    Barley Twist Spirals
    119 Posts 12 Posters 22.0k Views 12 Watching
      archturn
      Piece of cake...lol
        archturn
        @gilles said:
        Here is a step by step.
        Gilles
        I've used your method for the barley twist. Thanks to you and Dave R the twist (using the screw plugin) is a piece of cake. The "intersect model" used to join the newel with the twist , however, is another thing altogether. I'm really struggling with that part of it. Can you give me any pointers?
          archturn
          I've been having a time trying to intersect the barley twisted part into the rest of the newel. watched YTube videos and I'm wondering if there is an issue with intersecting complex surfaces?N114.jpg
            I can't tell from your image but it could be you are running up against SketchUp's dislike of tiny faces. It won't fill in very tiny ones which will leave a ragged edge. The fix is to perform the intersection after scaling the model up by a factor of 100 or 1000.
            It looks like you could use some softening of the ends, there and your barley twist is inside out. πŸ˜‰
            Are you making the intersecting 'bowl' in the same context as the twist?
              Good point, Peter.
              When I draw pommels and such I tend to make them much larger in diameter than needed and trim them back. I tend to think of it a bit in terms of turning in wood by hand. The cutter would run along the pommel shape and off the wood in a smooth continuous action and not stop right at the edge of the wood. You can see a similar sort of thing in this octagonal pedestal.
              • pbacotP
                It looks a bit like the bowl is not big enough in circumference. It can be larger so that it's rim is beyond any intersection with the twist. You are just going to delete the extra anyway. Same with the twist. At the bottom it looks like it isn't long enough to be sticking out of the bowl. Overlap them completely.
                EDIT, Here's my try. I find in using screw.rb (did you?) It's easier to use the same number of segments for other forms that join to it. It helps line up the geometry. IDK the proper termination, but mine looks like it needs some sanding. I think the bell shape might need be as tangent to the spiral shape as possible. which leads to the very problem. You also need a good intersection!
                You can see the geometry line up in the second picture
                The third picture shows an attempt to "sand it down" with Artisan. Get out the 100 grit!
                More turnings (slow processing) may give better results. Also, I did not bother to adjust the segments in my profile arcs. Probably should not be such a large variance in spacing.
                EDIT: More notes: the two shapes are separate groups. Enter each and intersect with model. You can dbl. click the excess face and delete. I find it helps sometimes to leave the excess in place until done with both intersect-with-model operations. Seems SU does not always recognize a one edge intersection.
                  archturn
                  It definitely helps to resize. I noticed when using the Zorro plugin I got jagged edges. So resizing is a plus. However I am still missing something. I understand that I have to be in edit mode of my group to make then intersection. But does the other object have to be selected as well? That would mean that the second object would have to be part of the edited object?
                  Also I'm wondering why I get a nice surface for my barley twist but portions of my tuning are lines?
                  I would upload my SU file but it is too large to upload.
                    Although you could make an intersection between the twist geometry and the other part of the turning with the other part outside the component (or group), You won't get the faces you need. So the other part of the turning should be in the same context, i.e. inside the component (or group) as the twist geometry.
                    The jagged edges are due to the intersection of two faceted surfaces and really can't be entirely eliminated. You can minimize them by having the same number of edges in both curves but that'll be difficult to manage in this case. If you were making the twist with each start a copy of a component, you would have an easier time with the intersection and less to deal with.
                    I'm not understanding why you are using Zorro for any of this.
                    The lines you're seeing are due to unsoftened geomtry. I don't know if it is something you are doing that results in the unsoftening or if you are doing something with a plugin that causes it. You can fix it by selecting the area, right clicking and choose Soften/Smooth. Or is it Smooth/Soften?
                      archturn
                      As far as I know I am using the same number of segments. SU uses 24 by default and I am setting up the screw dialog to 24
                      Do you mean here to "Select" each and intersect with the model?
                      So you are selectimng both twice and intersecting?
                      • pbacotP
                        In response to Archturn (last post): Select each group (or component), the spiral and the cap, separately. Open (edit) each group and perform intersect with model. This way you can check the intersection is correct and easily delete unwanted material in each. You may want to hold off deleting, until after you've performed both intersection operations. Then you have two groups. You can join the geometry together when you are ready, but I feel you have more control this way while working on it.
                        Dave: "So the other part of the turning should be in the same context, i.e. inside the component (or group) as the twist geometry."
                        I don't think so. If you leave these as separate groups you can perform intersect "with model" from INSIDE each group. IMO you have an easier time then selecting parts to delete and checking the joint before committing to joining the geometry up in the same context.
                        check with hidden geometry that the vertical sections of geometry align. But either way works. That's just my preference.
                        Can you just upload the parts in question? zip it?
                          Peter, yes, you can get the intersect but there'll be no faces created, in this case, to terminate the twist geometry.
                          Take a look at the example.
                          In the foreground there are two components. I opened the cylinder for editing and performed Intersect Faces>With Model. The faces were intersected and edges were created at the intersection but notice there are no faces in the resulting notch.
                          In the background, the box is in the same context as the cylinder. After intersection and deleting the waste, there are faces created in the notch.
                          Intersect.skp
                            archturn
                            Ok Got this part
                            Dave
                            I think I do have the same number of edges - 24. Will try as you said with each twist a copy of a component
                            Just to make it a bit easier to mange at the intersecting point
                            Dave I tried the soften geometry to no avail. I've included a file with a sample part.
                            test turning.skp
                              Crossing posts but here's an example of the round end applied to the twist. Obviously I didn't bother with anything above the termination of the barley twist but there rest is pretty simple. This was done with the twist and a shallow dome in the same context.
                              Pommel Twist.skp
                              I'll take a look at your file as soon as I get a minute.
                                It worked for me. I selected all of the geometry, right clicked, chose Softe/Smooth Edges. I also corrected the face orientation.
                                In my opinion you're using way more segments for your curves than are really needed. This will increase the likelihood of running into the tiny face issue. I think you could reduce that quite a lot without having any real noticeable loss of detail.
                                test turning.skp
                                  archturn
                                  Wow
                                  Doesn't work for me. Can SU get tired? πŸ˜„
                                    I don't know. I've never worked it that hard. Did you try moving the slider a little?
                                      archturn
                                      Slider??
                                        • gillesG
                                          gilles
                                          check this, and Dave is right, you don't need so much segments in your vertical curves.
                                          You must consider the purpose of creating the model:
                                          make a render
                                          creating shape for produtcs
                                          create a catalog of your products for architects....
                                          Stay low poly as far as you can, go see to the gallery and you will see impressives models with low poly.
                                          ho ho cross post πŸ˜„
                                            archturn
                                            That did it
                                            • 3 / 6
