    Ad Blocking on this website?
    Scheduled Pinned Locked Moved Ideas Box & Board Issues
    118 Posts 27 Posters 49.7k Views 27 Watching
    • jeff hammondJ Offline
      @gaieus said:
      Well, mine seems to be faster indeed - but I am not sure this should explain site slowness to that extent.
      not after seeing pete's results.. his internet is way faster than anyone else here but he's experiencing a slow scf
        Khai
        you need to tone down the adblock detection guys.
        right now, it's triggering if it even detects adblock is installed and enabled.. even when the site is whitelisted! and sorry. I am NOT uninstalling it just to come here. I make an exception for you guys alone. I've actually had to install a secondary browser to use here with no adblocks installed to test but thats not staying for long.. I dunno what you changed but...
        (I have an aversion to flashing things constantly extorting me to buy crap, rogue adverts trying to install malware (right now there's a lovely ad that pops up on Notalwaysright that keeps trying to install something on my Nexus 7 tablet if I use that to read the articles...) etc. )
        • DesertRavenD Offline
          DesertRaven
          Thank you! I have an adblock active for the same reasons, always had and I don't want to waste my time cleaning up malware.
          simplicity is the ultimate sophistication
            right now, it's triggering if it even detects adblock is installed and enabled.. even when the site is whitelisted! and sorry. I am NOT uninstalling it just to come here...
            Khai, I also have AdBlock installed and when I disable it on SCF, it works fine. The "solution" here is not "sensing" if AdBlock is installed or not but if ads are displayed or not.
              Khai
              then I invite you here to show me how to fix it.
              I have "disabled" it on this site. I cannot "see" pictures or attachments. I get a message that I am running an adblocker.
              so. if I disable it fully and restart firefox? I see the pictures and attachments.
              I reenable it, I don't see them
              so. what does that say? hmm? the site is whitelisted and allowed in Adblock. until last the last few days, I was having no issues.
              now I am. and yes I AM seeing ads. I'm NOT seeing attachments.
                Khai
                also this is what I'm seeing. ad's at the top
                and the blocking message at the bottom. oh and ironically.. I can't see my own attachment.
                • tademaT Offline
                  tadema
                  Chrome with no adblock still takes well over a minute to log on
                  • Rich O BrienR Online
                    header ads a local injections and not BSA
                      Aerilius
                      There are ads between the board index and the corner bar. They seem to be "lost" on your screenshot.
                      (In contrast to the SketchUcation banner that is hosted here, the others are hosted on buysellads.)
                        Khai, somehow you still block ads. This is what's missing from your browser.
                          Aerilius
                          Do ads also influence the speed test? (See black box on previous screenshots)
                          • Joe WoodJ Offline
                            Joe Wood
                            It took 45 seconds to load the forum page, then well over a minute after clicking 'new posts'. Waiting on buyselladds. Not very fun waiting so long. Hope we find a solution for this!
                            Joe Wood
                            woodsshop.com/
                            • TaffGochT Offline
                              TaffGoch
                              I've been asked how this works.
                              Internet browsers (every one that I've tested) uses the "hosts" file for domain name resolution, FIRST, before going to domain lookup online.
                              When you type a text web address, the browser needs the corresponding numeric IP address. The browser has to get it someplace, right? Everyone assumes that it is acquired online, as they have seen the messages to that effect.
                              Fortunately, the IP address can be provided by the "hosts" file, if you add them to it. The only primary advantage is faster access, since web-based domain lookup is avoided. This was the initial reason for the "hosts" file.
                              If, however, you put a text web address in the "hosts" file, and provide the WRONG numeric IP address, the browser will go to the wrong address. If you look at the example I provided above, and look in your own "hosts" file, you will see that the numeric IP address provided, for EVERY entry is, "127.0.0.1"
                              "127.0.0.1" is the IP "home" address for your OWN COMPUTER !
                              This causes the browser to look for files on your computer - files that aren't there.
                              When an advertisement is supposed to load, the browser can't find it (on your computer,) so it just skips it. (Some browsers show an error message, some just a blank graphic box.)
