    Ruby script for selecting color
    62 Posts 4 Posters 3.3k Views 4 Watching
    • nithi09N Offline
      nithi09
      Thank you
      it's worked when I use (base.back_material = color) in my code.
        Please don't use ' .back_material='.
        You want ' .material='...
        If your initial 'face' is not the "right way round" for the pushpull, DON'T make the result inside-out but colored correctly, rather you should add a test for the 'face' direction.
        A face drawn 'flat' at z=0 will always face downwards, irrespective of the cw/ccw direction of its outer_loop vertices...
        The face.normal is its vector.
        IF that is not facing away from the pushpull direction you might need to reverse the 'face' BEFORE the pushpull... with face.reverse! OR more simply use a -ve value for the pushpull - so it is in the upwards direction !! that is use -hei NOT hei...
        PS: I think your ' face' is called ' base'...
        • nithi09N Offline
          nithi09
          Thanks TIG
          I have a question on the user input for the my testbox1 code I want to add user to choose three given value or they can enter custom value. I tried my self it works for given value to choose but custom value i don't know how to do. could you give me an idea? you know what I mean? combine list = ["6'|8'|10'|Custom"]
            list = ["6'|8'|10'|Custom"] used in an inputbox will work... BUT when your get the results you will need to do another test on that result - let's call that x = results[0]...
            ` if x == "Custom"
            you now need a second input-dialog to get the custom size...
            res = inputbox(["X: "], ["1'"], "Custom Size")
            defsult is 1' [string]...
            return nil unless res
            x = res[0].to_l
            else ### it's a distance [string]
            x = x.to_l
            which when "6'" it returns a value of 72" [which is 6 feet]
            end`
              You are confusing the first 'results' with the second 'results' by using the same name !
              Use a different name for the second one... I've used 'resultsx'
              ... return if not results x = results[0] if x == "Custom" resultsx = inputbox (["Enter Width:"], ["1'"], "Custom Size") return nil if not resultsx x = resultsx[0].to_l ### must turn string into a length else x = x.to_l end wid = x ### we have that value set already dep = results[1].to_l ### must turn string into a length hei = results[2].to_l color = results[3] ### this stays as a string ...
              • nithi09N Offline
                nithi09
                Thanks TIG
                I tried it's give me an error could you look at my code?
                <span class="syntaxdefault"></span><span class="syntaxkeyword">require&nbsp;</span><span class="syntaxstring">'Sketchup.rb'<br /><br /></span><span class="syntaxdefault">def&nbsp;testbox1&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;model&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ent&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#ss&nbsp;=&nbsp;model.selection<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#obj&nbsp;=&nbsp;ss[3]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">prompts&nbsp;</span><span class="syntaxkeyword">=&nbsp;[</span><span class="syntaxstring">"Width"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"Depth"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"Height"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"Colour"</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">defaults&nbsp;</span><span class="syntaxkeyword">=&nbsp;[</span><span class="syntaxdefault">6.feet</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">4.feet</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">2.feet</span><span class="syntaxkeyword">,</span><span class="syntaxstring">'Red'</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;list&nbsp;=&nbsp;[[</span><span class="syntaxstring">"6'|8'|10'|Custom"</span><span class="syntaxkeyword">],</span><span class="syntaxstring">""</span><span class="syntaxkeyword">,</span><span class="syntaxstring">""</span><span class="syntaxkeyword">,[</span><span class="syntaxstring">"Blue|Red|Green"</span><span class="syntaxkeyword">]]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">results&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">inputbox&nbsp;prompts</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">defaults</span><span class="syntaxkeyword">,&nbsp;list,&nbsp;</span><span class="syntaxstring">"Test_Box"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">return&nbsp;if&nbsp;</span><span class="syntaxdefault">not&nbsp;results<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;x&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">results</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if&nbsp;</span><span class="syntaxdefault">x&nbsp;</span><span class="syntaxkeyword">==&nbsp;</span><span class="syntaxstring">"Custom"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">results&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">inputbox&nbsp;</span><span class="syntaxkeyword">([</span><span class="syntaxstring">"Enter&nbsp;Width;"</span><span class="syntaxkeyword">],&nbsp;[</span><span class="syntaxstring">"1'"</span><span class="syntaxkeyword">],&nbsp;</span><span class="syntaxstring">"Custom&nbsp;Size"</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;return&nbsp;</span><span class="syntaxdefault">nil&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">not&nbsp;results<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;x&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">results</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">to_l<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">else<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">x&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_l<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;wid&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">results</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">dep&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">results</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">hei&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">results</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">color&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">results</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">pts&nbsp;</span><span class="syntaxkeyword">=&nbsp;[[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">],&nbsp;[</span><span class="syntaxdefault">wid</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">],&nbsp;[</span><span class="syntaxdefault">wid</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">dep</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">],&nbsp;[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">dep</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">base&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_face&nbsp;pts<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;hei&nbsp;</span><span class="syntaxkeyword">=&nbsp;-</span><span class="syntaxdefault">hei&nbsp;</span><span class="syntaxkeyword">if&nbsp;(</span><span class="syntaxdefault">base</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">normal</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">dot</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Z_AXIS</span><span class="syntaxkeyword">)&nbsp;<&nbsp;</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#color&nbsp;=&nbsp;nil&nbsp;if&nbsp;color&nbsp;==''<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">base</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">back_material&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">color<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#base.reverse!<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">base</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pushpull&nbsp;hei<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;end<br /><br /><br /><br /></span><span class="syntaxkeyword">if&nbsp;(</span><span class="syntaxdefault">not&nbsp;$Testbox_menu_loaded</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;<br />&nbsp;&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Tools"</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"TEST_BOX"</span><span class="syntaxkeyword">)&nbsp;{</span><span class="syntaxdefault">testbox1</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;</span><span class="syntaxdefault">$Testbox_menu_loaded&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">true<br />end</span>
