    Turning a selection into a face?
    40 Posts 4 Posters 1.3k Views 4 Watching
      @tomot said:
      I did not know that this is a 2 stage process, 1: find & 2: return
      $newface1=sel.grep(Sketchup;;Face) #finds face only!
      > $newface1.pushpull $inset
      So How do I implement a pushpull of $newface1?
      sel.grep(Sketchup::Face)
      This returns an array of all faces in the colletion (in this case selection)
      <span class="syntaxdefault"><br />faces&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">sel</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">grep</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)&nbsp;}<br /></span><span class="syntaxcomment">#&nbsp;Push/pull&nbsp;all&nbsp;faces<br /></span><span class="syntaxdefault">faces</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each&nbsp;</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pushpull</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">distance&nbsp;</span><span class="syntaxkeyword">)&nbsp;}<br />&nbsp;</span><span class="syntaxdefault"></span>
      If you want only one entity, use find():
      <span class="syntaxdefault"><br />face&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">sel</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find&nbsp;</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)&nbsp;}<br /></span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pushpull</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">distance&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;</span><span class="syntaxdefault"></span>
        tomot
        @tig said:
        First off...
        Don't use $ variables !
        snip
        I was using $ variables only to check what my face code was actually being selecting in the Ruby Console. I still trying to resolved this issue. 😢
        [my plugins](http://thingsvirtual.blogspot.ca/)
        tomot
          tomot
          <span class="syntaxdefault"><br />faces </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> sel</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">grep</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}<br /></span><span class="syntaxcomment"># Push/pull all faces<br /></span><span class="syntaxdefault">faces</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pushpull</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> distance </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault"></span>
          <span class="syntaxdefault"><br />face </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> sel</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pushpull</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> distance </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"></span>
          That's precisely my problem in a larger nutshell 😄 , I'm trying to use RickW's offset.rb which draws a 2nd offset on the initial "sel" selected face. Since there now 2 faces I'm having difficulty selecting the offset face for pushpull that the offset.rb created, and NOT the initial "sel" selected face for pushpull. (I can post a pic if my description falls short)
          tomot
          • Dan RathbunD Offline
            Dan Rathbun
            Please do not use that script AS IS. We need to put it on the Quarantine List.
            It overrides the API Array#offset method, and adds methods to both API and Ruby Core base classes.
            You can use ideas from the methods that do not change base classes (by re-writing them and putting them inside your own namespace.)
            So... anyway Rick's offset method should have returned a reference to the added face, because it uses Entities#add_face()
            To use that method inside youir OWN namespace, you need to pass a reference to the original face into the method, and replace all self references within the method to the reference name of the passed face argument.
            Example 1 (The internals have not been changed much, but an undo operation has been added):
            module Tomot
              module SomePlugin
                class << self
                  def offset_a_face( face, dist )
                    unless face.is_a?(Sketchup;;Face)
                      fail(TypeError,"Sketchup;;Face instance expected for 1st argument",caller)
                    unless dist.is_a?(Numeric)
                      fail(TypeError,"Numeric subclass expected for 2nd argument",caller)
                    else
                      if dist.zero?
                        unless $VERBOSE.nil?
                          puts("Tomot;;SomePlugin;WARNING; offset_a_face(); Offset distance was zero.")
                        return nil
                    new_face = nil # this method's return value
                    pi = Math;;PI
                    verts = face.outer_loop.vertices
                    pts   = []
                    # CREATE ARRAY pts OF OFFSET POINTS FROM FACE
                    0.upto(verts.length-1) do |a|
                      vec1 = (verts[a].position-verts[a-(verts.length-1)].position).normalize
                      vec2 = (verts[a].position-verts[a-1].position).normalize
                      vec3 = (vec1+vec2).normalize
                      if vec3.valid?
                        ang = vec1.angle_between(vec2)/2
                        ang = pi/2 if vec1.parallel?(vec2)
                        vec3.length = dist/Math;;sin(ang)
                        t = Geom;;Transformation.new(vec3)
                        if pts.length > 0
                          vec4 = pts.last.vector_to(verts[a].position.transform(t))
                          if vec4.valid?
                            unless (vec2.parallel?(vec4))
                              t = Geom;;Transformation.new(vec3.reverse)
                        pts.push(verts[a].position.transform(t))
                    # CHECK FOR DUPLICATE POINTS IN pts ARRAY
                    duplicates = []
                    pts.each_index do |a|
                      pts.each_index do |b|
                        next if b==a
                        duplicates<<b if pts[a]===pts[b]
                      break if a==pts.length-1
                    duplicates.reverse.each{|a| pts.delete(pts[a])}
                    # CREATE FACE FROM POINTS IN pts ARRAY
                    if pts.length > 2
                      begin
                        if Sketchup.version.to_i > 6
                          face.model.start_operation('Offset Face',true)
                        else
                          face.model.start_operation('Offset Face')
                          new_face = face.parent.entities.add_face(pts)
                        face.model.commit_operation()
                      rescue
                        face.model.abort_operation()
                        raise() # to outer rescue clause
                      end # begin
                    end # if
                  rescue TypeError
                    raise() # just re-raise the Exception
                  rescue => e # any other Exceptions;
                      puts("Tomot;;SomePlugin;WARNING; offset_a_face(); #{face.inspect} did not offset; #{pts}")
                      puts("Error; #<#{e.class.name}; #{e.message}>")
                      puts(e.backtrace) if $VERBOSE
                    raise() # re-raise to any debugger in use
                  else # when no errors;
                    return new_face
                  end # offset_a_face()
                end # proxy class
              end # module SomePlugin
            end # module Tomot
            I'm not here much anymore.
