    Color lines drawing
    13 Posts 5 Posters 848 Views 5 Watching
    • Alan FraserA
      Alan Fraser
      That shouldn't be the case. If you choose to colour edges by material, then the only edges that change ought to be the ones you actually apply a specific colour to. All the others will remain the default black, exactly as they were before.
      3D Figures
        AlainBo
        I don't understand.
        According to the method explained by Gaieus, Window > Styles > select "In model" > Select the style you are using (normally just one style there) > Edit tab > Edge settings, seems to concern all edges in the model, not the one I want to change specifically so, if you look at the images posted first vs the last one, edges of wood panels haven't been changed by myself but because I changed the style telling to color edges with material.
          Are you applying the woodgrain material to your components or groups? Apply the wood grain material to the faces only and as described above, apply the colors to your lines and select Color by Material.
          You should apply the materials to the faces anyway so you can control their orientation. Painting the component or group "wrapper" makes that much more difficult. It also makes it harder to show multiple materials as I have on my board.
          • gillesG
            gilles
            Once you set colors by material, note that you can change any edge color in the entity info window.
            If you paint only surface(s) no edges selected, the material will be applied only on surface(s).
            Also this plugin:
            404 Not Found
            (sketchucation.com)
            Hope this helps.
              AlainBo
              Hmmm yes, it seems some groups/components have been painted globaly, some have been painted face by face so, I sometimes have black adegs, sometimes no.
              Also, after having selected to draw edges by material, we have to take care to always select default material to drw something!
              Well, I'm going to look at ChrisP' plugin, I think it would be a good help.
              Thanks a lot.
                What?
                Unless you apply a material/color to an edge after drawing it, it will display as black in Color by Material.
                  AlainBo
                  Yes Dave, you are right sorry.
                  • GaieusG
                    Hmmm yes, it seems some groups/components have been painted globaly, some have been painted face by face...
                    Ah well, true that if you apply a material on a whole group, its edges will also inherit this material.
                    There are pligins to remove group materials (and apply them to the faces directly) and there are plugins to remove edge materials - if you are interested, I can look them up but if you are in a "learning phase", best is to avoid such scenarios altogether.
                      AlainBo
                      I've installed ColorEdge which is quite cool despite some little problems I think and I'm going to look at plugins for faces mapping only.
                      Thanks everybody.
                        the plugins are great but don't get in the habit of relying on plugins to fix sloppy modeling. πŸ˜‰
