    Adding Dynamic Component Function to calculate lineal feet
    Scheduled Pinned Locked Moved Dynamic Components
    7 Posts 4 Posters 6.2k Views 4 Watching
    • O Offline
      Omarian
      I am using Sketchup 8 to do bills of quantities, material measurement and calculate pay for tradesmen based on measured work. I got help from TIG (a forum moderator)in creating a Ruby code which added a volume function "volume()" to SU's DC function set. This was very useful in creating dynamic component attributes for entities such as walls, foundations and slabs in estimating the quantity of concrete to order from suppliers. This also helped with determining how varying the thickness of walls or adding an extra room would affect material quantities and overall cost. The FACEAREA dc function was also useful in calculating square footage for tiling, painting etc. However, when I need to calculate running feet, there is great difficulty. For example, if I need to calculate the total running feet of moulding strips along walls, then I could not use the Lenx or Leny functions as these only give the rectangular dimension of the entity box. What I need is the running feet of walls by floor plan. I need a function that would calculate the total lineal feet in the following ways:
      1 Net Lineal Feet one side - Runninng feet at the base of the wall less any openings for doors etc for the inside or outside of a wall.
      2 Net Lineal Feet one side - Runninng feet at the base of the wall less any openings for doors etc for both sides of the wall.
      3 Gross Lineal Feet one side- Running feet at the base from intersection to intersection on the inside .
      4 Gross Lineal Feet one side- Running feet at the base from intersection to intersection on the inside and outside of the wall.
      There may already be a plug-in designed for this. I just cant find it. Please help.
      • yorik1984Y Offline
        yorik1984
        Yesterday I wanted to calculate full lenth of my DC too. But I had a problem. This problem is critical for me. I think this function will be useful for all sketchupers.
        • O Offline
          Omarian
          I really hope someone has a solution otherwise I may have to explore other software options.
            This was posted in another thread and is the basis of adding a DC function to get a perimeter.
            You can use t as a basis to get other data from the DC...
            Let's say you want the perimeter of all faces that have a normal==Z_AXIS.reverse [facing down - i,e, the bottom of a ceiling slab] inside a DC you do something like:
            require('sketchup')
            require('dynamiccomponents.rb')
                if defined?($dc_observers)
                  # Open Dynamic Component Functions (V1) class, only if DC extension is active
                class DCFunctionsV1
                 protected
                 # return the perimeter (in inches) of face.normal==Z_AXIS.reverse
                 if not DCFunctionsV1.method_defined?(;perimeter)
                  def perimeter(a) # Usage as DC function; =perimeter()
                   se = @source_entity
                   if se.is_a?(Sketchup;;Group)
                      allfaces = se.entities.grep(Sketchup;;Face)
                   else #component-instance
                      allfaces = se.definition.entities.grep(Sketchup;;Face)
                   faces=[]
                   allfaces.each{|face| faces << face if face.normal==Z_AXIS.reverse }
                   tr = se.transformation
                   xs = tr.xscale #***
                   ys = tr.yscale #***
                   peri = 0.0
                   faces.each{|face|
                      tlen = 0.0
                      face.outer_loop.edges.each{|e|
                         elen = e.length # this is an unscaled length
                         slen = elen*(1) #*** adjust for any X/Y scaling in (1) if needed ?
                         tlen += slen
                      peri += tlen
                    return peri
                end#class
                end#if
            • O Offline
              Omarian
              TIG,
              You are the best! It worked. Would it be possible to put other delimiters in the brackets, like line colour etc? Then I would tell the function only to calculate length of red lines or ignore lines 6" or smaller?
                Try this kind of thing to skip an 'e' [edge] in certain circumstances, using 'next'
                face.outer_loop.edges.each{|e| **next if e.length < 6.0 next if not e.material.name=='Red'** ... }
                  BrandonIrby
                  Sketchup Nube here. I am not using sketchup for 3D modeling, only slab footprint. Where would I need to input the code that TIG posted to allow for lineal footage addition? Please and thank you.
                  Brandon Irby
