    [PlugIn] 3D Printers G-Code importer/Exporter Ver0.0.9
    29 Posts 13 Posters 43.2k Views 13 Watching
      @didier bur said:
      Call me stupid but how to launch the script ??
      It's an importer, you find in the list of import formats. File > Import and in the file dialogue you pick the fileformat for G code.
        Davidfi1
        Uploaded vertion 0.0.5.
        Include impruvment to speed and rendering
        Please let me know if you like it 😄
        • Dan RathbunD Offline
          Dan Rathbun
          Line 117:
          if (Sketchup.version_number < 7)
          should be:
          if (Sketchup.version.to_i < 7)
          Line 135:
          # wait forever
          while 1==1 do
          end # while 1
          That is dangerous! It could lock up SketchUp if an error occurs, causing file handles to remain open.
          Use a continue messagebox instead.
          And you should return a numeric error code instead of 0 when an exception occurs.
          I'm not here much anymore.
            Dan Rathbun
            Include improvment to speed and rendering
            Just so you know...
            The native Ruby Console, is not actually a "true console interface".
            It is really a dialog with a non-editable multi-line text control.
            Writing output to the text control is VERY slow, and gets SLOWER the more that is written.
            (*) Write only what you NEED to.
            OR ...
            Perhaps write output to a log file instead, and after the import, display the log file's text in a Webdialog frame. (The browser can display plain text files.)
              Davidfi1
              Dan.
              Thank you, you are very helpfull.
              I don't really know what to do with these errors in the G-Code I am getting.
              It is not even correct to say they are errors at all.
              I use the ruby console as a very simple "information console"
              There is nothing to do with these "errors" just know about them...
              If somone don't want to see these messages he could just close the console.
              In the following versions I will not open the ruby console at all.
              Thank you again.
              David.
                Davidfi1
                @dan rathbun said:
                Line 117:
                Line 135:
                # wait forever
                > while 1==1 do
                > end # while 1
                will do.
                Thank you.
                  Davidfi1
                  New Version 0.0.6 posted
                  Thank you.
                    antoninoion
                    I'm getting the following error in the ruby console every time I start SU and it doesn’t show the G-code file type in the import file types list:
                    GcodeImporterVer0.0.6.rb:38: warning: Object#type is deprecated; use Object#class
                    I installed the plugin through the "Preferences/Extensions/Install Extension" option. I have SU V8.0.16845 for Mac, any idea on what I should do?
                    Antonio
                      Davidfi1
                      Antonio
                      I found the problem - fixing it soon.
                      change line 38 from:
                      if @ent.type == Sketchup::Edge
                      to:
                      if @ent.class == Sketchup::Edge
                      But wait for more testing - I will post a fix soon
                      Thank you.
                        Davidfi1
                        Version 0.0.7
                        Now we have a G-Code Exporter of the previously imported G-Code in the plugin menu.
                        So I changed the name to GcodeTools ... (please delete the old one)
                        The new exporter is a very simple assuming that in the next versions will be
                        adding all the needed features to make it usable
                        • so please let me know what need's to be fixed!.
                          Davidfi1
                          Version 0.0.8
                          Added to the exporter the ability to connect "unconnected" components
                          so now if a component is deleted - the exporter will just put a link to the
                          first component of the disconnected chain
                            Davidfi1
                            Version 0.0.9
                            New in Importer:
                            Will put a Attribute with the value of speed from the imported G-Code in the
                            "filament" & "MotorMove" components
                            Change the Z scale of the "filament" component according to the amount of
                            extruded filament in the imported G-Code
                            New in Exporter:
                            Export to the G-Code the Attribute of speed as was imported by the importer.
                            Export the Extruded length according to the Z scale of the "filament" component
                              Davidfi1
                              What should the next feature be?
                              If you have an idea, I will be very happy to try implementing it.
                                Jim
                                Animate a model of a cnc machine from the gcode.
                                  Davidfi1
                                  Did you try to import CNC G-Code?
                                  Can you explain what was the problem?
                                  Do you have an idea how it should work if it was working correctly?
                                    dooseyboy
                                    i have attempted this plugin in 2013, about to try it in 8 pro.
                                    thought i should bring this little web app that i found recently.
                                    it is a gcode viewer and i was hoping to use it to view the gcode i exported from sketchup in it but it doesn't seem to be working from being exported in 2013.
                                    http://jherrm.github.io/gcode-viewer/
                                    neither of the gcode files i exported from regular sketchup files worked in the simulator. but i am keen to use this addon to use the simulation app
                                    • Z Offline
                                      zurits
                                      Does not work for me either; Sketchup 2013 Win7x86, thanks for for the code.
                                        mkultra
                                        2014 load fails...
                                        2014/SketchUp/Plugins/Fishelzon/GcodeImporterVer0.0.8.rb:38: formal argument cannot be an instance variable
                                        @filamentComp.entities.each { |@ent|
                                        C:/Users/Cheryl/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon/GcodeImporterVer0.0.8.rb:163: formal argument cannot be an instance variable
                                        IO.foreach(filename) do |@line|
                                        C:/Users/Cheryl/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon/GcodeImporterVer0.0.8.rb:183: formal argument cannot be an instance variable
                                        @params.map {|@var|
                                        C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
                                        C:/Users/Cheryl/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon_GcodeTools_ext.rb:40:in register_extension' C:/Users/Cheryl/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon_GcodeTools_ext.rb:40:in loadLastVer'
                                        C:/Users/Cheryl/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon_GcodeTools_ext.rb:47:in <module:Fishelzon>' C:/Users/Cheryl/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon_GcodeTools_ext.rb:11:in <top (required)>'
                                          mctabish
                                          I am also failing to load on start up. I get:
                                          Error Loading File C:/Users/Pop/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon/GcodeImporterVer0.0.8.rb
                                          Error: #<SyntaxError: C:/Users/Pop/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon/GcodeImporterVer0.0.8.rb:38: formal argument cannot be an instance variable
                                          C:/Users/Pop/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon/GcodeImporterVer0.0.8.rb:163: formal argument cannot be an instance variable
                                          C:/Users/Pop/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon/GcodeImporterVer0.0.8.rb:183: formal argument cannot be an instance variable
                                          @params.map {|@var|
                                          C:/Users/Pop/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon_GcodeTools_ext.rb:40:in register_extension' C:/Users/Pop/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon_GcodeTools_ext.rb:40:in loadLastVer'
                                          C:/Users/Pop/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon_GcodeTools_ext.rb:47:in <module:Fishelzon>' C:/Users/Pop/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fishelzon_GcodeTools_ext.rb:11:in <top (required)>'
                                          Any resolution?
                                          sketchup 2014 Win 7 x64
                                          Bruce
                                            Dan Rathbun
                                            Try making the following changes. untested
                                            (Ruby v 2.0 will not allow direct references to instance variables in the block parameter list.)
                                            Line 38:
                                            @filamentComp.entities.each { |ent| @ent = ent
                                            Line 163:
                                            IO.foreach(filename) do |line| @line = line
                                            Line 183:
                                            @params.map {|var| @var = var
