Ad Blocking on this website?
I don't have any AdBlock and DoNotTrackMe addons for Firefox, I also read what other regular users comment here, so finally what is the solution to view and download those
useful attachments - plugins and others? -
useful attachments - plugins and others?I have find that NoScript (and possible other addons that) do block third party javascripts. So perhaps if you can list the addons you use, maybe someone can spot one that possible do block.
Something on your system is blocking these so the SCF end won't display the links for you.
The most common 'ad-blockers' areAdBlock
,NoScript
andDoNotTrackMe
, these need disabling/removing for SCF to open with all links available - but there are other add-ons too that can cause this...
Also your anti-virus/malware software or your firewall etc might also be set to be over zealous where SCF is concerned...
The tech-guys are working to ensure that nothing that is not a genuine ad-blocker is misinterpreted as one !
If you use IE or install a 'clean' version of 'Chrome' with no add-ons, what happens ?
If that works then you know it's then something in Firefox...I use Firefox [v19] with the latest AdBlock add-on and I have no issues whatsoever, ether with link display or loading times etc [but then it is fully 'disabled' for SCF.com and a few other sites I visit that are supported solely by advertising...]
Thanks notareal for rowing in and helping on this matter. Do you think it might be a good idea to compile a list of possible bottlenecks that folks may have installed?
I've listed the three main ones that I know of...
AdBlock
is easily disabled for the whole SCF site - one-clickNoScripts
also readily allows you to 'whitelist' SCF, but buysellads.com needs specifically enabling as its default setting is 'barred' - of course under the ToS members agree not to use 'ad-blockers'...DoNotTrackMe
is far far less easy to customize, and blocks everything by default...I have also
AVG DoNotTrack
installed and that allows SCF/buysellad anyway - only barring a relatively compact list of usual suspects... -
AdBlock
AVG DoNotTrack
installed and that allows SCF/buysellad anyway - only barring a relatively compact list of usual suspects...I have AdBlock disabled here and everywhere to test and still have buy/sell problems here.
Intermittent problems are the most annoying.
Maybe 5 pages will load ok and suddenly all I get is 1.4 minute time outs...............over and over
Problematic more than not
Any ideas welcomescreenshots 12 minutes apart
To me, Firefox developer tools said it would be waiting for the server to respond (for the main html document).
Then loading all the other resources (although ~50+ files) was not much more than a second.Shouldn't the server logs reveal more valuable info about what happens between that the browser sends a request and that the server responds?
Thanks Guys for sticking with this. I will after a while make a Global regarding the little gremlins that folks may have working away that they could well have forgotten about.
I imagine there are probably a few more that will come the the surface?
Then loading all the other resources (although ~50+ files) was not much more than a second.Well, the site has been put together and styles changed here and there to conform more to our needs but it has never been "optimized" for best performance (yet). Certainly there are many places for improvement and we'll try to do these as our resources allow.
Not only the server logs but there are online tools, too, like Google's page speed insight.
With another site (that I have been building forever) I have managed to get that "improvement possibility list" to have only one item: enabling compression (which I cannot do on my shared hosting server) so I am beginning to understand what those "suggestions" mean but on a site like this, it is much more complex to achieve than on a speedy, small website (which I put together from bits and pieces in php manually so I can optimize wherever I wish).
I would not dare to tamper with the code here though...
I'm still really struggling with this issue of not seeing ads etc. Ive checked all the settings and cleared-out browsing history and caches, updated stuff and so on but still can't see stuff. The image attached is what my browser (Chrome) tells me. I have three computers through my router 2 wired and one wireless. The wireless one (my wifes) I can view ok. Is is wire/wireless issue? Suggestions on remedies welcome please (apart from always using the wifes!).
What 'add-ons' [..Tools>Extensions] do you have loading for Chrome ?
Do you have 'AdBlock'? that needs deactivating for SCF.com. click on the icon at the end of the address bar...Are there any other 'DoNotTrackMe' types of thing ?
I assume your illustration is from the machine that's not working...
Javascript seems fully enabled ?
What about the other settings... my are all similar so I expect that's not it.
I use Firefox so it's not directly comparable... many members use Chrome without difficulty though...
If your Firewall set to allow SCF through unfettered ? That might be a difference ? -
For the forum's troubleshooters, I'm having these loading issues intermittently, this morning I was able to browse the forums no problem, came back after an hour and had the long wait again. An hour later, trying to reply to this thread also took over a minute to load, we'll see if it even posts.
Disabling AdBlock and 'Do not track me' makes it possible, however at the price of very very long loading times.
You can run ad block Pete?
You should be able to
Aha!!! excellent, page loaded in less than a second.
I have 'Firefox' [as my usual browser] and also 'Chrome' [occasional use], both with 'AdBlock' loading, but both have it disabled for SCF. I notice no time difference in the site loading with or without 'AdBlock' enabled - the load-time is usually pretty fast for me - and it's no faster if 'AdBlock' is totally disabled globally.
I use 'AVG DO No Track' which ignores SCF and buysellads anyway, rather than 'DoNotTrackMe', which I found both clunky and difficult to understand and customize ! Have you tried it with that 'off'.
Using 'NoScript' is also likely to stop/slow SCF Ã la une ad-blocker...
That can be disabled using a site 'whiteboard', but I stopped having that add-on enabled altogether ages ago...
Without any first hand experience of this 'load-delay' I am at a loss to suggest what might be up... Is it consistently slow ?? -
Broken record here
Would seem like a setting would be consistent yes/no for loading.
Here are 4 instances within a couple hours where buy/sell twice loads, twice fails to load and times out at ~ 1.4 minutes before allowing page to load.
Do you have 'AdBlock'? that needs deactivating for SCF.com. click on the icon at the end of the address bar... [attachment=0:19pzd05m]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:19pzd05m] Are there any other 'DoNotTrackMe' types of thing ?
If your Firewall set to allow SCF through unfettered ? That might be a difference ?I have no add-ons at all on Chrome, I don't have Adblock and no other 'donottrackme' type things as far as I'm aware.
The illustration was from the machine that isn't working. How and where can I check Javascript? I've checked the firewall and set internet security level to medium and incorporated SCF as a trusted site.
http://sketchucation.com/forums/posting.php?mode=quote&f=76&p=452612# -
,NoScript
andDoNotTrackMe
Thank you so much, 'TIG' and 'notareal' for these tips, but I tried to use Chrome, Opera and also I checked settings in antivirus,it's not working, anyway I can enter on site, view&download attachments using my Android smartphone.
Do you allow javascript to run on pages ?
SCF needs it.
Do your Firewall settings restrict SCF in any way ?
