    [Plugin] Point_Component v2.4 2009
    16 Posts 9 Posters 20.1k Views 9 Watching
    • GaieusG
      @kc10 said:
      does this plugin works also for my idx?
      It should as it is not rendering engine specific but points the SU component. Give it a try!
      • honoluludesktopH
        honoluludesktop
        Updated point component plugin includes beta code for pointing IDX light fixtures as an adjustable light for rendering purposes. IDX provides a free download for those who wish to test rotating the beam of a adjustable light fixture. Read the top post for "beta" limitations.
        http://forums.sketchucation.com/download/file.php?id=59824
        Unrendered image.
        http://forums.sketchucation.com/download/file.php?id=59825
        Rendered image with adjustable recessed light pointing on picture.
        • honoluludesktopH
          honoluludesktop
          Update improves accuracy of rotated components.
          • C
            carolinebg13
            Hi Honolulu,
            Thanks for posting the plug-in.
            For some unknown reasons, I don't have a plugin folder in my computer. I have a MAC.
            I am using Sketchup 8 Pro.
            Here is what I see inside my computer:
            my username - library - application support - Google Sketup 8 - Sketchup - and then these folders:
            Autosave, Materials, Old colors
            If I don't have a "Plugin" folder, what should I do?
            Thank you so much in advance,
            Kind regards,
            Caroline
            • C
              carolinebg13
              Hi again Honolulu,
              Would you happen to have this same plugin in a rbz file? Maybe it could work with my Sketchup 8 Pro?
              Thanks again,
              Caroline
              • GaieusG
                Hi Caroline,
                Simply rename the ZIP file extension to RBZ and you can use the install extension function under SketchUp > Preferences > Extensions (in SU version 😎
                • C
                  carolinebg13
                  Thank you Gai for your quick response.
                  I tried the Sketchup - Preferences - Extensions - Install Extensions ; with renamed .rbz plugin in the zip file, as unfortunate as it is, there is an error message appearing saying "impossible to install extension"...
                  Would you happen to have an B plan? Thanks again!
                  Best regards,
                  Caroline
                  @gaieus said:
                  Hi Caroline,
                  • GaieusG
                    Did you rename the original ZIP extension to RBZ? Or something inside the ZIP files? (Sorry, it is not clear to me what you did)
                    • G
                      gbterstal
                      Oh.. do I LOVE this plugin. I have been struggling with IDX Renditioner lights for weeks and was even planning to use another rendering tool JUST because of light placement. This tool saved me lots of time and money....
                      Thanks so much Honoluludesktop.
                      • FrederikF
                        Frederik
                        Just for the record...
                        HonoluluDesktop died a few years ago... August 5th 2011 in San Francisco...
                        http://sketchucation.com/forums/viewtopic.php?f=179&t=40819
                        Cheers
                        Kim Frederik
