    [PlugIn] 3D Printers G-Code importer/Exporter Ver0.0.9
    29 Posts 13 Posters 44.3k Views 13 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      Key for saving defaults:
      It is preferable to use underscore "" instead of spaces, and to prepend "Plugin" to the key, thus:
      "Plugin_Fishelzon_GcodeImporter"
      I'm not here much anymore.
        Davidfi1
        OK Guys - Thank you.
        I fixed the code according to your suggestions in the next version
        I added a "last version" load to the loader and updated the version number.
        Waiting for yor remarks befor moving on.
        I am thinking about how to implement a "G-Code exporter"
        I need to figure out a way to keep the unused G-Code lines.
        The adding of these lines will enable the exporter to put these lines
        back to the exported G-Code.
        • Didier BurD Offline
          Didier Bur
          Call me stupid but how to launch the script ??
          DB
            @didier bur said:
            It's an importer, you find in the list of import formats. File > Import and in the file dialogue you pick the fileformat for G code.
              Davidfi1
              Uploaded vertion 0.0.5.
              Include impruvment to speed and rendering
              Please let me know if you like it 😄
                Dan Rathbun
                Line 117:
                if (Sketchup.version_number < 7)
                should be:
                if (Sketchup.version.to_i < 7)
                Line 135:
                # wait forever
                while 1==1 do
                end # while 1
                That is dangerous! It could lock up SketchUp if an error occurs, causing file handles to remain open.
                Use a continue messagebox instead.
                And you should return a numeric error code instead of 0 when an exception occurs.
                  Dan Rathbun
                  Include improvment to speed and rendering
                  Just so you know...
                  The native Ruby Console, is not actually a "true console interface".
                  It is really a dialog with a non-editable multi-line text control.
                  Writing output to the text control is VERY slow, and gets SLOWER the more that is written.
                  (*) Write only what you NEED to.
                  OR ...
                  Perhaps write output to a log file instead, and after the import, display the log file's text in a Webdialog frame. (The browser can display plain text files.)
                    Davidfi1
                    Dan.
                    Thank you, you are very helpfull.
                    I don't really know what to do with these errors in the G-Code I am getting.
                    It is not even correct to say they are errors at all.
                    I use the ruby console as a very simple "information console"
                    There is nothing to do with these "errors" just know about them...
                    If somone don't want to see these messages he could just close the console.
                    In the following versions I will not open the ruby console at all.
                    Thank you again.
                    David.
                      Davidfi1
                      @dan rathbun said:
                      Line 117:
                      Line 135:
                      # wait forever
                      > while 1==1 do
                      > end # while 1
                      will do.
                      Thank you.
                        Davidfi1
                        New Version 0.0.6 posted
                        Thank you.
                          antoninoion
                          I'm getting the following error in the ruby console every time I start SU and it doesn’t show the G-code file type in the import file types list:
                          GcodeImporterVer0.0.6.rb:38: warning: Object#type is deprecated; use Object#class
                          I installed the plugin through the "Preferences/Extensions/Install Extension" option. I have SU V8.0.16845 for Mac, any idea on what I should do?
                          Antonio
                            Davidfi1
                            Antonio
                            I found the problem - fixing it soon.
                            change line 38 from:
                            if @ent.type == Sketchup::Edge
                            to:
                            if @ent.class == Sketchup::Edge
                            But wait for more testing - I will post a fix soon
                            Thank you.
                              Davidfi1
                              Version 0.0.7
                              Now we have a G-Code Exporter of the previously imported G-Code in the plugin menu.
                              So I changed the name to GcodeTools ... (please delete the old one)
                              The new exporter is a very simple assuming that in the next versions will be
                              adding all the needed features to make it usable
                              • so please let me know what need's to be fixed!.
                                Davidfi1
                                Version 0.0.8
                                Added to the exporter the ability to connect "unconnected" components
                                so now if a component is deleted - the exporter will just put a link to the
                                first component of the disconnected chain
                                  Davidfi1
                                  Version 0.0.9
                                  New in Importer:
                                  Will put a Attribute with the value of speed from the imported G-Code in the
                                  "filament" & "MotorMove" components
                                  Change the Z scale of the "filament" component according to the amount of
                                  extruded filament in the imported G-Code
                                  New in Exporter:
                                  Export to the G-Code the Attribute of speed as was imported by the importer.
                                  Export the Extruded length according to the Z scale of the "filament" component
                                    Davidfi1
                                    What should the next feature be?
                                    If you have an idea, I will be very happy to try implementing it.
                                      Jim
                                      Animate a model of a cnc machine from the gcode.
                                        Davidfi1
                                        Did you try to import CNC G-Code?
                                        Can you explain what was the problem?
                                        Do you have an idea how it should work if it was working correctly?
                                          dooseyboy
                                          i have attempted this plugin in 2013, about to try it in 8 pro.
                                          thought i should bring this little web app that i found recently.
                                          it is a gcode viewer and i was hoping to use it to view the gcode i exported from sketchup in it but it doesn't seem to be working from being exported in 2013.
                                          http://jherrm.github.io/gcode-viewer/
                                          neither of the gcode files i exported from regular sketchup files worked in the simulator. but i am keen to use this addon to use the simulation app
                                          • Z Offline
                                            zurits
                                            Does not work for me either; Sketchup 2013 Win7x86, thanks for for the code.
