    NEW BuildEdge PLAN 2.0 Beta
    49 Posts 14 Posters 5.8k Views 14 Watching
    • E
      eselick
      Aaron
      I've just started playing with the Beta and have a couple of quick questions.
      Is there anyway to snap new windows and doors to existing Sketchup endpoints?
      I don't seem to be able to create a ground floor only second and higher. Is this normal?
      Thanks so much for all the work.
      Elliot
        Curious I made it from nothing, only perimeter's segments must be all on any same Z ๐Ÿค“
        • aarondietzenA
          aarondietzen
          @eselick said:
          Aaron
          Elliot
          I Elliot,
          Unfortunately, there is no snap (yet) in door and window input.
          I am a little confused about your "Ground Floor" input. Do you mean you are trying to draw a floor on top of nothing? The floor entities were designed to be drawn on top of walls, so that may be your issue, though in the next version, connectivity has been modified, and you may be able to do what you are asking about.
          Hopefully I will be posting that version in the VERY near future!
          Aaron
          "Imagination is more important than knowledge..."
          - Albert Einstein
          • studio43S
            studio43
            Aaron
            I still am having Buildedge crashes. Brendon contacted me and I responded. I cannot locate a .log file
            I have noticed that when I commit to SU or explode the BE geometry it will crash once I envoke BE again
            Paul
            • aarondietzenA
              aarondietzen
              @studio43 said:
              Aaron
              Paul
              Hi Paul,
              Brendon should be back in touch with you today!
              Aaron
              - Albert Einstein
              • C
                CTMan
                Hi Aaron
                I've just downloaded the Open Beta Version and was having a ply around with layouts etc.
                Excellent piece of software !
                I've probably done something I wasn't meant to and ended up with strange results.
                I created a simple wall layout, Selected the whole layout ( probably should've grouped it !) and then moved the layout both up and along the axes. Some walls get left behind - and others get flipped about - see attached pix.
                Like I said its probably misuse at my end but thought I'd mention it
                CTMan
                Start
                • charly2008C
                  charly2008
                  Hi Aaron,
                  this tool could be a great help in building constructions. I started with a simple floor plan. Then I saved the model and closed Sketchup. After restarting and opening the SketchUp model again, the tool could not be started again and also caused a SketchUp crash.
                  My System:
                  Sketchup 8 Pro
                  Operating System
                  MS Windows Prof 7 64-bit SP1
                  CPU
                  Intel Core I7 860 @ 2.80GHz
                  Lynnfield 45nm Technology
                  RAM
                  16,0 GB Dual-Channel DDR3 @ 666MHz
                  Graphics
                  512MB Nvidia GeForce GTS 250 (XFX Pine Group)
                  Hard Drives
                  244GB Samsung SSD 840 Series ATA Device (SATA-SSD)
                  313GB Seagate ST3320613AS ATA Device (SATA)
                  Untitled.skp
                  • studio43S
                    studio43
                    charly
                    I too have been having Buildedge crashes. I recently added a 2gb graphics card and I thought it behaved better. It does still crash. I can make it crash if I build a model (floor, walls & roof) then explode the model, after that I go and click the BE tool and it crashes
                    • aarondietzenA
                      aarondietzen
                      Hi all,
                      There are definitely a few issues in this release of the software. There is a general instability that we have tracked down and are fixing. I hope to release that very shortly.
                      Also, there is an issue with moving from BuildEdge PLAN 1.0 to this beta causes issues with the settings files. Moving back and forth between versions causes PLAN to not load.
                      Both of these issues should be fixed and released very soon (hopefully the first part of this week).
                      Keep an eye out for that update!
                      Aaron
                      - Albert Einstein
                      • aarondietzenA
                        aarondietzen
                        @ctman said:
                        Hi Aaron
                        CTMan
                        Hi CT!
                        BuildEdge PLAN entities cannot be grouped or moved in a group until after you commit the entities. The issue is with the data that buildEdge hold about those entities. The ideal way to work is to complete your BuildEdge PLAN model, then commit it to SketchUp, and then move it around. If you are still having a problem with starting PLAN up again, let me know and I can get you in touch with our help desk. Brendon should be able to get you up and running again.
                        Aaron
                        - Albert Einstein
                        • P
                          paparoach0322
                          Thanks for the 2.0 Beta! I'm a fan of the current version, and I really like the 2.0 features you've added. Has anyone here experienced an issue with the Beta licensing? The beta seemed to work for a few days, but now I get an error when trying to start the plugin - I get an error message stating:
                          "BuildEdge PLAN could not be loaded. License is not activated."
                          If I reinstall the 1.x plugin, it works as expected. As soon as I install the 2.0 Beta, I get the error message above.
                          Any ideas on how to resolve this?
                          Cheers
                          • micioneM
                            micione
                            Same problem here .
                              dehleo
                              Dear Aaron,
                              I downloaded the buildedge plan but when I'm going to use it says that buildedge plan can't be loaded. License is not activated.
                              Pls kindly help me.
                              • aarondietzenA
                                aarondietzen
                                Hi guys,
                                The first release of BuildEdge PLAN 2.0 Beta did expire, but I am happy to say that we have released a new one! Please visit our download page and download again and you will get a new, improved version!
                                - Albert Einstein
                                • utilerU
                                  utiler
                                  Thanks Aaron, so we still need to remove the last version...?
                                  Edit: I guess I could just read the installation instructions. ๐Ÿ˜ณ
                                  Just Curious...
                                  • aarondietzenA
                                    aarondietzen
                                    it's worth mentioning anyway, Andrew!
                                    The newest version of the installer will clean out the previous version, so you can just run it over top of your old software. If you have a licensed installation (i.e. you paid for PLAN at some point in the past) it will not affect your security at all, and you will be able to run software after the Beta period has expired.
                                    Please download a copy and let me know what you all think!
                                    Aaron
                                    - Albert Einstein
                                    • utilerU
                                      utiler
                                      Doing that now, Aaron!! ๐Ÿ‘
                                      Just Curious...
                                        Cool news ๐Ÿ˜Ž
                                        Bugs hunting is open! ๐Ÿ’š
                                        • aarondietzenA
                                          aarondietzen
                                          Cool news ๐Ÿ˜Ž
                                          Yes! ๐Ÿ˜„ ๐Ÿ˜„ ๐Ÿ˜„
                                          - Albert Einstein
                                          • P
                                            paparoach0322
                                            Cool. will check out the new beta today. Thanks.
                                            • 2 / 3
