    Render problem with stored light map and Irradiance map
    renderpluginsextensions
    4 Posts 3 Posters 978 Views 3 Watching
    • rishikeshavateR Offline
      rishikeshavate
      Hi friends,
      I rendered a exterior scene in sketchup using Vray.
      It works well when i rendered it with default settings (output size 640 x 480).
      I stored Light catch map, Irradiance Map and loaded these saved maps.
      (through mode parameter in Options > Irradiance map/Light Cathch > mode > changed to From file from Single File)
      I changed output size to 800 x 600 and rendered it again. But this time it is not rendered properly.
      I m attaching the rendered output before using LC and IR map and after using LC/IR map.
      plz help me.
      Thanx.
      Before using LC and IR mapAfter using LC and IR map
      • andybotA Offline
        andybot
        It's a bug in vray. No solution to this unfortunately.
          rishikeshavate
          Thanx for quick response.
          Then what is other solution for lager out put?
          • panixiaP Offline
            panixia
            model as smart as possible and render by "zone render"
