    Lost my "Plugin toolbar" from menu
    5 Posts 4 Posters 559 Views 4 Watching
      Loydski
      Hi Everyone,
      I do hope someone can help me out? I don't know if this is the right forum but I badly need help.
      I was installing some Ruby scripts to my shortcut sketchup "plugin folder" and later noticed upon starting sketchup, there were messages stating errors in loading some previous scripts I have already successfully uploaded prior and got stressed upon realizing my "plugin" on the menu bar went missing.
      Can anyone help me as how to restore the plugin menu?
      I have searched through the net for answers but couldn't find a solution to it.
      Your help will be much appreciated.
      Thanks.
      LLoyd
      • jeff hammondJ Offline
        the plugin menu will only appear if you have a plugin installed.
          If you aren't seeing the Plugins menu between Window and Help, go to Window>Preferences>Extensions and tick all of the boxes you find there. Hit OK and you should see it.
            Loydski
            I must've mangled that area. I re-installed my sketchup and is now working fine with the plugin showing on the menu bar.
            Thank you so much for trying to help.
            Lloyd
              kaas
              i had the same problem yesterday. Tried a lot to fix it but nothing helped. In the end i de-installed and re-installed sketchup and that did the trick
