    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 404.0k Views 172 Watching
    • OxerO Offline
      Oxer
      Hi mvdv,
      I'm Mac's user, and Sketchup Ivy works on Mac but only with 0.6.0 version, see below. I have introduced the keys for Mac in the Use tab of the plugin window. If you want to see how use the plugin in Mac go to this link http://www.youtube.com/watch?v=RGV8jU9HK_Y
      Sketchup Ivy 0.6 for Mac
      • romboutR Offline
        rombout
        Wow thanks for the settings, great work!
        • Z Offline
          zelimbo
          hey all i'm new to the forum but not in sketchup world....i'm having problems trying to install the ivy pluggin.....this is what happens when i open sketchup :
          Error Loading File LiveIvy.rb
          no such file to load -- LiveIvy/LiveVector_coreError Loading File LiveIvy_node.rb
          uninitialized constant LiveIvy::Node::PdnError Loading File LiveIvy_tool.rb
          uninitialized constant Pdn
          please if anyone can help me resolve this issue...since before i havent had this problem with anyother pluggin
          cheers!
          • KrisidiousK Offline
            Krisidious
            Do you have the liveivy .rb file in the plugins folder and your liveivy folder inside of the plugins folder as well?
            You should delete all the liveivy and make sure you downloaded the 0.6.3 version.
            By: Kristoff Rand
            • Z Offline
              zelimbo
              emmm i have a folder which i named ivy with all the files it comes with....apart from that i copied the liveivy.rb file alone in the pluggins folder......should i eliminate one of them?? im kinda lost and really want this app
              thanx!!
                Krisidious
                you should have a "LiveIvy.rb" in your plugins folder and a "LiveIvy" folder in your plugins folder.
                names must remain the same.
                By: Kristoff Rand
                • Z Offline
                  zelimbo
                  thanks kristoff for taking your time with me did what you told me to and ended up wiht this:
                  can't convert nil into String
                    Krisidious
                    You get that when you load sketchup or when you load the plugin and try to use it?
                    By: Kristoff Rand
                    • Z Offline
                      zelimbo
                      i get that when i load sketchup
                        Krisidious
                        Here... Try mine.
                        (www.aboveallhouseplans.com)
                        it's like 37 megs. has more ivy in it.
                        if this doesn't work there is a conflict with another plugin.
                        By: Kristoff Rand
                        • Z Offline
                          zelimbo
                          thanx man!
                            Krisidious
                            Did that fix it?
                            By: Kristoff Rand
                            • F Offline
                              fwolf21
                              Great work.
                              I have worked with the original ivy generator back in 2008-2009.
                              Don't have any thing to say right now since just start using it.
                              Ill keep you posted if anything comes up.
                              Keep you the great work
                                PHRodrigues
                                awesome! thx man.
                                  technoshaman
                                  Thank you for this wonderful plug in. I was about to start modeling ivy by hand!!!! But this saved me so much time. THANK YOU
                                  • lele_poggiL Offline
                                    lele_poggi
                                    The plug-in doesn't work with the new version of Vray for Sketchup 1.6.
                                    Can be fixed this bug?
                                    Thank you
                                    gsa | Gabriele Sacchi architetto
                                    http://www.gs-a.it
                                      Thank you
                                      The bug is in the Vray beta - it breaks several legit tools by having some flaky observer calls... I know Vray have a solution and I'd expect an update to their beta soonest...
                                      Meanwhile can I suggest that you disable Vray from loading while modeling - you don't need a renderer to model ??
                                        lele_poggi
                                        Thanks TIG.
                                        I've already disable Vray and it works fine.
                                        I didn't know it was a Vray bug.
                                        So I'm in waiting for their next beta release to check this.
                                        http://www.gs-a.it
                                          I'd recommend that you report this to the developers of V-Ray. It's known to have caused problems with other plugins as well.
                                            AcesHigh
                                            @pierreden said:
                                            TO COME
                                            • Leaves as Components
                                            • More Parameters and grow patterns.
                                            • Other Plugins. Fur, Cloth and Tree.
                                            I wonder what happened to Pierreden 😞
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 36
                                            • 37
                                            • 24 / 37
