    [Plugin]Fly Through v1.4.0-Feb 27,2014.
    18 Posts 11 Posters 24.4k Views 11 Watching
      small08
      Will try, thank-you!
        tak2hata
        Hi,All.
        I update this to ver1.1 on Mar 21,2013.
        Enjoy Flying.
        by TAK2HATA
        • OxerO Offline
          Oxer
          On Mac there is an error, you have to change the "." sign for the "," in flylenght, so it'll works fine.
          In ruby file lines 71 to 75:
          "def initialize
          @flylength = 0,2.m
          a = Sketchup.read_default("TAK2_FLYTHROUGH","FLYLENGTH","0,2m")
          @flylength = a.to_l if a
          #@flylength = 0,2.m
          @lbtndn = false
          @cxy = [ 0,0 ]
          reset"
          Another problem on Mac is that you obtain "[" "]" pushing "Option (Alt) +`" and "Option (Alt) ++" if you have assigned on Mac the Option (Alt) key to change the Speed, I can't use Up and Down.
          • BoxB Offline
            Oxer I don't think that's a mac error as such.
            The "." "," issue is generally due to the global settings of your computer, whether it be PC or Mac. I imagine as you are from Spain you have your Mac using the common European system which uses the "," for example 2,5Deg Celsius, whereas a standard English based set up would write it as 2.5Deg Celsius.
            Anyway, it's an unfortunate annoyance for all those who have the system set the "wrong way".
            Feel free to give me a slap if this has nothing to do with your problem.
            • OxerO Offline
              Oxer
              Thanks for your answer, it's possible that the problem were in the metric units.
              Is there a solution for the "[" "]" signs on Mac?
                tak2hata
                Hi,Oxer and Box.
                Your advices are useful infomation.
                I will correct it later.
                Thanks.
                by TAK2HATA
                  tak2hata
                  Hi,All.
                  I update this to Ver 1.2 in Mar 23,2013.
                  Changing SPEED is placed in context menu.
                  Thanks.
                  by TAK2HATA
                    Kiey
                    This plug-in is useful while in draw/edit objects,
                    could it possble effect when I draw something or move something.
                    just like autocad's Transparent command ?
                      tak2hata
                      Hi,All.
                      I update this to v1.4.0.
                      small improve.
                      Thanks.
                      by TAK2HATA
                      • rogerionemesisR Offline
                        rogerionemesis
                        @tak2hata said:
                        Hi,All.
                        small improve.
                        Thanks.
                        Thank you. The mouse single click makes it reallllly better.
                          tspco
                          I tried this today, it worked well, but I have a suggestion, any way to ass a maintain camera height, say from the native su camera eye height? I do terrains a lot and it would be real cool to not look at the underside when moving across it. Floating Camera has this function, but the rest of the plugin has issues.
                          Thanks Ryan
                          SU make 2017, /Twilight Render Hobby
                          Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                            tak2hata
                            Thanks Ryan
                            Hi,Ryan.
                            I guess from your suggestion.
                            Is it walk tool of sketchup?
                            Or,Flying and collision with land and no gravity?
                            by TAK2HATA
                            • JClementsJ Offline
                              JClements
                              I downloaded and installed today.
                              Running SU2014, Windows 7.
                              END key did not move down (or any direction). SHIFT key did not appear to move faster.
