    Layout wishlist
    Scheduled Pinned Locked Moved LayOut Feature Requests
    layout
    84 Posts 24 Posters 37.7k Views 24 Watching
      Arrowheadman
      Simpler way of importing sections from SketchUp…and someone should make a better how-to video for us beginners.
        Set up the section as desired, turn off the section plane if you don't want it to show, create a new scene and, when given the option, choose 'Save as a new style.' Or, in the Styles window, create a new style after making the section. Make sure you don't have the circular arrows showing on the style's thumbnail.
          I made a video. It's processing now and I'll post a link to it as soon as it is ready.
          Here you go: http://sketchucation.com/forums/viewtopic.php?f=12&t=49300
          • bmikeB Offline
            bmike
            • bmikeB Offline
              bmike
              @bmike said:
              well, that doesn't work.
              try this. https://www.youtube.com/watch?v=fFIR6oQPny8
                Penguin2
                A comprehensive PDF manual or Layout for Dummies would be great for a newbie like me!
                • pbacotP Offline
                  Speed up the rendering or make it background. No program I ever used stops so long to show a print window. (I'd say "freezes" but it comes back). This is a big hiccup in workflow.
                  • FrederikF Offline
                    Frederik
                    I've only recently started using LO.
                    It's a great application in itself, but I have to agree with many of the wishes that have already been mentioned and I have a few of my own...
                    1.) Rulers and guidelines.
                    Although the user is able to use the grid and can set the major and minor grid to whatever will suit their needs, I'm still missing an option to turn horizontal and vertical rulers on and off.
                    Similar to how guidelines work and behave in a program like Adobe Photoshop would also be very great to have.
                    2.) Option to control nudge.
                    When moving an object I find it difficult to adjust it precisely enough and even with the keyboard arrows it's difficult as the nurge option seem to move the object by 0,5mm, which isn't accurate enough when you have some small parts you need to place within a group.
                    I recall that Coreldraw had an option where the user could set the nurge number to whatever he/she wanted. In addition there was also micro nudge when pressing the Shift-key while using the arrows to move an object.
                    3.) Import/insert some vector graphic formats to LO.
                    I'm aware that the user can convert an inserted SketchUp view to vector images, render the viewport as Vector and then explode it, however, since you're unable to import svg-, ai-, eps-, wmf- into SU, the user will still need to draw the object in SU prior to inserting it in LO.
                    I don't expect all vector formats to be available, but a format like SVG should be available IMO...
                    I'm within the mechanical engineering business and need to make P&ID's for all projects.
                    All symbols required to make these P&ID's are available in svg-format at i.e. Wikimedia Commons
                    4.) Scrapbook warehouse
                    I've seen users sharing a few scrapbooks (one of the more recent was the My LayOut Scrapbook for Architectural Drawings posted by Krisidious), but I'm sure other users also have a scrapbook or two, which would be beneficial for others.
                    Once I've completed the one I'm working on currently, I'm going to share it.
                    5.) Page numbers - and a date field.
                    I know it has been on the wish-list since v.2, but I really miss this function.
                    6.) Ruby API in Layout.
                    Back on September 2010 I saw Bjanzen posted this...
                    @bjanzen said:
                    you could encourage us to do ruby API in LayOut, and that's probably how that and man other features will get implemented.
                    By that Mr. B was referring to page number and date.
                    These were my first and immediate observations and wishes.
                    Cheers
                    Kim Frederik
                    • FrederikF Offline
                      Frederik
                      I will continue on my list...
                      7.) Option to insert a table.
                      I know that I can draw a table using the line tool and I'm also familiar with copy/paste from Excel and Word, however, I would like to have such an option/tool directly accessible from LO, where I'm able to set the size of the rows and columns as well as the borders and shading.
                      8.) Additional line tool options.
                      I find myself missing more Shape Style tools.
                      I.e. I'd like to have an option enabling me to have an arrow placed in the middle of a line and when lines are crossing other lines, I'd like to have an option where I can select if I want an arch where the lines are crossing.