                • nithi09N Offline
                  nithi09
                  Thanks TIG
                  I tried when I use sketchup inputbox popup use defalt nothing happening. when I choose custom it gives mesage "cannot convert Custom to length" could you tell me why?
                  <span class="syntaxdefault"></span><span class="syntaxkeyword">require&nbsp;</span><span class="syntaxstring">'Sketchup.rb'<br /><br /></span><span class="syntaxdefault">def&nbsp;testbox1&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;model&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;ent&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#ss&nbsp;=&nbsp;model.selection<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;#obj&nbsp;=&nbsp;ss[3]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">prompts&nbsp;</span><span class="syntaxkeyword">=&nbsp;[</span><span class="syntaxstring">"Width"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"Depth"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"Height"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"Colour"</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">defaults&nbsp;</span><span class="syntaxkeyword">=&nbsp;[</span><span class="syntaxdefault">6.feet</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">4.feet</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">2.feet</span><span class="syntaxkeyword">,</span><span class="syntaxstring">'Red'</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;list&nbsp;=&nbsp;[[</span><span class="syntaxstring">"6'|8'|10'|Custom"</span><span class="syntaxkeyword">],</span><span class="syntaxstring">""</span><span class="syntaxkeyword">,</span><span class="syntaxstring">""</span><span class="syntaxkeyword">,[</span><span class="syntaxstring">"Blue|Red|Green"</span><span class="syntaxkeyword">]]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">results&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">inputbox&nbsp;prompts</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">defaults</span><span class="syntaxkeyword">,&nbsp;list,&nbsp;</span><span class="syntaxstring">"Test_Box"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">return&nbsp;if&nbsp;</span><span class="syntaxdefault">not&nbsp;results<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;x&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">results</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if&nbsp;</span><span class="syntaxdefault">x&nbsp;</span><span class="syntaxkeyword">==&nbsp;</span><span class="syntaxstring">"Custom"<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">resultsx&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">inputbox&nbsp;</span><span class="syntaxkeyword">([</span><span class="syntaxstring">"Enter&nbsp;Width;"</span><span class="syntaxkeyword">],&nbsp;[</span><span class="syntaxstring">"1'"</span><span class="syntaxkeyword">],&nbsp;</span><span class="syntaxstring">"Custom&nbsp;Size"</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;return&nbsp;</span><span class="syntaxdefault">nil&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">not&nbsp;resultsx<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;x&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">resultsx</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">to_l<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">else<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">x&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_l<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;wid&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">x<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;dep&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">results</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">hei&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">results</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">color&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">results</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">pts&nbsp;</span><span class="syntaxkeyword">=&nbsp;[[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">],&nbsp;[</span><span class="syntaxdefault">wid</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">],&nbsp;[</span><span class="syntaxdefault">wid</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">dep</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">],&nbsp;[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">dep</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]]<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">base&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_face&nbsp;pts<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;hei&nbsp;</span><span class="syntaxkeyword">=&nbsp;-</span><span class="syntaxdefault">hei&nbsp;</span><span class="syntaxkeyword">if&nbsp;(</span><span class="syntaxdefault">base</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">normal</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">dot</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Z_AXIS</span><span class="syntaxkeyword">)&nbsp;<&nbsp;</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#color&nbsp;=&nbsp;nil&nbsp;if&nbsp;color&nbsp;==''<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">base</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">back_material&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">color<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">#base.reverse!<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">base</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pushpull&nbsp;hei<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;end<br /><br /><br /><br /></span><span class="syntaxkeyword">if&nbsp;(</span><span class="syntaxdefault">not&nbsp;$Testbox_menu_loaded</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;<br />&nbsp;&nbsp;</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Tools"</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"TEST_BOX"</span><span class="syntaxkeyword">)&nbsp;{</span><span class="syntaxdefault">testbox1</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;</span><span class="syntaxdefault">$Testbox_menu_loaded&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">true<br />end</span>
                    Because you set the default value of the box to an object of the type Length (6.feet) - this means that the input box will try to convert the return value to be of the same type.
