Ruby script for selecting color
Not
require 'Sketchup.rb' class Testbox def testbox1
Try
require 'Sketchup.rb' class Testbox def **initialize**()
Then useTestbox.new()which will run the initialize... -
Thanks you for you help. it's works
Hi I want to add texture for this box I want to see this box look like glass box any Idea?
thanks -
If you have a glass texture already existing use that by 'Name'.
If you have added a 'color' material you can get a reference to that after you have made it/added it to a face:
mat=base.materialand then usemat.alpha=0.5to add opacity < 1... aka transparency -
Hi TIG it's working. but I want to see both way. I mean from outside to inside the box see through fine but inside to outside not see through how do I can do both way? or where do I can find clear glass texture
Thanks -
When you give the first face ['base' ?] its material you need to also apply it to the back face thus:
base.material = 'xxxx' base.**back_material** = 'xxxx'
where 'xxxx' is the material... -
Hi TIG how do I can add glass texture to only one wall of box out of four walls.above method applying whole box. I like to try only one wall glass.thanks
Well... you need to work out how to 'find' the face first, then once you have it give it a [preexisting] material - let's assume it's name is 'Glass'...
A face has a 'normal' - which the vector that tells us which way a face is looking...
So let's say the collection of faces [along with edges etc] is in ` - then you need to filter that to find just the faces and then from that exact face with a particular 'normal'...
Let's also assume it is a box so only one matching face.normal will be found...group.entities.grep(Sketchup;;Face).each{|face| if face.normal==Z_AXIS ### == faces 'UP'... BUT you can use any vector to compare face.material='Glass' face.back_material='Glass' break ### stop looking end }group.entities.grep(Sketchup;;Face).each{|face|
}[/code:ngl1vctf] -
Hi TIG how do I find preexisting material on my box? is not 'Glass' thx
Your materials have names.
I used 'Glass' as an example.
The material must already exist in the model.
[I am skipping explaining how to create a material if it doesn't already exist, change its RGB and opacity etc... that wasn't your original question!]So use any existing material you want - just pass its 'name'...
Hi TIG What I am trying to do above creating box one side of box look like see through glass and rest solid coloured any idea???
An image of what you expect might help us help you, we are not mind-readers.
I have given you a general framework for code that finds "any face" by its direction and gives it a material.
The example I gave was forface.normal==Z_AXIS
which means it faces directly upwards,
BUT you can compare it to any axis
X_AXIS
Y_AXIS
and for the 'opposite direction'...
X_AXIS.reverse
Y_AXIS.reverse
Z_AXIS.reverseYou need to find and read code examples more....
Hi TIG could you recommend any good book specific for sketchup with code example. I have a book called "Automatic Sketchup" by Matthew Scarpino. It's not enough detail for me.
That's an excellent start.
Also get examples of others scripts [not too complex to start] and see how others do it... -
Hi TIG It's working thanks.
How do I choose specific one face If I have multiple faces in same direction -
Find something unique about that face - like its bounds.min x/y/z ?
The sloping, upward looking face will have a
normal.z>0BUT ALSOnormal.z<1, it also has anormal.x<0- so that finds that kind of face ?
The triangular face hasnormal.x==1, BUT so does the rectangular one next to it.
You can differentiate them usingface.vertices.lengthon each,==3for the triangle and==4for the rectangle ?
Or if the difference is that it is below the red axis, testingface.bounds.min.y<0will find it...Tip on
bb=object.bounds
bb.widthis in X
bb.heightis in Y
bb.depthis in Z
this is NOT as you might initially assume - 'height' is NOT the Z - the bounds conventions come from the older CAD concept, where width/height are from the screen, when you typically looked at an object in plan, from above; and the 'depth' is the extent it projected 'out-of-the-screen'. 3D modelers likeSketchUp show axes in 3d with Z typically up the screen rather that 'out-of-it'... bb.min,bb.maxandbb.centeretc should be self-evident ? -
thanks TIG for fast reply I am going to try. I will let you know!!
@nithi09: Please use [ code ] ... many lines of Ruby code here ... [ /code ] bbCode tags around large blocks of Ruby code.
