    [Plugin]Fly Through v1.4.0-Feb 27,2014.
    18 Posts 11 Posters 22.7k Views 11 Watching
      tak2hata
      Hi,All.
      I create a fly through plugin.
      Let's fly as a bird in sketchup.
      General disclaimer
      I MAKES NO GUARANTEE OF VALIDITY about this script.
      Please use this script at your own risk.
      DONWLOAD:
      Get the latest version from the PluginStore:
      http://sketchucation.com/resources/pluginstore?pln=flythrough
      or AutoInstall from within SketchUp using the SketchUcation Tools
      version1.0
      UPDATE:Mar21,2013.
      BUGFIX:Default value of "SPEED" was too small.
      BUGFIX:Could not hit [TAB] on Mac.so it replaced by[OPTION]key.
      IMPROVE:"Look around" and "Move" works simultaneously.
      Version1.2
      UPDATE:Mar23,2013.
      IMPROVE:Changing "SPEED" is placed in Context Menu.
      IMPROVE:"Look around" and "Move" works more simultaneously.
      Version1.21
      UPDATE:Mar24,2013.
      Add code "require 'sketchup.rb'"
      Version1.4.0
      UPDATE:Feb27,2014.
      small improve.Toggle Look around mode by one clicking.
      1. [Arrow] keys to Move.
      2. Drag mouse L button to Look Around.
      3. [Home] Key to UP(Windows)
      4. [End] key to DOWN(Windows)
      5. "[" key to UP(MAC)
      6. "]" key to DOWN(MAC)
      7. Press "SHIFT" key to Move fast.
      8. Context Menu to change SPEED value.
      Latest Version:
      by TAK2HATA
        mwm5053
        WOW thats's cool thanks
        2011 iMac
        SU 2015 Pro, 2017 Make
        V2 Twilight
        macOS Sierra 10.12.5
          dtrarch
          Tak2
          Thanks and fun too. 👍 😄
          dtr
            mwm5053
            Not Mac ready keys won't work.
            2011 iMac
            V2 Twilight
              baldaman
              Domo aligatou gozaimasu tak2hata ruby sensei!
                small08
                Will try, thank-you!
                  tak2hata
                  Hi,All.
                  I update this to ver1.1 on Mar 21,2013.
                  Enjoy Flying.
                  by TAK2HATA
                  • OxerO Offline
                    Oxer
                    On Mac there is an error, you have to change the "." sign for the "," in flylenght, so it'll works fine.
                    In ruby file lines 71 to 75:
                    "def initialize
                    @flylength = 0,2.m
                    a = Sketchup.read_default("TAK2_FLYTHROUGH","FLYLENGTH","0,2m")
                    @flylength = a.to_l if a
                    #@flylength = 0,2.m
                    @lbtndn = false
                    @cxy = [ 0,0 ]
                    reset"
                    Another problem on Mac is that you obtain "[" "]" pushing "Option (Alt) +`" and "Option (Alt) ++" if you have assigned on Mac the Option (Alt) key to change the Speed, I can't use Up and Down.
                    • BoxB Offline
                      Oxer I don't think that's a mac error as such.
                      The "." "," issue is generally due to the global settings of your computer, whether it be PC or Mac. I imagine as you are from Spain you have your Mac using the common European system which uses the "," for example 2,5Deg Celsius, whereas a standard English based set up would write it as 2.5Deg Celsius.
                      Anyway, it's an unfortunate annoyance for all those who have the system set the "wrong way".
                      Feel free to give me a slap if this has nothing to do with your problem.
                      • OxerO Offline
                        Oxer
                        Thanks for your answer, it's possible that the problem were in the metric units.
                        Is there a solution for the "[" "]" signs on Mac?
                          tak2hata
                          Hi,Oxer and Box.
                          Your advices are useful infomation.
                          I will correct it later.
                          Thanks.
                          by TAK2HATA
                            tak2hata
                            Hi,All.
                            I update this to Ver 1.2 in Mar 23,2013.
                            Changing SPEED is placed in context menu.
                            Thanks.
                            by TAK2HATA
                              Kiey
                              This plug-in is useful while in draw/edit objects,
                              could it possble effect when I draw something or move something.
                              just like autocad's Transparent command ?
                                tak2hata
                                Hi,All.
                                I update this to v1.4.0.
                                small improve.
                                Thanks.
                                by TAK2HATA
                                • rogerionemesisR Offline
                                  rogerionemesis
                                  @tak2hata said:
                                  Hi,All.
                                  small improve.
                                  Thanks.
                                  Thank you. The mouse single click makes it reallllly better.
                                    tspco
                                    I tried this today, it worked well, but I have a suggestion, any way to ass a maintain camera height, say from the native su camera eye height? I do terrains a lot and it would be real cool to not look at the underside when moving across it. Floating Camera has this function, but the rest of the plugin has issues.
                                    Thanks Ryan
                                    SU make 2017, /Twilight Render Hobby
                                    Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                                      tak2hata
                                      Thanks Ryan
                                      Hi,Ryan.
                                      I guess from your suggestion.
                                      Is it walk tool of sketchup?
                                      Or,Flying and collision with land and no gravity?
                                      by TAK2HATA
                                      • JClementsJ Offline
                                        JClements
                                        I downloaded and installed today.
                                        Running SU2014, Windows 7.
                                        END key did not move down (or any direction). SHIFT key did not appear to move faster.
