Black screen
Shows a black screen when rendered. Just in case one file, in others it is normal.
Please help -
Probably a lighting issue, have you tried resetting the options to default setting? It might help if you post your settings and an extract of your scene, as this could be caused by several things.
If you are loading a vispot from the internet, I would say thats the culprit. You should stay away from these things because some are from the older 1.05.30 version and there are lots of changes between the 2 versions and will cause errors.
