    Need help smoothing out a letter
    10 Posts 6 Posters 844 Views 6 Watching
      prodrawercom
      To change a circle from a collection of straight lines, to one that appears to be a true circle, I do the following:
      draw circle
      delete inside of circle
      select circle
      window
      entity info
      increase number of segments
      see circle smooth out
      I thought I would be able to do the same thing with the letter "S". I thought I would click the 3D text icon, type the S, and proceed from there. But, it doesn't work as it did with the circle. Can someone give me a step by step on how to do this? I need to cut out some letters on my CNC for a wedding and can't figure out how to get the letters smoothed out in SketchUp. Thanks
        You can do this with the circle, arc and polygon entities because they are recognized as such entities (and handled differently from "normal" geometry) but these 3D letters are just simple geometry without special, added functions.
        So the only way is to either draw the 2D geometry in another application (which has the ability to do it with more segments), import the geometry and start from there or subdivide the 3D geometry inside SU. Below is a model with two S letters - the left one is the default S and the right one is a subdivided S. Certainly some more care could have been given to the subdivision (especially at the ends of the letter) but the theory works.
        1 iteration with Artisan - the top and bottom faces were creased (to keep them planar) and at the end, CleanUp used to remove unnecessary, coplanar edges from these faces.
        S.skp
        • mitcorbM Offline
          mitcorb
          I found that with Fredo's Bezierspline tool you can change the number of segments with Select curve> right click- Convert to> Polyline Segmentor> Specify segment number in pop up. This will remove the faces formed by the selection as it increases the segment count.
          So, doing it this way, you would have to edit the text component by reducing it down to a 2d profile, modify the segment count, then extrude the profile to the desired thickness.
          Tedious, no doubt for a significant number of these letters.
          There may be other ways to do it more quickly?
          • gillesG Offline
            gilles
            Segmentor increase the number of segments but doesn't refine the curve, I would choose Convert to Catmull spline.
              It seems to me that maybe this is a task for which there's a better application. Inkscape comes to mind.
              • gillesG Offline
                gilles
                With BezierSpline, before
                404 Not Found
                (sketchucation.com)
                Left CatmullSpline, right Segmentor
                  prodrawercom
                  Thanks to everyone.
                  The reason I was using SketchUp is because of its ability to easily change my drawings into code for my CNC. I have used Inkscape very little and don't know if it will produce DXF files. I will check to see. One way or the other I'll get it done and report back. ☀
                    prodrawercom
                    404 Not Found
                    (sketchucation.com)
                    Your left S looks great! Pardon my ignorance but... was this produced with a function of SU or in another application?
                      driven
                      Fredo's 'Curvisard' >> 'Smooth Contours' used on the curves does a quick and reasonably good job on a non-extruded 'font face'.
                      Different fonts have higher precision.
                      3D Text does have a 'best tolerance quality' when used from code, but you can only turn it down. Can be useful if re-drawing 'from scratch'
                      e.g. # Draw an "S" at the origin of the model, aligned left, in
                      Arial Bold, not italics, 1" in size, least tolerance quality, filled,
                      with an extrusion size of 0".
                       Sketchup.active_model.entities.add_3d_text('S', TextAlignLeft, "Arial", true, false, 1.0, 1.0, 0.0, true, 0.0)
                      • gillesG Offline
                        gilles
                        S with 3D text SU then BezierSpline.
