    [Plugin] Solid Inspector
    303 Posts 99 Posters 342.4k Views 98 Watching
      drawkcab
      Many thanks for this. New user breaking in and this worked beautifully. 2" whisker on vertex of 75 ft. tower found instantly - love it.
        metageek
        @thomthom said:
        Did you install TT_Lib2? Linked under Requirements.
        Yup, did that.
          thegoodguy
          Brilliant! Thank you so much for this excellent plugin πŸ˜„
          • O Offline
            Obryan
            Hi ,
            I have a mac osx 10.6.8 running Snow Leopard. I have Dropped the downloaded Solid Inspector ruby scripts into HD/Library/Application Support/Google Sketchup 8/Plugins
            When I restart sketchup 8 I get This message:
            Error Loading File tt_solid_inspector.rb
            no such file to load -- TT_Lib2/core.rb
            Can somebody tell me how to install Solid Inspector into my Mac?
            Thank you,
            Sean
              Go back to the first post and follow the link to the required TT_Lib2 - under the "Requirement" header, right above the Download button.
                Ralphxyz
                What is Solid Inspector telling me?
                Sorry I am new to SketchUp but really having problems with making Solids.
                http://gettheworkdone.net/images/sketchup/SolidTools1.png
                What do I do to fix the problems?
                What specifically do the colors represent?
                Thanks,
                Ralph
                  The red colour is just indicating the current issue - you can cycle through the different issues using tab. The camera should zoom to the problem area.
                  The highlighed areas either means there is a hole or internal faces. You need to correct these before the object can be considered a solid.
                  • olisheaO Offline
                    olishea
                    Excellent plugin thomthom. Thank you and all the best.
                    oli
                    • jgbJ Offline
                      jgb
                      You can zoom INTO the object and see the problems defined in red or orange. It really does not matter which you tackle first. Put your cursor on one item and deselect the group/comp. Then select again and edit. The cursor is on the problem. 99% all you have to do is delete it.
                      You can also change to XRAY view (Wireframe will not show problem faces) In XRAY you can move the cursor right onto the problem from outside the object, then edit it.
                      Sometimes you may have a circle that seems to be well outside the object. SI found a line fragment within the groups bounding box but totally outside the object. Pan and zoom such that the circle is seen against BLANK background, ie open sky or ground. Place the cursor in the circle, then deselect and edit again. Make a sweeping right to left selection to catch the offender and delete.
                      Note: You cannot edit the object while SI is active. You cannot activate SI while in edit mode.
                      There is also a companion pluggin, Solid Solver that "fixes" these kinds of errors, BUT, it can also destroy (undoable, almost always) an object that has a lot of problems.
                      I once had an object that started with about 600 lines and ended up with about 30 when Solver finally got done, so it is a good idea to SAVE before trying to Solve a complex mess.
                      I also have had objects that were deemed by Solver as "Can NEVER be made solid" fixed with just a few missing lines added.
                      jgb
                        joepotato
                        This plugin saved me from countless hours of trial and error in correcting issues with my model. Thank you!!!
                          rbedoya
                          Hi Thom,
                          I installed the Solid Inspector into my mac, in the plugins, but when i launch SU i get the following
                          Error Loading File tt_solid_inspector-1.rb
                          what might be the problem?
                            Please, re-read (or at least read once) the installation instructions and download/install that library this plugin is dependent on.
                              rbedoya
                              I have installed the library required and i get that error.
                                rbedoya
                                Here is the library i have installed and the plugin
                                TT_Lib2%20-%202.7.1.rbz
                                  Placing the RBZ file in the plugins folder doesn't work. It's a package that must be installed. Note there's a big difference between RB and RBZ files.
                                  Follow the installation instructions linked in the red box near the Download button.
                                    driven
                                    @rbedoya said:
                                    Error Loading File**tt_solid_inspector-1**.rb
                                    is that a copy, or are there two versions?
                                    on my mac it's **tt_solid_inspector.rb**,
                                    if so does your TT_Lib2 also a copy i.e. TT_Lib2-1
                                    if it is, SU won't find it...
                                      Jim
                                      Rather than implement this as a Tool, I wonder if it makes sense to apply a material to the offending edges and set the style to color by material. That way, I could exit the tool and explore the model at my leisure.
                                        Could be added as an option. I'd still want to have an non-modifying inspection method.
                                        I had originally planned to try to implement methods to fix various errors - but .. you know Time and all that. πŸ˜•
                                        • xiombargX Offline
                                          xiombarg
                                          Here's are two really handy tips for using this plugin, especially on complex models:
                                          1. Set the solid inspector as a shortcut key so you don't have to keep using the drop down menu. You can waste half your life away using drop down menus to access frequently used tools.
                                          and combined with this...
                                          1. Use Jim's "Custom Toolbar" plugin and then go to the VIEW drop down menu, then go to TOOLBARS and choose "Options". Having these buttons (or setting shortcut keys) for "Show Hidden Geometry" and for "Hide Rest of Model" is indispensable for fixing complex models into solids. It will save you A LOT of time.
                                            scott216
                                            I'm having trouble using this plug-in. I can't get it to turn off most of the time. I'll go go the tools drop down menu and click on solid inspector to hoping to uncheck it, but it doesn't uncheck. How do I turn this off. I'm using sketchup 8.0.16845 on Mac 10.7.5
                                            • 15
                                            • 16
                                            • 8 / 16
