    [Plugin]Draw Slope Normals.rb-v1.4-Mar 28,2013.
    36 Posts 21 Posters 55.3k Views 21 Watching
      mizar
      it's wonderful
      Thanks a lot
        Lillioso
        I get this error when i startup Sketchup, and the Plugin wont load.
        What am I doing wrong?
          tak2hata
          Hi,Lillioso.
          I mistook about that "file_loaded".
          It needs "require 'sketchup.rb' for first time.
          I add the code,now in ver 1.31.
          Thanks.
          by TAK2HATA
            rv1974
            There's some problem on 1.15- The arcs will be distorted (from plan point iof view).
              tak2hata
              Hi,rv1974.
              Watch this.Arc is not distorted in TOP View.
              Please upload the picture or model that included "distorted arc."
              by TAK2HATA
              • pbacotP Offline
                That's SPECIAL Tak2hata!
                  rv1974
                  Tak2hata-san, I tested it in deep and this tool indeed keeps the plan outline. This is
                  AMAZING! ๐Ÿ˜ฎ
                  About your last video: I played with the similar shape and the result was a bit distant from 100% perfect (the left example); then I reshaped the curves with Fredo's skinning
                  (the right example) and it was closer to the desired. Could you take a closer look at this issue?
                  REALLYThank you!
                  Offtop: yesterday I watched 'Jiro Dreams of Sushi' documentary. There are epic people in Japan!
                  left: draw slope
right: lofting (smoother result)
                  Untitled.skp
                    tak2hata
                    AMAZING! ๐Ÿ˜ฎ
                    REALLYThank you!
                    Hi,rv1974.
                    Folding is works with Sketchup default function.
                    Freado' Skinning is smoother function.
                    I will connect to the skinning when fredo lib is loaded.
                    Offtop:Jiro's Sushi is expensive!I want to eat that!There is Great Sprits for Sushi!
                    by TAK2HATA
                    • O Offline
                      orchard collie
                      Hi TAK2HATA
                      I'm using SketchUp 2013 Pro on Mac OSX 10.8.4 - downloaded the plugin and unzipped it into the Plugins Folder.
                      Opened SketchUp went to Preferences - Extensions - Install extension - located the folder', opened it but could not select the draw slope normals.rb file to install it.
                      Any ideas what my problem is, apart from stupidity?
                      Cheers
                        tak2hata
                        @orchard collie said:
                        Hi TAK2HATA
                        Cheers
                        Hi,orchard.
                        Installing plugin was completed when you unzipped it into the Plugins Folder.
                        In case of installing from "*.rbz" file,
                        "Install Extension" in Preference menu works.
                        Thanks.
                        by TAK2HATA
                          rv1974
                          Tak2hata, could you please implement somehow the 'offset' (or let's call it 'local') coordinate input? Say typing evenly + 50 would move the vertex 50cm upward from the currentposition.
                          In many situations it's more natural to work with local coordinates.
                          Thanks in advance
                          P.S. This tool in conjunction with Fredo's Skinning make killing combo in landscape\road design! ๐Ÿ‘
                          • O Offline
                            orchard collie
                            Thanks Tak2Hata
                            Assuming it's loaded, I can't seem to locate the plugin in any of the Menus or by context clicking a mesh.
                            Any suggestions as to how to activate it on Mac?
                            Orchard Collie
                              tak2hata
                              Hi,orchard.
                              Download plugin zip file and unzip.
                              rb file and the folder include some file will be created.
                              unzipped with folders
                              Please place all files to plugins folder.
                              The command will be shown in [MENUBAR]->[PLUGINS]->{DRAW SLOPE NORMALS]
                              and [TOOLBAR]->[Draw Slope NormalsTOOL]
                              Thanks.
                              by TAK2HATA
                              • finitylabF Offline
                                finitylab
                                this is superb.
                                  gvatnar
                                  Thanks for a great plugin!!
                                    bsfranza
                                    hi there together ๐Ÿ˜„
                                    still a great plugin - however i wonder if its possible to edit the script so it shows the slope in percentage? and i wonder if it would be possilbe to modernise it so it uses the overlay function of the latest sketchup??
                                    if anyone can helpt me i would be very happy - im currently trying to edit it on my own with some help of the infamous chat gpt - but from i learned in the forum this is not said to be very effective ๐Ÿ˜„...
                                    will see if anyone can help, im willed to share some cookies ofc!
                                    best
                                    fa
                                    • 2 / 2