              Dan Rathbun
              Example 2 : Here is a shorter edition that uses a vector or an array as the 2nd argument, and leverages the API's built-in Geom::Point3d#offset! method.
              You can create a vector to pass as the 2nd argument, or call the method with an array literal, to say, offset the face by 10 units in the positive Z direction:
              offset_a_face( @face, [0,0,10.0] )
              module Tomot
                module SomePlugin
                  class << self
                    def offset_a_face( face, vect )
                      unless vect.is_a?(Geom;;Vector3d) || vect.is_a?(Array)
                        fail(TypeError,"Geom;;Vector3d or Array expected for 2nd argument",caller)
                      else
                        vect = Geom;;Vector3d.new(*vect) if vect.is_a?(Array)
                        if vect.length.zero?
                            puts("Tomot;;SomePlugin;WARNING; offset_a_face(); Offset vector length was zero.")
                          return nil
                      verts = face.vertices
                      pts = verts.map {|v| v.position.offset!(vect) }
                      if pts.length > 2
                        begin
                          else
                        rescue
                        end # begin
                      end # if
                    rescue TypeError
                      return new_face
                  end # proxy class
              end # module Tomot
                Dan Rathbun
                Example 3 : a one-liner (with no error trapping, etc.)
                Assume @vect is either an Array or a Geom::Vector3d instance:
                @nface = @oface.parent.entities.add_face(@oface.vertices.map {|v| v.position.offset!(@vect) })
                  <span class="syntaxdefault"><br />model&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />entities&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities<br />sel&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection<br /><br /></span><span class="syntaxcomment">#&nbsp;Grab&nbsp;a&nbsp;list&nbsp;of&nbsp;existing&nbsp;faces<br /></span><span class="syntaxdefault">original_faces&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">grep</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)<br /><br /></span><span class="syntaxcomment">#&nbsp;First&nbsp;offset&nbsp;face<br /></span><span class="syntaxdefault">face&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">sel</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find&nbsp;</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)&nbsp;}<br /></span><span class="syntaxdefault">offset</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">20.mm&nbsp;</span><span class="syntaxkeyword">)&nbsp;</span><span class="syntaxcomment">#&nbsp;I&nbsp;don't&nbsp;know&nbsp;what&nbsp;the&nbsp;real&nbsp;method&nbsp;is&nbsp;there.<br /><br />#&nbsp;Then&nbsp;Push-pull&nbsp;inner&nbsp;face<br /></span><span class="syntaxdefault">faces&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">grep</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)&nbsp;-&nbsp;</span><span class="syntaxdefault">original_faces<br />inner_face_from_offset&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">faces</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">first&nbsp;</span><span class="syntaxcomment">#&nbsp;*should*&nbsp;be&nbsp;just&nbsp;one&nbsp;face<br /></span><span class="syntaxdefault">inner_face_from_offset</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pushpull</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">500.mm&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;</span><span class="syntaxdefault"></span>
                  Untested
                    Dan Rathbun
                    @thomthom said:
                    I don't know what the real method is there.
                    It was my Example 1 (above) but Rick's edition was an instance method added to the Sketchup::Face class. (I re-wrote it to pass the face instance into the method.)
                    As shown in my one-liner (Example 3) a method is not really even needed.
                    @oface is the old face in the selection.
                    The new face will be @nface, and then just do the push-pull on it.
                      That just offsets in an direction - we're talking about offsetting in terms of what the Offset tool does.
                        tomot
                        Tig, thomthom and Dan, thanks for your input it will take me a few days to digest your input, and try putting your input into use.
                        but thomthom is right, I'm looking for the statement that allows me to offset the face the offset.rb creates.
                        I was hoping a simple Boolean expression in the API would have served a very useful purpose, in this particular instance. 😢
                        tomot
                          Dan Rathbun
                          @tomot said:
                          ... but thomthom is right, I'm looking for the statement that allows me to offset the face the offset.rb creates.
                          OK... then first of all the Example 1 re-write of Rick's method mimics the native offset tool, and returns the newly created offset face.
                          (Just ignore Examples 2 & 3, as I did not understand what was needed and may have misunderstood what Rick's code was doing.)
                          If you wish to AGAIN apply an offset, pass the newly created face and a new offset distance (or whatever distance,) into the method a second time.
                          If you wish to move it or something else ... do whatever by using the returned reference as needed.
