    Style Experiment
    43 Posts 7 Posters 6.7k Views 7 Watching
      Peter, I hope there is something useful there, anyway. Do you lay the clay render over another image or is it on the bottom? I usually put the render at the bottom of the pile.
      • jeff hammondJ
        @pbacot said:
        Thanks Dave,
        That gives me more to work with. Also looking for nice way to quickly output things such as massing studies where I want it not to look like SU (sorry) and have a little life without taking up the afternoon. With my clay or AO outputs I've tried de-saturating and adjusting the contrast because the overlay tends to darken the whole model, if you know what I mean, so I was interested in how that might be better achieved. (Also for use in PP of regular renderings.)
        Peter
        one possible way to achieve this pretty quick..
        in sketchup, hide/delete any ground planes or walls etc that you don't need lines for then set to hidden line mode**.. export the SU model as .png/.tif with transparency turned on..
        in photoshop, use 'multiply' as the layer blend mode as opposed to 'overlay' ..
        **realistically, what we need in sketchup is a combo of hidden line and wireframe mode.. then we'd be able to export a transparent image composed of only the lines we want with no faces to mess up the blending in post..
          Jeff, that's essentially what I do now.
          Export on PC doesn't allow for exporting PNGs with transparency. ThomThom has an export plugin that will export with the background transparent, though.
          And I've made a feature request for that display style several times including in person at 3D BaseCamp last fall. 😉 Maybe it'll happen.
          • jeff hammondJ
            • pbacotP
              This is TEST. 😳 basically exporting linework from CAD elevations through SU and Daves' grainy pencil style.
              In this case having the white fill in the model is useful to delineate the background. I use "color to Alpha"
              I wish I could just export the shading from KT AO. Always have to remove background and color.
              Here I can finish up a quick study if I were to punch out the windows, add a few lines in the roof and model that porch a little (heh, it is just a cutout). I hadn't put all the siding on yet either.
                That looks nice Peter.
                As for the background, you can put your model on a seamless background even if it is the size of a house. Make that background white in the render and you're all set.
                  How about something like this, Peter?
                  Here's a screen shot of the setup.
                  It's the same seamless background I've been using on many of the other images of this house. I added a couple of spotlights to illuminate the background only. No settings other than to turn on Soft Shadows for the sun.
                  The only other change I made was to set the image to black and white while editing. Otherwise it's just a simple matter of dropping the lines in over the render.
                  • pbacotP
                    I put it under. But it is yellow colored and the background (even white "sky color") is pinkish. In this one I removed the background, desaturated then also put the layer color to alpha. Set it above another white layer, (eventually one mask layer and layer for the ground wash)
                    Setting up a house "studio" not a bad idea. 👍 I took off the SU shadows and so forgot: no ground shadows! (if there were any in this shot)
                    • pbacotP
                      That looks good, Dave! Thanks for the demonstration too. Peter
                        Thank you. And you're welcome.
                        And here's a version of that image with pencil shading.
                        Still a pretty quick process.
                        More contrast with Ambient Occlusion.
                        • jeff hammondJ
                          i just tried a quickie experiment and it went pretty good.. since you seem to be in an experimental mode today, maybe you can mess around with it some..
                          set the style with thicker profiles and depth cue (maybe around 4px at least) --not sure if this is absolutely necessary, it's just how i set it up..
                          export a hidden line view .png (doesn't need to be transparent at this point)..
                          open in photoshop then go Select -> Color Range…
                          click on the color of the face an/or background..
                          push delete..
                          you should be left with only the line work on a transparent background..
                          (adjust fuzziness in the color range select or use refine selection in order to make adjustments as need be)
                          not sure but there might be something useful in there..
                            Jeff, I'll give that a try. Normally I just import the lines image onto a layer set to Multiply and I don't have to monkey with the white background. It doesn't affect the underlying image at all.
                            Sometimes, as in the case of the image where I show the background with the unsoftened edges, I make several lines exports at different sizes and resize them all down to the same size.
                            • jeff hammondJ
                              oh.. right, i guess i forgot what the context of this thread is 😆
                              i mean, i think your examples look great as you're showing and there's no need to do what i mentioned above..
                              that's more/less talking about when you want to have textures in a render but still show some of sketchup's line work.. in which case, the sketchup output of the texture begins to fog the rendered version.. and the darker the you try to make the lines, the more fogged the rendered textures become..
                              so, on that note, carry on..
                                FWIW, when I want to use textures, too, I export a texture image with edges turned off and a separate image with the edges in hidden line. Then combine those with the render.
                                Faces
                                Edges
                                  mwm5053
                                  Where do I find Dave's grainy pencil style.
                                  2011 iMac
                                  SU 2015 Pro, 2017 Make
                                  V2 Twilight
                                  macOS Sierra 10.12.5
                                    Walt, I don't know exactly which line style Peter used but there are a number of my pencil styles here.
                                    FWIW, the pencil shading is not really a style. That part is created outside of SketchUp from either a shadows export from SU or from a clay-rendered image.
                                    • pbacotP
                                      Oops 😳 Maybe that one is not readily available. Dave does have several styles for offer in the Sketchucation store.
                                      Edit: it's called Grainy Pencil fine. Yes it is for the linework, not the shading.
                                      Let's just have SU 2013 add AO, soft shadows, and sketchy shadows 😄
                                        mwm5053
                                        I looked there but really couldn't tell which one it was I also have Dave's styles from SketchUpArtists.
                                        2011 iMac
                                        V2 Twilight
                                          mwm5053
                                          I like that one you did of the house.
                                          2011 iMac
                                          V2 Twilight
                                          • pbacotP
                                            I hope I didn't throw things off. I appreciate the off-topic, Jeff and Dave, because sometimes the line overlay doesn't look good and I am back to wondering WT...hell I did last time and so on. Deleting background around linework might give some flexibility but can cause (low) AA to show I think.
                                            • 1 / 3
