    Elliptic Gears
    16 Posts 8 Posters 1.3k Views 8 Watching
    • E Offline
      enhydra
      I was looking for a plugin, that helps generating elliptic gears. As long as I do standard gears, I am fine with the involute gear plugin. So I sliced two different gears and merged them (see image below). But is there a proper way to generate an elliptic gear?
      • Chris FullmerC Offline
        I'm going to guess that if the involute gear plugin does not support elliptic gears, then there probably is no plugin for it.
        You could contact CADalog and see if they'll incorporate it though.
          there is link inside the text
          Don't know if it's free and the export format
          • E Offline
            enhydra
            I know this tool. It seems promising. πŸ˜„ But the guy has not decided yet, how he wants to publish it. By now there is no export format.
            Regards
            Kurt
            • gillesG Offline
              gilles
              Component Stringer could help.
              (sketchucation.com)
                (sketchucation.com)
                Component stringer AND Ddider's ellipse plugin: http://rhin.crai.archi.fr/rld/plugin_details.php?id=124
                as it makes ellipses with equal segments.
                • Jean LemireJ Offline
                  Jean Lemire
                  Hi enhydra, hi folks.
                  In your image, you show two small circular gears meshed with a larger elliptical one.
                  For this to work, you need a way to accomodate changes in axis distance.
                  Normally, elliptical gears are meshed with other elliptical gears.
                  See this web page for some formula:
                  http://www.technicaljournalsonline.com/ijaers/VOL%20II/IJAERS%20VOL%20II%20ISSUE%20I%20%20OCTBER%20DECEMBER%202012/225.pdf
                  You will see that defining the exact shape for the teeth is not so simple.
                  Just ideas.
                    Even not elliptical gears are no so simple too πŸ˜„
                    38 parameters! πŸ€“
                      Jean Lemire
                      Hi Pilou, hi folks.
                      You are right. Imagine with square gears. Yes, they exist.
                      See this page:
                      Non-circular gear - Wikipedia
                      (en.wikipedia.org)
                      And this one for even more strange looking shapes for gears. Look for the fish shaped one at mid length. Really funny.
                      Just ideas.
                      • E Offline
                        enhydra
                        http://sketchucation.com/forums/viewtopic.php?f=79&t=48477&hilit=component+stringer#p435378
                        Thanks for replying πŸ˜„
                        @gilles & by Gaieus: I will take a look at these two plugins. Hope they do the job. πŸ‘
                        @Jean Lemire:
                        Yes, I am aware of that. πŸ˜‰ Take a look at http://skfb.ly/5k3ecba. A rubber band will press the smaller gear towards the elliptic gear.
                        You get the point: Dealing with gears is quite challenging. But
                        @Pilou
                        I am not bothered by all of the 38 parameters. πŸ˜‰
                          Terrific gears indeed!
                          And crazzy wood clocks 😲
                          • E Offline
                            enhydra
                            I wish I had a laser cutter in the basement. πŸ˜‰
                            • PixeroP Offline
                              Pixero
                              Kind of reminds me of the intro to the old Swedish TV show Tekniskt Magasin.
                                driven
                                you could reverse engineer this one...
                                11mb and v6
                                https://dl.dropbox.com/u/25114184/Clark_67.skp
                                edit forgot to add superelipse plugin may help http://sketchucation.com/forums/viewtopic.php?t=29061
                                • E Offline
                                  enhydra
                                  Unfortunately the plugin "Compnent Stringer" won't work for this kind of problem. Especially if you are interessted in a proper solution. For makers and tinkerers the plugin and also my way are good enough. πŸ˜‰
                                  Look at: http://www.thingiverse.com/thing;57771
                                  • gillesG Offline
                                    gilles
                                    For those who enjoy fine mechanics:
                                    http://kmoddl.library.cornell.edu/model.php?m=689&movie=hide