Hi TIG I didn't understand boundingbox method here is my code look at it. Also I attaching image of this
<span class="syntaxdefault"><br /></span><span class="syntaxkeyword">require </span><span class="syntaxstring">'Sketchup.rb'<br /></span><span class="syntaxkeyword">class </span><span class="syntaxdefault">Testbox<br />def initialize</span><span class="syntaxkeyword">()</span><span class="syntaxcomment">#testbox1 <br /> <br /> </span><span class="syntaxdefault">model </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br /> ent </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities <br /> </span><span class="syntaxcomment">#mats = model.materials<br /> #glass = mats.add "Glass"<br /> <br /> #ent = Sketchup.active_model.entites<br /> </span><span class="syntaxdefault">ent </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities<br /> group </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_group<br /> ent </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">group</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities<br /> <br /> <br /> prompts </span><span class="syntaxkeyword">= [</span><span class="syntaxstring">"Width"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"Depth"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"Height"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"Colour"</span><span class="syntaxkeyword">]<br /> </span><span class="syntaxdefault">defaults </span><span class="syntaxkeyword">= [</span><span class="syntaxstring">"6'"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"4'"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"5'"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">'Red'</span><span class="syntaxkeyword">]<br /> list = [[</span><span class="syntaxstring">"6'|8'|10'|Custom"</span><span class="syntaxkeyword">],[</span><span class="syntaxstring">"2'|4'|1\""</span><span class="syntaxkeyword">],[</span><span class="syntaxstring">"5'|7'|9'"</span><span class="syntaxkeyword">],[</span><span class="syntaxstring">"Blue|Red|Green|White"</span><span class="syntaxkeyword">]]<br /> </span><span class="syntaxdefault">results </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">inputbox prompts</span><span class="syntaxkeyword">, </span><span class="syntaxdefault">defaults</span><span class="syntaxkeyword">, list, </span><span class="syntaxstring">"Test_Box"<br /> </span><span class="syntaxkeyword">return if </span><span class="syntaxdefault">not results<br /> <br /> w </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">results</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br /> if </span><span class="syntaxdefault">w </span><span class="syntaxkeyword">== </span><span class="syntaxstring">"Custom"<br /> </span><span class="syntaxdefault">results_w </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">inputbox </span><span class="syntaxkeyword">([</span><span class="syntaxstring">"Enter Width;"</span><span class="syntaxkeyword">], [</span><span class="syntaxstring">"1'"</span><span class="syntaxkeyword">], </span><span class="syntaxstring">"Custom Size"</span><span class="syntaxkeyword">)<br /> return </span><span class="syntaxdefault">nil </span><span class="syntaxkeyword">if </span><span class="syntaxdefault">not results_w<br /> w </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">results_w</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">to_l<br /> </span><span class="syntaxkeyword">else<br /> </span><span class="syntaxdefault">w </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">w</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_l<br /> end<br /> <br /> wid </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">w<br /> dep </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">results</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">to_l<br /> hei </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">results</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">to_l<br /> color </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">results</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">]<br /> <br /> </span><span class="syntaxdefault">pts </span><span class="syntaxkeyword">= [[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">], [</span><span class="syntaxdefault">wid</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">], [</span><span class="syntaxdefault">wid</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">dep</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">], [</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">dep</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]]<br /> </span><span class="syntaxdefault">back_wall </span><span class="syntaxkeyword">= [[-</span><span class="syntaxdefault">5</span><span class="syntaxkeyword">,-</span><span class="syntaxdefault">36</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">],[-</span><span class="syntaxdefault">5</span><span class="syntaxkeyword">,-</span><span class="syntaxdefault">36</span><span class="syntaxkeyword">,(</span><span class="syntaxdefault">hei</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">36</span><span class="syntaxkeyword">)],[-</span><span class="syntaxdefault">5</span><span class="syntaxkeyword">,(</span><span class="syntaxdefault">dep</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">36</span><span class="syntaxkeyword">),(</span><span class="syntaxdefault">hei</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">36</span><span class="syntaxkeyword">)],[-</span><span class="syntaxdefault">5</span><span class="syntaxkeyword">,(</span><span class="syntaxdefault">dep</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">36</span><span class="syntaxkeyword">),</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]] <br /> </span><span class="syntaxdefault">angle_ptr </span><span class="syntaxkeyword">= [[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">],[ </span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,(</span><span class="syntaxdefault">hei</span><span class="syntaxkeyword">/</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">)],[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,-(</span><span class="syntaxdefault">dep</span><span class="syntaxkeyword">/</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">)]]<br /> </span><span class="syntaxdefault">triangle </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_face angle_ptr<br /> base </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_face pts<br /> backwall </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">ent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_face back_wall<br /> <br /> hei </span><span class="syntaxkeyword">= -</span><span class="syntaxdefault">hei </span><span class="syntaxkeyword">if (</span><span class="syntaxdefault">base</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">normal</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">dot</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Z_AXIS</span><span class="syntaxkeyword">) < </span><span class="syntaxdefault">0</span><span class="syntaxkeyword">)<br /> <br /> </span><span class="syntaxdefault">base</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">back_material </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">color <br /> base</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">color<br /> <br /> mat </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">base</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material<br /> mat</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">alpha </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">0.5<br /> <br /> base</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">reverse</span><span class="syntaxkeyword">!<br /> </span><span class="syntaxdefault">base</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pushpull </span><span class="syntaxkeyword">-</span><span class="syntaxdefault">hei<br /> triangle</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pushpull wid<br /> group</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">grep</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{ |</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">|<br /> if </span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">normal</span><span class="syntaxkeyword">==</span><span class="syntaxdefault">X_AXIS </span><span class="syntaxcomment">##&& face.normal==X_AXIS.reverse### == faces 'UP'... BUT you can use any vector to compare<br /> <br /> </span><span class="syntaxdefault">mats</span><span class="syntaxkeyword">= </span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">materials</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add </span><span class="syntaxstring">"Color_Texture"<br /> </span><span class="syntaxdefault">mats</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">texture </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find_support_file </span><span class="syntaxstring">"panelskin1.jpg"</span><span class="syntaxkeyword">, </span><span class="syntaxstring">"Plugins"<br /> </span><span class="syntaxdefault">mats</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">color </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">color<br /> face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">= </span><span class="syntaxdefault">mats </span><span class="syntaxcomment">#"Magenta"<br /> </span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">back_material</span><span class="syntaxkeyword">= </span><span class="syntaxstring">"Magenta"<br /> <br /> </span><span class="syntaxdefault">mat1 </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material<br /> mat1</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">alpha </span><span class="syntaxkeyword">=</span><span class="syntaxdefault">5<br /> <br /> elsif<br /> face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">normal</span><span class="syntaxkeyword">==</span><span class="syntaxdefault">X_AXIS</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">reverse<br /> </span><span class="syntaxcomment">#face.material= #"Magenta"<br /> </span><span class="syntaxdefault">mats</span><span class="syntaxkeyword">= </span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">materials</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add </span><span class="syntaxstring">"Color_Texture"<br /> </span><span class="syntaxdefault">mats</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">texture </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find_support_file </span><span class="syntaxstring">"brick.jpg"</span><span class="syntaxkeyword">, </span><span class="syntaxstring">"Plugins"<br /> </span><span class="syntaxcomment">#mats.color = color<br /> #face.material= mats<br /> </span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">back_material</span><span class="syntaxkeyword">= </span><span class="syntaxdefault">mats </span><span class="syntaxcomment">#"Magenta"<br /> #mat1 = face.material<br /> #mat1.alpha =0.5<br /> <br /> #break ### stop looking<br /> </span><span class="syntaxdefault">end<br /> <br /> </span><span class="syntaxkeyword">} <br /> <br /> </span><span class="syntaxdefault">end<br />end<br /><br /><br /></span><span class="syntaxkeyword">if (</span><span class="syntaxdefault">not $Testbox_menu_loaded</span><span class="syntaxkeyword">)<br /> <br /> </span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Tools"</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"TEST_BOX"</span><span class="syntaxkeyword">) { </span><span class="syntaxdefault">Testbox</span><span class="syntaxkeyword">.new } <br /> <br /> </span><span class="syntaxdefault">$Testbox_menu_loaded </span><span class="syntaxkeyword">= </span><span class="syntaxdefault">true<br />end</span>
