    On a Mac wondering if anyone has this problem, Image on File
    30 Posts 5 Posters 4.8k Views 5 Watching
      mwm5053
      😳 ha what a boob
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
        mwm5053
        That worked better that why I don't code
        and a big thanks to you too for helping this afternoon
        2011 iMac
        V2 Twilight
        • jeff hammondJ
          wait..
          so is it working properly now?
            driven
            that's why I use Copy/Paste code blocks
            But, I should have done -r in the first place....
            EDIT:had a typo in my code block
              mwm5053
              Sorry guys still getting this took 45 sec for icon to load that's ok I don't want to take up all your time, I probably owe you at least a 6 pack for sure by now.
              2011 iMac
              V2 Twilight
              • jeff hammondJ
                nah man.. it's ok.. i'm youtubing on one computer.. messing around in two other apps.. and reading two forums..
                whheeeeeeeee
                • jeff hammondJ
                  at this point then, we would be getting into some areas of riskier things to try which i personally would do on my computers but i'm not going to advise someone else.. i'm not confident enough in my knowledge of the depths of OSX to be talking about it.. (i.e.- i know osx strictly from a user's point of view.. but there comes a point where i have absolutely no idea what these cupertino boys have going)
                    driven
                    It's the only place I'm allowed to smoke, and there's snow outside,,,
                    close all QuickLook windows
                    In Activity Monitor
                    type in Qu to get to bring QL to the top
                    if it's not there, then that's good... it's not being used
                    if it is, select it
                    then hit you Sample Process button
                    try and work out what's keeping it turned on...
                    simple
                      driven
                      the other simpler test is
                      click on your Macintosh HD folder Icon in the sidebar then
                      Finder>>View>>Arrange By>>None
                      it should remove any 'fancy' labelling and can be turned back on if it's not the culprit...
                        slbaumgartner
                        You could also try the sketchup quicklook generator I posted in
                        404 Not Found
                        (sketchucation.com)
                        I had issues early on because SketchUp did not register a quicklook generator of its own, which somehow caused quicklook to try to treat a .skp file as text. It took a long time and then displayed useless info.
                        Steve
                        • G
                          glitchdesign
                          I found this thread because i have the QL helper issue too. I've tried the ql manage steps listed above. I can't say for sure if .skp is the only thing that makes ql go nuts, but there's no doubt that it is a trigger. I've never come across anything like the quicklook generator posted above, will it help specifically with this problem, or is it more just for being able to view files before opening them? Where should i put the .qlgenerator file? I'm afraid i'm not too experienced with this stuff...
                            slbaumgartner
                            @glitchdesign said:
                            So far as I know, nobody ever conclusively proved the cause of this problem, so there is no guarantee of what will work. My theory was that it could be due to SketchUp not registering the .skp extension correctly with Mac OS X, which would cause Finder's preview to scan the file trying to decide how to display it and could clog up the quick look cache. I am sure that SU 8 did not register .skp, but I haven't checked on 2013.
                            Unzip the qlgenerator into ~/Library/QuickLook and the ruby into your plugins folder (the path varies depending on SU version). You may have to run "qlmanage -r" from a console window before the quick look daemon will pick up the new generator. You also have to save a file once before you will get a preview image instead of the sketchup logo.
                            • 2 / 2