                      (similar to how it's possible in SmartDraw)
                      To be continued... 😄
                      Cheers
                      Kim Frederik
                        Like this?
                        At least that one you can already do. 😉
                        • FrederikF Offline
                          Frederik
                          Unless I've overseen something, I can't find how this can be done except if you draw two separate lines and then add a start or end the arrow to the line selected...
                          Or if you use the Split tool and then apply the arrow to the line you've cut...
                          What I would like is a tool, where you can select a line and then apply an arrow in middle of the line... Similar to how you can apply an arrow in the start or end of a line...
                          SmartDraw have some very intuitive tools for such purposes... 😉
                          Cheers
                          Kim Frederik
                            pedrinalex
                            I do not know if someone has already asked for this:
                            control the on and off layers inserted from SketchUp model, to avoid having to create scenes with layers off or on.
                            regards
                            Pedro
                            MB ASUS x99M-WS, Xeon e5 2695 v3, 64 GB RAM 2400, 2x gforce gtx 1060, 1 SSDH 1 tb & 3 HD 1 TB c/u
                              Pedro, could you explain that? Scenes made in SketchUp are used to create the viewports in LayOut. You control the visibility of entities with layers in SketchUp. That's the way it is supposed to work.
                                ArCAD-UK
                                Windoze File extensions: An SU file has the extension .SKP the backup version becomes .SKB and I can readily hide the backups so I don't open them accidentally. In LO the extension is .layout(!) but the back up becomes "Backup of [FILENAME].layout". Is there some way to change the extension so I can keep the files hidden but readily available without cluttering up my layout folder or manually moving them?
                                .LBK would be a good option to adopt!
                                  pedrinalex
                                  Hi David.
                                  I read your question and I am preparing some pictures to explain my idea.
                                  Only two days I have been very busy with work.
                                  I hope that this day can upload these pictures.
                                  I send an apology and a hug
                                  regards
                                  Pedro
                                    matt.gordon320
                                    At least for what I'm doing at the architecture firm I work for, options for aligning the edges of a building in a scale viewport with another, as well as showing an equal amount of ground plane would be good. Right now, I'm having to align every single time I update the model. It's tediously slow and frustrating.
                                      ArCAD-UK
                                      Matt:
                                      That sounds like you are changing your scene's camera position when updating scenes. If you do, the insert point in layout changes to follow what you did in SU. Try to set things up so that you can get back to the same camera position before updating.
                                        Matt, are you actually making scenes in SketchUp to use as viewports in LO? It kind of doesn't sound like it.
                                          matt.gordon320
                                          Hey Dave, I'm using scenes, but I think the issue boils down that I'm using SU & Layout to do some design development models, so the overall building envelope keeps changing ever so slightly. Updating the scene to "Zoom Extents" of the model changes the scene layout, thereby changing the way Layout reads, and consequently displays said scene is my guess at the moment.
                                          I think the thing that's the most frustrating is that although the right and left elevation scenes are both set to "Zoom Extents" for the whole model, they still don't line up when stacked in our page layout. If I move and attempt to resize the clipping mask/viewport (whatever it's called in Layout) it simply tries to keep the model centered in the clip mask, and pulls it out of alignment with the one above. I can't seem to get them lined up, no matter what I do.
                                          I might see if I can get permission from my firm to post the layout and SketchUp files, see if I can get some guru advice 😄 . I've been using SU for 7+ years and am really comfortable, but Layout just baffles me in certain respects. Perhaps I'm expecting it to be too much like InDesign.
                                            I see what you mean. If you know the envelope is going to change size, perhaps you'd be better off to not zoom in as tight as Zoom Extents allows. Also, you can set LO to not rescale when you change the viewport size. Would that help. there is a little oddness sometimes when resizing which has been brought up before in that the model will move slightly within the viewport when it is resized. I'm hoping that will change with the next version but that doesn't help you now.
                                            If you can't get permission to share the files on the forum publicly, perhaps you can get permission to share them with one person (me) who won't send them to anyone else.
                                            • 3 / 5
