    Some advice using Artisan
    Scheduled Pinned Locked Moved Organic Modelling
    12 Posts 5 Posters 11.1k Views 5 Watching
    • massimoM
      massimo Moderator
      Next time is better to do a new post jbomb instead of editing the previous one. So Rich can see that you've added the model (with new posts the icon of the thread will turn to red in the index).
        jbomb
        Thanks for the advice.
        I hadn't actually made any changes to the model just added it to the thread but I will note for next time - thanks πŸ˜„
        • olisheaO
          olishea
          Also use Remove Inner Faces plugin.
          You have inner faces that cause strange behaviour too.
          Look where top of handle meets the cup. Before and after inner faces removed.
          I haven't quad/triangulated the face yet, just showing how inner faces cause problems.
          oli
          • olisheaO
            olishea
            Now to make it more round. More loops make it more rectilinear....how would you go about it Rich? I continued loop all way round which is causing squareness.
            Or maybe start off with an equal sided Ngon, like a hexagon, so it can split into two quads.
            test4_A.skp
            oli
              jbomb
              Thanks Oli, I think that all makes sense. It seems that it is the little details that turn this tool into something really powerful.
              • olisheaO
                olishea
                Its OK, still not right though, it need to be round in plan. I'll upload another model soon...
                oli
                • cottyC
                  cotty
                  You will find some valuable hints in this post about proxy creation...
                  my SketchUp gallery
                    test4.skp
                    • olisheaO
                      olishea
                      I brought my handle from a planar face. In Rich's example you can maintain a better curve by bringing the handle from an edge. This was racking my brain for a while! Because every time I triangulated the face where handle meets cup, it became flat. Anyway here are couple other ways.
                      test4_B.skp
                      oli
                        jbomb
                        Thank you for the models guys - It makes a lot more sense now.
                        Still finding a few issues but I think I just need to try things and learn from my mistakes.
