    Solid non-transparent objects have gone transparent
    4 Posts 3 Posters 347 Views 3 Watching
    • U Offline
      unearthed
      Almost everything in my drawing had become transparent (see attachment) with internal edges showing through. Does anyone have a clue why this happens?
      Growplan - People ∩ Plants ∩ Place
      windows 7 64b, 4GB RAM, SU 8.0.16846
      Gimp, QGIS, Vectorworks 12, Bricscad 11
        TECHDAVE02
        check styles window
        • TIGT Online
          Looks like a graphics-card issue?
          Check your drivers are up to date and look at the Preferences > OpenGL settings to see if any changes help...
          Also check if the model, or any part of it [even on off-layers or hidden], is miles from the origin [axes intersection [0,0,0]] and that no components have geometry miles from their origins [insertion points] - common with imported CAD data.
          Also oddly scaled block-objects from CAD imports can have unexpected issues...
          Extremes like this can affect how the model displays...
          • U Offline
            unearthed
            Thanks TIG, I've found nothing way over the horizon as it were (or way above or below), and the jaggy problem only occurs with parallel projection (and only really shows with 3D/iso type views), with perspective views it's all fine. Its probably time for a reinstall.