                              By the way, you can download "hosts" files, from online sources, that are already packed with hundreds of the the most common "bad actors." I've been doing this for decades; long before ad-blocking software came along. If you find yourself blocked from a necessary website, edit the "hosts" file, to permit routing to the proper address.
                              -Taff
                              "Information is not knowledge." -- Albert Einstein
                                Taff originally wrote...
                                Here is the solution, which I just confirmed on my Windows machine.
                                There is a built-in site-blocking file on EVERY Windows machine, called the "hosts" file (no extension.) Macs may use a similar file. On my Windows XP machine, it is located in the following directory:
                                C:\WINDOWS\system32\drivers\etc
                                Look for the "hosts" file. Open it for editing with Notepad. Use <ctrl>-F, to open Notepad's "find" window, and search for "buysellads". (I found two instances in my hosts file.)
                                Append a "#" character to the beginning of the line. (This will cause the line to be treated as a comment line, rather than a valid block entry.)
                                My case:
                                127.0.0.1 buytraffic.cn
                                127.0.0.1 s3.buysellads.com
                                127.0.0.1 stats.buysellads.com
                                127.0.0.1 buzzclick.com
                                When edited:
                                #127.0.0.1 s3.buysellads.com
                                #127.0.0.1 stats.buysellads.com
                                Save the file. Reload your browser. (I use Chrome, and don't have to reload. A page-refresh is sufficient.)
                                The problem: Uploaded images and attachments being stored at an internet address that is a recognized ad/spamming source.
                                Many ad-blocking programs revise the "hosts" file, as part of their blocking methodology. You can always edit yourself, if you encounter a website that is being blocked, and you need to permit access.
                                If SketchUcation is going to continue to use "buysellads" or comparable host for file storage, these instructions need to be posted as a "sticky"
                                -Taff
                                This post was removed in error.
                                • soloS Offline
                                  Hunted for the 'hosts' file without success, I'm using windows 8.
                                  • Joe WoodJ Offline
                                    Joe Wood
                                    Did Taff or Rich post the Notepad workaround, whichever one of you it was,
                                    In Notepad, is that Ctrl F, or Ctrl -F to search for buysellads?
                                    wow, in Notepad I see maybe 1,000 entries in that Hosts file! While in that Hosts file in Notepad I clicked Edit>Find and entered buyselladd but it found nothing.
                                    hope this workaround works, from the time I clicked the email notification for this thread till I arrived here was over a minute, with Adblock turned off .
                                    Joe Wood
                                    woodsshop.com/
                                    • TaffGochT Offline
                                      TaffGoch
                                      Solo,
                                      See these links, for help with Windows 8:
                                      Editing Hosts File in Windows 8
                                      You canโ€™t block Facebook using Windows 8โ€ฒs hosts file
                                      While the last one mentions Facebook, the article is really about how Windows 8 is treating the "hosts" file differently than previous Windows versions.
                                      The location of the "hosts" file doesn't appear to have changed, however. You should find it in the aforementioned directory.
                                      -Taff
                                      • TaffGochT Offline
                                        TaffGoch
                                        In Notepad, is that Ctrl F, or Ctrl-F to search for buysellads?
                                        Joe,
                                        Careful with your search. It's "buysellads" not "buyselladd"
                                        You can search for just "buysell" and it will still find the entries.
                                        -Taff
                                        • Joe WoodJ Offline
                                          Joe Wood
                                          So do I do Edit>Find while in that hosts file, or do I do that Ctrl F while in that file? Or is it Ctrl -F ?
                                          EDIT- when in that hosts file I did Edit > Find, buysell and all it found was buyselldomain.net
                                          Joe Wood
                                          woodsshop.com/
                                          • TaffGochT Offline
                                            TaffGoch
                                            Joe,
                                            You used "Edit > Find" while in Notepad (editing "hosts") which is the same thing. In other words, "<Ctr>+F" is simply a keyboard shortcut.
                                            (If fact, if you click on the menu "Edit" and pause to look at the list of commands, you'll see the keyboard shortcut right-beside the "Find" entry in the list.)
                                            -Taff
                                            • 3 / 6
