    [Plugin] OBJexporter v3.0 20130131
    304 Posts 96 Posters 467.0k Views 96 Watching
      sceptile
      says the file can amage my computer?
        Let us assume you mean 'damage'...
        Who, what where, when, why and how ?
        Yours might win this week's prize for the most useless error report / query... πŸ˜’
          sceptile
          and i cant find the plug in folder i have sketchup 8 free where is it? thanks
            Your questions get little clearer, and also show that maybe you aren't yet ready for using scripts...
            There are extensive Sketchup Help files available to you.
            For example under the Sketchup main menus Help > Learn About Plugins... opens a link which tells you exactly how to install Plugins etc...
            Also you have not yet explained the '[d]amage' statement that you made earlier... πŸ˜’
              For example under the Sketchup main menus Help > Learn About Plugins... opens a link which tells you exactly how to install Plugins etc... Giving the full paths for PC and MAC,
                Sound
                Hello TIG, thank you for writing such an useful plugin. I look forward for using it in a 3D printing workflow but I noticed two problems - the first one being more serious.
                1. Draw a cube and export it as OBJ. It contains 16 triangle facets, but I would expect 12. If you inspect the generated OBJ you'll notice that it generated a tetrahedron inside the cube by triangulating the internal space. Hence the four more facets. I think this problem needs to be addressed. What do you think about it?
                2. Resulting OBJ files contain lots of duplicate vertices. I think this is because you don't reuse vertices but you generate new ones all time. However this corrupts the topology of the generated OBJ file. If you open it with, say, Netfabb Studio Basic (a popular free utility for 3D printing) it will report all faces as unconnected. I don't know whether SketchUp API associates a unique ID with each vertex; in case it doesn't I think you could just build your own dictionary based on coordinates and check whether you already wrote that vertex and if so, just reuse its index when defining the new facet.
                Thank you for your work, and I really hope you can fix these two things.
                  @Sound
                  I am afraid you are mistaken. πŸ˜•
                  I have tested this extensively and a cube of 6 faces exports as a cube of 12 facets, because they are each triangulated.
                  You can clearly see it in the OBJ code.
                  If I import the OBJ it then arrives with 12 triangulated faces too.
                  this occurs with many OBJ importing apps.
                  IF you triangulate the faces manually before exporting you can create internal 'partitions' inside the cube depending on the order the diagonals are drawn, this should only make more that the visible 12 faces πŸ˜•
                  So this suggests there is something wrong with your initial cube if it indeed has 16 facets when exported, or alternatively something wrong with the app into which you are importing it? There are many apps that import these OBJ files quite acceptably without new facets or complaints about unconnected facets...
                  What are you using to import it ?
                  The code takes faces in the same context using the same material, triangulates them as necessary and produces the facets to suit. This tool is used as the basis of several rendering apps. The Pro OBJ exporter exports a simple cube with a file that is all but identical to this tool's file, so I don't think there's anything wrong with it...
                  Try the Pro version OBJ exporter and see it's the same...
                  I suspect you are either mis-modeling the cube beforehand OR not using appropriate import settings and getting spurious results... I suggest you make an OBJ made from a 1m cube in the positive quadrant of the axes, bb.min at [0,0,0]. Then compare it with mine in the ZIP, which only has 12 facets...
                  obj.zip
                    Sound
                    Thank you for the answer. Yes, it looks like those internal faces were already in SketchUp. A new test shows 12 facets, and that's fine.
                    Still, the other problem persists. Even when the exported cube results in 12 facets, the file contains 24 vertices (you can check this by opening the OBJ file with Meshlab or any other importer, or even by counting the "v" lines in the OBJ file). This looks very wrong, as the original geometry only has 8 vertices. Can you help me about this issue too? Thanks!
                      So no apology for putting me to unpaid trouble when it was entirely your error? πŸ˜’
                      My exporter does work differently from the pro-OBJexporter, which minimizes the number of vertices by recycling them when possible.
                      However, my version treats each context, material and face as a separate set, and doesn't reused vertices. The coding is such that it would be very awkward to effect...
                      However, it has no noticeable effect on the resulting form and a ood 3rd party app should be able to cope with welding vertices etc anyway...
                      Get Pro if you really do NEED this functionality, and are not just being 'anally retentive'.
                      After all my tool is 'free' [donationware] and you cannot readily expect, let alone demand, changes to its functions... πŸ˜’
                        Sound
                        Well, I'm just reporting a bug. A cube, having 8 vertices, is exported with 24 vertices 😲
                        This is a wrong representation of the object and has a very noticeable impact on all uses of the OBJ file when topologic integrity is required (3D printing is one example).
                        Of course I expect nothing from you, being it freeware. Whether you want to fix this bug or leave it there is entirely up to you.
                        Sadly, your code is not even covered by an open source license (it's "all rights reserved"), so people are not allowed to fix this bug and redistribute a fixed version. 😒
                          @Sound
                          The vertex 'duplication' isn't actually a 'bug', since that would suggest that it isn't doing what it is intended to do: and it currently does exactly what it is coded to do.
                          However, I do take your [inelegantly put] point that vertex entries could be 'reused' if they are 'shared' by more that one facet...
                          So I now have an idea on to make an adjusted version of the code that will now does this: and it can also have a few other tweaks; to reduce the file size further, to optimize the processing time etc.
                          I'll post it soonest...
                          PS: Although I do 'reserve all rights' to my code... please feel free to make your own improvements to any of my tools, and either PM me or post them here, of course for free unfettered use by all members... The only thing I ask is not to post whole scripts in the same thread as it'll cause confusion... πŸ˜’
                            Here's v2.8 http://sketchucation.com/forums/viewtopic.php?p=294844#p294844
                            The D.P. accuracy is not now applied to 'whole numbers', and any -0 values becomes 0.
                            Any shared-vertex entries are now 'reused'.
                            The OBJ file size is minimized and the processing time is optimized.
                              Sound
                              TIG, thank you very much for working on that and for clarifying your terms about modifying the script.
                              I will test the new version as soon as possible and report success or failure.
                              Have a good day.
                                Sound
                                I can confirm this works for any model I tried.
                                Thank you! Exported OBJ is now topologically correct and thus suitable for a lot more uses.
                                  Good.
                                    Here's v2.9 http://sketchucation.com/forums/viewtopic.php?p=294844#p294844
                                    Merging of shared vertices is now optional, as it slows down processing for larger models considerably; and it is only required by some more picky mesh-apps, but renderers etc don't seem to mind non-merged vertex data at all.
                                      Here's v3.0 http://sketchucation.com/forums/viewtopic.php?p=294844#p294844
                                      It has a much improved shared-vertex merging algorithm that is now slightly faster than a non-merging version, so the option 'not to merge' has been removed because it is now of no benefit.
                                      Where possible, shared-vertex data is always reused, ensuring correctly formed geometry.
                                      This can mean that a SKP export containing 100,000 faces and therefore potentially 300,000 vertices can be 'compacted' to use perhaps 50,000 shared-vertices [but of course this depends on each SKP's geometry, grouping etc]: this 'compaction' also reduces processing time [which will now be perhaps ~60 seconds for this sized example], and when combined with the latest optimized 'numerical-entries' gives much smaller OBJ file sizes, and faster processing in 3rd-party apps too.
                                      • andybotA Offline
                                        andybot
                                        Great work, as usual, TIG!! This plugin is very essential for me. Many thanks for your development efforts!
                                        • cottyC Offline
                                          cotty
                                          Thank you for this update!
                                          my SketchUp gallery
                                            samurai1789
                                            What simple instructions???? What ever i do i cannot find it HELP!!!!
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 11 / 16
