    Yet another SphereTool
    20 Posts 3 Posters 1.3k Views 3 Watching
      driven
      It is just a 'followme' sphere, so I assume yes, I can only show the diagonals by distorting after completion.
        Basically, a QuadFace compatible quad is either:
        1. a native quad (face with four vertices)
        2. two triangles made to act as one unit (separated by an edges that is soft+smooth and cast_shadow: false)
        The reason that cast_shadow needs to be false for the diagonal is that in case the whole mesh is made soft+smooth there needs to be a way to detect what is the diagonal - and since cast_shadow is on by default and it appear most people don't use this property I made that the "magic marker" for the diagonal. This allowed for non-planar quads in SketchUp.
          driven
          So, it should be ok as is?
            It would work. But maybe Rich has hoped for a triangulated version so things can be manipulated without ending up with the edge that SU's AutoFold feature adds. But then again, QuadFace Tools had a function to add triangulation and there is my recent AutoSmooth plugin that both addresses this.
              driven
              @Rich
              is this what you mean?edges as per 'quadface tools' definition
              @TT... does this look right, I applied to all edges, but could just do the diagonals if that's better.
                @John
                Thomthom nailed it. I triangulate everything using the QuadFace tools.
                It will make for a better exchange of data from on app to another.
                  driven
                  @Rich
                  would this do what you need
                  just an off axes sphere, with tri's
                    There's something funky with that because none of Thomthom Ring Select/Loop Select are finding the edges.
                    Even trying to convert it doesn't work.
                    Thom can help here more than me. I do understand the property needed but generation of that property through code is not my bag....
                    Unless I am missing the obvious πŸ˜•
                      No - just the diagonal should have cast_shadow set to false. Cast Shadows set to false is what marks an edge as separating the two triangles of a quad. The border edges should not have this set.
                      Also, I see that lots of your edges are 1 segment Curve entities. Why is that?
                        D'oh....
                        missed the edges that parallel
                          driven
                          I'll exclude the original edges...
                          It's a rotated arc so before I split them with the diagonals, you can scale using 'move-tool' on the cardinal points.
                          for uv is it better if I explode the edge first?
                            For UVs I won't matter. It was just odd to see a one segment Curve. I noticed it because the Smooth and Sort property was gone in the Entity Info when I selected one of them.
