    [Plugin] Point_Component v2.4 2009
    16 Posts 9 Posters 19.8k Views 9 Watching
    • PixeroP Offline
      Pixero
      Thanks.
      • Chris FullmerC Offline
        I like this one, thanks Honolulu!
        • honoluludesktopH Offline
          honoluludesktop
          Hi Chris, or any one, if you can help me with the above code so the the axis tilt's without rotation, we can improve the plugin.
          • unclebimU Offline
            unclebim
            Thank you for your work, this plugin already came very handy for pointing Twilight spot lights inside SU, did the job in seconds as the axis center of the lights is centered, I just pointed the light without the fixture for a small change in the z-axis target.
              kc10
              sir sorry for being annoying to many questions. does this plugin works also for my idx?
                It should as it is not rendering engine specific but points the SU component. Give it a try!
                  honoluludesktop
                  Updated point component plugin includes beta code for pointing IDX light fixtures as an adjustable light for rendering purposes. IDX provides a free download for those who wish to test rotating the beam of a adjustable light fixture. Read the top post for "beta" limitations.
                  http://forums.sketchucation.com/download/file.php?id=59824
                  Unrendered image.
                  http://forums.sketchucation.com/download/file.php?id=59825
                  Rendered image with adjustable recessed light pointing on picture.
                    honoluludesktop
                    Update improves accuracy of rotated components.
                      carolinebg13
                      Hi Honolulu,
                      Thanks for posting the plug-in.
                      For some unknown reasons, I don't have a plugin folder in my computer. I have a MAC.
                      I am using Sketchup 8 Pro.
                      Here is what I see inside my computer:
                      my username - library - application support - Google Sketup 8 - Sketchup - and then these folders:
                      Autosave, Materials, Old colors
                      If I don't have a "Plugin" folder, what should I do?
                      Thank you so much in advance,
                      Kind regards,
                      Caroline
                        carolinebg13
                        Hi again Honolulu,
                        Would you happen to have this same plugin in a rbz file? Maybe it could work with my Sketchup 8 Pro?
                        Thanks again,
                        Caroline
                          Hi Caroline,
                          Simply rename the ZIP file extension to RBZ and you can use the install extension function under SketchUp > Preferences > Extensions (in SU version 😎
                            carolinebg13
                            Thank you Gai for your quick response.
                            I tried the Sketchup - Preferences - Extensions - Install Extensions ; with renamed .rbz plugin in the zip file, as unfortunate as it is, there is an error message appearing saying "impossible to install extension"...
                            Would you happen to have an B plan? Thanks again!
                            Best regards,
                            Caroline
                            @gaieus said:
                            Hi Caroline,
                              Did you rename the original ZIP extension to RBZ? Or something inside the ZIP files? (Sorry, it is not clear to me what you did)
                                gbterstal
                                Oh.. do I LOVE this plugin. I have been struggling with IDX Renditioner lights for weeks and was even planning to use another rendering tool JUST because of light placement. This tool saved me lots of time and money....
                                Thanks so much Honoluludesktop.
                                • FrederikF Offline
                                  Frederik
                                  Just for the record...
                                  HonoluluDesktop died a few years ago... August 5th 2011 in San Francisco...
                                  http://sketchucation.com/forums/viewtopic.php?f=179&t=40819
                                  Cheers
                                  Kim Frederik
