot of these items have already been modeled but I have had to resort to drawing lines to make the Site Plan readable. I also like the idea of being able to render as a Vector in Layout. I take all of these groups nested in one group and one scene to Layout. I am happy with the result except that I cannot arrange their order. I have sorted the order in SU but I would prefer to do that in Layout where I will be able to see immediate results. What is the best way to go about this. I don’t like the idea of making say 20 scenes with each one holding a single line and then having 20 stacked view ports in Layout. I feel sure that I am missing something somewhere and I would appreciate some feedback.
                  sonder
                  Smarque: For items that will never change such as property lines, setbacks easements and existing contours, simply group each item such as all property lines and set them on a layer you can isolate, Then copy them from SU onto a layer in LO labeled "property line". Just make sure you are on the top view in parallel projection before you copy. Then you simply vector render the line work to scale in LO. For items that will change as a project progresses, always create scenes in SU. Always set Line work that you want to differentiate on different layers in LO. So for a site plan, I have separate layers for contours, setbacks, easements, property lines.
                  • pbacotP Offline
                    Note follow up to the above: I had to get a new computer and what a difference! SU still can crash and it still needs to be able handle nominally larger files but my SU-LO experience is SO much improved. I think the SSD drive is big part of that... and rendering forget it! I don't even feel tempted to network my old computer for rendering--I probably wouldn't notice those two cores.
                    • smarqueS Offline
                      smarque
                      Sonder. Wow! You picked up exactly what I was getting at. I couldn't have wished for a better clear and concise answer. It's opened it up for me. Thank you.
                      pbacot. I'm sure a new computer would be uplifting. It's on my wish list. I do find LO to be resource hungry.
                        sonder
                        Agreed, but I'll bet it is your video card that made the difference. Mine is amazingly fast now.
                          KrisM
                          Question for Sonder,
                          Further back in this thread, you mentioned that you supply coloured drawings to the owner, builder and for the permit set. The other plan sets would presumably be greyscale. I am wondering how your details sheets read when printed in greyscale. The coloured details are very clear but the distinction in the materials may not be so clear without the colour. Perhaps you could post an example.
                          Regards,
                          KrisM
                          • fionmacoolF Offline
                            fionmacool
                            SketchUp 2013 vindicates the argument of those who have championed the idea of creating Construction Documents in SU/ LO.
                            Please forgive the blatant advertising- For anyone who is interested in finding out how to set up SU/ LO for Con Docs please take a look at my book-
                            http://www.viewsion.ie/#!publications/c223s
                            By the way, Nick Sonder's approach is both harmonious with, and adds nicely to the workflow detailed in this workbook. In the forthcoming 2013 edition I will be referring to the technical innovations that Nick has popularised (If that's OK with you Nick? Obviously I would giving all due credit.)
                            I had the absolute pleasure of meeting and working with Nick in Boulder last October:)
                            Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
                            • I Offline
                              ivan_pajares
                              Hi group,
                              folowing up on Nick's workflow I am encountering problems copying and pasting section linework to layout2013. I get an empty sketchup model reference whenever I paste the geometry from sketchup...
                              Actually I can only export it properly with the "send to layout" menu or inserting it in layout as a sketchup reference with a scene properly set up. Am I hitting a bug or just missing something?
                              Thanks, specially to Nick for sharing his workflow!
                                JuanV.Soler
                                Hi ivan_pajares
                                fortunately its going to be solved soon :
                                @marcdurant said:
                                Hi all-
                                The "copy from SketchUp and paste in LayOut" bug was introduced by some of the major refactoring in SketchUp. A fix for this is in QA as we speak and should be available soon.
                                thanks,
                                Marc
                                • I Offline
                                  ivan_pajares
                                  [quote="JuanV.Soler"]Hi ivan_pajares
                                  [quote="marcdurant"]Hi all-
                                  Great! Qué alivio, gracias!
                                    JuanV.Soler
                                    ya está aquí hoy ha salido la nueva adaptacion de la versión
                                    link to download adaptation of the new version
                                    http://www.sketchup.com/
                                    lo anunciaron hoy :
                                    404 Not Found
                                    (sketchucation.com.)
                                    @tyler miller said:
                                    This issue should now be fixed with version 2013.0.4124 that we released today. Please let us know if you see any problems.
                                    Thanks,
                                    Tyler
                                    salud ¡
                                    • bmikeB Offline
                                      bmike
                                      Just an update...
                                      This:
                                      Came from the drawings I posted earlier:
                                        fionmacool
                                        Nice drawings Mike.
                                          Klog
                                          Absolutely Fabulous, Mike
                                          Al Klagge
                                          Teton Timberframe
                                          Klog http://www.tetontimberframe.com
                                          Win 7 Pro Dell Precision M4500 4Gig 4 threads @ 2.9 GB/S
                                          Skp 7 Pro & 8
                                          • pbacotP Offline
                                            Great work Mike! (I thought I posted earlier). Appreciate you sharing the inspiring drawings and process!
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 19 / 23
