    Shortcut for Reverse Faces?
    6 Posts 6 Posters 1.4k Views 6 Watching
    • chippwaltersC
      chippwalters
      Hi All,
      Another newbie type question. I can't seem to find a shortcut item listed for 'Reverse Faces.' Is there a way to assign that command to a shortcut key (or a button of some sort?)
      Chipp
      Currently working with Cross-Reality technologies
      • tbdT
        tbd
        1. right click on a face to display the context menu
        2. dismiss that (click outside)
        3. Windows | Preferences | Shortcuts
        4. filter: reverse
        http://plugins.ro
          Jim
          Hi Chipp,
          In order to assign a shortcut key to Reverse Faces, you need to have at least one face selected. Once selected, open the Shortcut dialog, and Reverse Faces will now be in the list.
          • GaieusG
            To expand this: every tool that needs a pre-selection to work with can only be assigned a shortcut key (meaning that it will appear in the shortcut list) when soemething (in this case obviously a face) is selected.
            • K
              kecix3c
              hi, i had a same problem but the only different thing is im using OSX platform. i already select the face and then open the shortcut dialog, but i still couldn't see the reverse face
                  2) dismiss that (click outside)*
                2. Windows | Preferences | Shortcuts
                3. filter: reverse
                Choose Edit...Reverse Face
                *Don't do step 2. In order for context menu items to show in the Shortcuts list, it would have to show in the context menu if you right click and if a face isn't selected, it won't show in the context menu.
