    Jean Prouvé - S.A.M. Tropique table - 1950
    36 Posts 10 Posters 3.3k Views 10 Watching
    • massimoM Offline
      massimo Moderator
      Another awesome piece by the French designer. Modeled in SU and rendered in Thea. Just a contrast + saturation correction in post pro. Perhaps I'll try something with a more complex scene. 😄
        Robust! ☀
        • novenaN Offline
          novena
          grande Massimo!!! you are a genious...
          http://hdzarkitektur.wordpress.com/
          • marked001M Offline
            marked001
            we know you're well-versed in complex scenes..don't worry.
            i'm enjoying these furniture images, personally. great stuff.
            http://www.revision21vis.com
            instagram: revi21on
            • massimoM Offline
              massimo Moderator
              Thanks guys. 😄
              • allanxA Offline
                allanx
                Love your render Massimo, especially those steel legs..they are awesome!
                allanx
                [Portfolio](https://www.coroflot.com/designers/work-stream?id)
                • massimoM Offline
                  massimo Moderator
                  Thank you Allan. 😄
                  • cheddaC Offline
                    chedda
                    Good work & attention to detail especially the textures. I'd like this model in my library 😉
                    Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                    • massimoM Offline
                      massimo Moderator
                      If you mean the real thing you can have it. Not exactly cheap... 😮
                      • Rich O BrienR Online
                        are those fingerprints? Am I looking into another bucket of fish?
                        • massimoM Offline
                          massimo Moderator
                          Yes. You'd like to fry some fish?
                          • cheddaC Offline
                            chedda
                            Virtual sketchup library, i have the original, 7k what a steal !
                            • massimoM Offline
                              massimo Moderator
                              i have the original
                              😲 Really...?
                              • massimoM Offline
                                massimo Moderator
                                Ok Rich now you can do your frying.
                                • cheddaC Offline
                                  chedda
                                  No i don't own the original, i was just messing.
                                    Hold on and I contact my egyptian hieroglyphics expert.... 😕
                                    The fresnel version is adjusted brightness of original? Why are you using that in the Fresnel slot?
                                    You know you now opened a can of worms again....
                                    Another thing is that both Layer weights are 100%....does that mean they blend?
                                    Man...advanced Thea material creation is hard, I really need to figure this shit out in my head before I go nucking futs
                                    • massimoM Offline
                                      massimo Moderator
                                      What I meant was: you have to quit trying to understand everything and start trying something instead of giving up. 😉
                                      But maybe your egyptian hieroglyphics expert has a better understanding. 👍
                                      Yes.
                                      It was just a try. I wanted to introduce a slight variation on the reflection related to the angle of view. The Fresnel controls the reflectivity from 0 degree viewing angle to 90 degree viewing angle depending on the IOR value.
                                      In Thea you can use both blended and stacked layers. If the values of the weights are 100% then Thea will assign automatically 50% each. Otherwise you can put different %. In this particular case I've mixed a glossy mat (the metal) with a basic mat (just the diffuse color of the metal). If you increase the basic % and decrease the % of the glossy mat you'll have a more diffuse look. And vice versa. So simple.
                                      Not hard at all, just a matter of trials & errors.
                                        Where I got lost here was in the fresnel. I couldn't grasp why you would use a fresnel on metal.
                                        Obviously it worked but when using the material ball to test materials it doesn't suit this trial and error approach, does it?
                                        The result is perfect but my understanding of fresnel was for fabrics. This is where my confusion begins.
                                        The layer stack system I grasp but is was always going 50/50 when the textures occupied the same layer.
                                        I don't mean to say Thea is hard to use but its depth of options make advanced materials a science. I really want to get a firm grip on the deeper element to it.
                                        • massimoM Offline
                                          massimo Moderator
                                          A typical illustration of the fresnel effect (you can use this example for the fresnel reflection too) is when you look at a pool: if you look straight down from above at a pool of water, you will not see very much reflected light on the surface of the pool, and can see down through the surface to the bottom of the pool. At a glancing angle (looking with your eye level with the water, from the edge of the water surface), you will see much more specularity and reflections on the water surface, and might not be able to see what's under the water.
                                          Maybe just very reflective metals don't show this in reflection. Anyway I don't know how much that effect added to the mat. I'll try to delete it and see the result.
                                          A material is not good in itself. It depends a lot on lighting, models, environment etc of the scene. Of course a material can have a good "structure". Lets say that Thea's ball is a good "average" tool. I make the mats on Thea's ball (or another simulation scene) and then adjust them once applied in the "real" scene.
                                          You don't have to worry about multiple texture on the same layer. That is automatically managed by Thea accordingly to the energy conservation law. In Kerkythea, for example, you have to assign different layers even for a simple specular map. That's a bit harder.
                                          Well the possibilities are almost infinite. So if you think is hard having infinite possibilities then...yes, is hard. 😄 If you have clear from the beginning what you want to achieve then you'll learn by trying and especially by looking at how good mats are made.
                                            Thea allows that you can give this material to Rich or he must rebuild it? (Copyright licence ? )