                    But "Custom" cannot be converted into a valid Length object.
                    So instead you'd need to use strings as the default value and handle the conversion back to Length as needed.
                    Btw, it's a lot easier to read your code if you wrap it in [code] tags. (I've done it for you so far.)
                      Well done TT - I didn't spot the mismatch between 6.feet length and "6'" string.
                      If you are making a dropdown list it needs to be text, that you convert to a length later...
                        Not
                        require 'Sketchup.rb' class Testbox def testbox1
                        Try
                        require 'Sketchup.rb' class Testbox def **initialize**()
                        Then use Testbox.new() which will run the initialize...
                        • nithi09N Offline
                          nithi09
                          Thanks you for you help. it's works
                          • nithi09N Offline
                            nithi09
                            Hi I want to add texture for this box I want to see this box look like glass box any Idea?
                            thanks
                              If you have a glass texture already existing use that by 'Name'.
                              If you have added a 'color' material you can get a reference to that after you have made it/added it to a face: mat=base.material and then use mat.alpha=0.5 to add opacity < 1... aka transparency
                              • nithi09N Offline
                                nithi09
                                Hi TIG it's working. but I want to see both way. I mean from outside to inside the box see through fine but inside to outside not see through how do I can do both way? or where do I can find clear glass texture
                                  When you give the first face ['base' ?] its material you need to also apply it to the back face thus:
                                  base.material = 'xxxx' base.**back_material** = 'xxxx'
                                  where 'xxxx' is the material...
                                  • nithi09N Offline
                                    nithi09
                                    Hi TIG how do I can add glass texture to only one wall of box out of four walls.above method applying whole box. I like to try only one wall glass.thanks
                                      Well... you need to work out how to 'find' the face first, then once you have it give it a [preexisting] material - let's assume it's name is 'Glass'...
                                      A face has a 'normal' - which the vector that tells us which way a face is looking...
                                      So let's say the collection of faces [along with edges etc] is in ` - then you need to filter that to find just the faces and then from that exact face with a particular 'normal'...
                                      Let's also assume it is a box so only one matching face.normal will be found...
                                      group.entities.grep(Sketchup;;Face).each{|face|
                                        if face.normal==Z_AXIS ### == faces 'UP'... BUT you can use any vector to compare
                                          face.material='Glass'
                                          face.back_material='Glass'
                                          break ### stop looking
                                      }[/code:ngl1vctf]
                                      • nithi09N Offline
                                        nithi09
                                        Hi TIG how do I find preexisting material on my box? is not 'Glass' thx
                                          Your materials have names.
                                          I used 'Glass' as an example.
                                          The material must already exist in the model.
                                          [I am skipping explaining how to create a material if it doesn't already exist, change its RGB and opacity etc... that wasn't your original question!]
                                          So use any existing material you want - just pass its 'name'... ๐Ÿ˜•
                                          • nithi09N Offline
                                            nithi09
                                            Hi TIG What I am trying to do above creating box one side of box look like see through glass and rest solid coloured any idea???
                                            • 1 / 4