                          Here is test script wrapped as Tomot::Offset, that adds right-click mouse "Offset Face" commands to the popup menu, but differs in result from the native tool by setting the selection to the new face. (The native tool does not change the selection set.) It also uses an inputbox to get the distance, ... but in practice you would bypass that and your code would supply the needed distance value.
                          module Tomot
                            module Offset
                              class << self
                                  else
                                    if dist.zero?
                                        puts("Tomot;;Offset;WARNING; offset_a_face(); Offset distance was zero.")
                                      return nil
                                  pi = Math;;PI
                                  pts   = []
                                    if vec3.valid?
                                      if pts.length > 0
                                        if vec4.valid?
                                  duplicates = []
                                      next if b==a
                                  if pts.length > 2
                                    begin
                                      else
                                    rescue
                                    end # begin
                                  end # if
                                rescue TypeError
                                    puts("Tomot;;Offset;WARNING; offset_a_face(); #{face.inspect} did not offset; #{pts}")
                                  return new_face
                                #{ get_dist(face)
                                #  Prompts for a distance, then calls offset_a_face()
                                #  If a new offset face is created, it will be set as
                                #    a single object of the current model's selection.
                                def get_dist(face)
                                  result = UI.inputbox(['Offset distance ;   '],[0],'Offset a Face')
                                  if result
                                    ret = offset_a_face(face,result[0])
                                    if ret
                                      sel = Sketchup.active_model.selection
                                      sel.clear
                                      sel.add(ret)
                                    else
                                      return nil
                                  else
                                    return nil
                                end #}
                              end # proxy class
                              unless file_loaded?(File.basename(__FILE__))
                                UI.add_context_menu_handler {|popup|
                                  unless Sketchup.active_model.selection.empty?
                                    if sel.single_object? && sel[0].is_a?(Sketchup;;Face)
                                      face = sel[0]
                                      popup.add_item('Offset Face',10) { get_dist(face) }
                                    else
                                      face = sel.find {|o| o.is_a?(Sketchup;;Face) }
                                      if face # (nil if no face was selected)
                                        popup.add_item('Offset First Face',11) { get_dist(face) }
                                file_loaded(File.basename(__FILE__))
                            end # module Offset
                          end # module Tomot
                          Question to the room at large: Regarding line 137, which is faster for large selection sets ?
                          face = sel.find {|o| o.is_a?(Sketchup::Face) }
                          OR
                          face = sel.grep(Sketchup::Face)[0]
                          Keep in mind both need to be fololowed by a nil test conditional, viz:
                          if face
                            tomot
                            Dan thanks for your code, however regarding your last piece of code.
                            I'm unclear as to how to use it.
                            If I save your code as as offset.rb and replace it with the original offset.rb then load it in the console, I get an error in the console when I right click on selected face.
                            Is this the way you intended it to be used? Please explain further!
                            and just to make sure, please see the attachment regarding the face in question.
                            tomot
                              Dan Rathbun
                              YES, make a selection, then right-click the selection (or a single face,) and an inputbox should pop up to enter a distance.
                              IF you get an error, it would help if you paste the error message into a post.
                                tomot
                                there is also no "offset" reference in the context menu
                                tomot
                                  Dan Rathbun
                                  @Tomot ... you have no profile information showing.
                                  (1) What SketchUp version ?
                                  (2) What SketchUp edition (Free or Pro) ?
                                  (3) What Platform & Operating System ?
                                  Lastly... if you are using an old version that does not support the 2nd ordinal position argument for add_item(), then remove that argument, and the menu items will just be at the end of the popup menu.
                                  The popup menu items are really just for testing... you can directly call the methods just as the menu items do, and remove the popup menu code.
                                  The code is an example.
                                    tomot
                                    Pro, My bad its working, after update!
                                    tomot
                                      Dan Rathbun
                                      You may also be interested in this from TIG:
                                      [Plugin] TIG-Smart_offset v2.1
                                      I have not tried it, so I do not know if it sets the new offset face as the selection.
                                      TIG ?
                                        TIG ?
                                        The originally selected face remains selected, but it should 'return' an array of the new face[s] formed when run via code...
                                          tomot
                                          I would like to take offset 1 step further: namely allowing the selection of more than one face.
                                          I revised Dan's script and added a secondary Reveal offset to the menu. The Reveal menu item represents the depth of the reveal.
                                          The reason behind my initial interest in RickW's offset.rb was to use it to provide reveals
                                          of selected faces, using SketchUp, for proposed concrete faces, be they cast-in-place or precast.
                                          Dan correctly identified users selecting more than 1 face, before the offset professing occurs.
                                          I need a hint 🎉 so I can I change the code to allow selecting more than 1 face?
                                          The attached pic shows my added revised code, the revised code is also attached.
                                          offset.rb
                                          tomot
                                            Dan Rathbun
                                            You should not really have that method.
                                            You should have written an additional method to do a multi-face offset.
                                            What do you want the selection to hold at the end of the multi-face offset ?
                                            (Also.. ALWAYS check if results from an inputbox, in case the user cancels the dialog.)
                                            • 2 / 2
