    [Plugin] Solid Inspector
    303 Posts 99 Posters 368.4k Views 98 Watching
      a162042
      Outstanding tool . It took a little bit to figure out how to install on my MAC. What i found to be the problem was i did not have TT_Lib2 - 2.6.0.zip downloaded in my plugin folder once i loaded it i then loaded the solid inspector and it works great.
        apassemard
        Hello All
        I downloaded the Solid Inspector plugin on my Mac and it wasn't loading.. After some looking around I realized that I had put the plugin here:
        /Applications/Google SketchUp 8/SketchUp.app/Contents/Plugins
        Where it should have been put here:
        /Library/Application Support/Google SketchUp 8/SketchUp/plugins/
        Now it's working fine.
        Hopefully that help some of the Mac users out there who are having issues..
        Antony
          JBERGMAN
          This tool works great if you are trying to fix it yourself... I found this other plugin in the ruby library depot that not only identifies the problems, but corrects them too!
          http://rhin.crai.archi.fr/rld/plugin_details.php?id=793
          worked for me first try...
            Jim
            A more recent 'Fix Solid' is available right here on this forum:
            http://sketchucation.com/forums/viewtopic.php?t=48557
            EDIT: by TIG
            And there is the updated similar tool 'SolidSolver' http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
              metageek
              @myguel said:
              I confirm the problem comes from the wine install somehow. I install the plugin on a mac the same way as with the linux and it works perfectly.
              I will ask for some help in the wine community.
              Did you get anywhere? I'm getting similar trouble running it in SU8 under Crossover (the commercialized Wine). On startup, I get a dialog titled "Load Errors", saying:
              Error Loading File tt_solid_inspector.rb
              uninitialized constant TT::System
              When I press OK, the entire SU viewport goes black. I did try the (possibly outdated) advice to run dos2unix on the *.rb files of the plugin, but that doesn't help--in fact, it causes SU to report a BugSplat after I press OK on the Load Errors dialog.
                Did you install TT_Lib2? Linked under Requirements.
                  drawkcab
                  Many thanks for this. New user breaking in and this worked beautifully. 2" whisker on vertex of 75 ft. tower found instantly - love it.
                    metageek
                    Yup, did that.
                    • T
                      thegoodguy
                      Brilliant! Thank you so much for this excellent plugin πŸ˜„
                      • O
                        Obryan
                        Hi ,
                        I have a mac osx 10.6.8 running Snow Leopard. I have Dropped the downloaded Solid Inspector ruby scripts into HD/Library/Application Support/Google Sketchup 8/Plugins
                        When I restart sketchup 8 I get This message:
                        no such file to load -- TT_Lib2/core.rb
                        Can somebody tell me how to install Solid Inspector into my Mac?
                        Thank you,
                        Sean
                          Go back to the first post and follow the link to the required TT_Lib2 - under the "Requirement" header, right above the Download button.
                            Ralphxyz
                            What is Solid Inspector telling me?
                            Sorry I am new to SketchUp but really having problems with making Solids.
                            http://gettheworkdone.net/images/sketchup/SolidTools1.png
                            What do I do to fix the problems?
                            What specifically do the colors represent?
                            Thanks,
                            Ralph
                              The red colour is just indicating the current issue - you can cycle through the different issues using tab. The camera should zoom to the problem area.
                              The highlighed areas either means there is a hole or internal faces. You need to correct these before the object can be considered a solid.
                              • olisheaO
                                olishea
                                Excellent plugin thomthom. Thank you and all the best.
                                oli
                                • jgbJ
                                  jgb
                                  You can zoom INTO the object and see the problems defined in red or orange. It really does not matter which you tackle first. Put your cursor on one item and deselect the group/comp. Then select again and edit. The cursor is on the problem. 99% all you have to do is delete it.
                                  You can also change to XRAY view (Wireframe will not show problem faces) In XRAY you can move the cursor right onto the problem from outside the object, then edit it.
                                  Sometimes you may have a circle that seems to be well outside the object. SI found a line fragment within the groups bounding box but totally outside the object. Pan and zoom such that the circle is seen against BLANK background, ie open sky or ground. Place the cursor in the circle, then deselect and edit again. Make a sweeping right to left selection to catch the offender and delete.
                                  Note: You cannot edit the object while SI is active. You cannot activate SI while in edit mode.
                                  There is also a companion pluggin, Solid Solver that "fixes" these kinds of errors, BUT, it can also destroy (undoable, almost always) an object that has a lot of problems.
                                  I once had an object that started with about 600 lines and ended up with about 30 when Solver finally got done, so it is a good idea to SAVE before trying to Solve a complex mess.
                                  I also have had objects that were deemed by Solver as "Can NEVER be made solid" fixed with just a few missing lines added.
                                  jgb
                                    joepotato
                                    This plugin saved me from countless hours of trial and error in correcting issues with my model. Thank you!!!
                                      rbedoya
                                      Hi Thom,
                                      I installed the Solid Inspector into my mac, in the plugins, but when i launch SU i get the following
                                      Error Loading File tt_solid_inspector-1.rb
                                      what might be the problem?
                                      • GaieusG
                                        Please, re-read (or at least read once) the installation instructions and download/install that library this plugin is dependent on.
                                          rbedoya
                                          I have installed the library required and i get that error.
                                            rbedoya
                                            Here is the library i have installed and the plugin
                                            TT_Lib2%20-%202.7.1.rbz
                                            • 15
                                            • 16
                                            • 8 / 16
