    Construction & Working Drawings - Discussion
    layout
    453 Posts 114 Posters 442.8k Views 114 Watching
      ArCAD-UK
      Hi Neil I've got an Archicad licence. Great piece of software if you do repeat style projects and don't want to do anything that isn't in the box. I'm migrating to SU as I think it is much more focussed as a design tool. Ok it needs development of the many well discussed shortfalls but fingers crossed we should see some great progress soon.
        rtbuild47
        I use LO all the time for Building Regulation and construction drawings and my only
        gripe is that to define materials have to use colors or shades, when hatching would be so much more professional.
        artybuild
          arcsurvey
          This is my first attempt at a construction drawing for a simple UK lean to extension. I am quite pleased with it but it took a long time to achieve though with practice maybe I can get the time cut down. I find that I get bogged down with the outliner and it takes time to manage my groups. I need to make more use of layers maybe.
          I tried to create a hatch pattern rather than using colours to identify the brick and blockwork but it crashed each time I applied it. Not sure why that was.
          I cannot decide whether to just model the exteriors in SKP to give the 3D and go back to CAD for the 2D plans or whether to stick with it and try to increase productivity.
          First attempt at a section using skp and layout only
          • porch_unpluggedP Offline
            porch_unplugged
            I'm finding that you do cut the time taken down a lot as you progress. You'll find quicker ways of doing things.
            I'd try and stick with the sketchup for the plans as well. I find that clients really respond to the textures etc. of a sketchup drawing, rather than the cold crap look of CAD.
            • Mike LuceyM Offline
              Mike Lucey
              Richard, you might check out Rich's YourTube tut, here, http://www.youtube.com/watch?v=3rZ9-o0vTAs&hd=1
                arcsurvey
                Thank you both for your reply and the hatch plugin looks useful.
                I have been creating a section cut slice from the competed model and then adding the detail such as cavity walls, tiles, etc. Is this generally considered the best way to do it?
                I have found that creating 2D symbols from CAD blocks works well for doing the floor plan in 2D from the 3D section cut without adding a lot of weight to the model.
                I have started my next project and it is going quicker already - I guess it will keep improving.
                  Mike Lucey
                  Keep us posted on progress.
                    sonder
                    artybuild
                    Hmm, I think the opposite. Hatching was developed to identify and define perameters of materials or scope, while SU and layout do this in a method to me that is more clear and direct. I would rather see CMU that looks like CMU rather than a cross hatch pattern that is referenced in a schedule telling you it is CMU.
                    • bmikeB Offline
                      bmike
                      artybuild
                      I also suspect that hatching was a product of the times - plotters and printers that handled lines, and PCs that did the same.
                        sonder
                        artybuild
                        Actually those plotters and printers were the hand and pencil days. Ouch I'm getting old. I graduated architectural school in 1987, so hand drawing was still the main course, with ACAD just really starting to move in the industry.
                        • bmikeB Offline
                          bmike
                          artybuild
                          for sure. i was on the transition period when i dropped out. school was leaning towards a paperless studio for the 3rd year grads, but the first 2 years did a mix of traditional modeling, drawing, 3d, and bullshitting, i mean, critiquing. my prof in school was aghast that i wanted to learn autocad. guess he didn't have to work to put himself through school...
                          prior to grad school i came from an art school with a renaissance style traditional foundation program - so lots of life drawing - both human figure (i was marginal at it) and from observation - still life, landscape, architecture, etc.
                          lots of emphasis in design and painting coursework on sketching. i still have alot of my sketchbooks. flip through them every now and again...
                            sonder
                            Mike, where did you go to school. Sounds a lot like my school - RISD.
                            • bmikeB Offline
                              bmike
                              Cleveland Institute of Art, BFA Sculpture, but I spent time in ID, Graphics, and lots of time working for carpenters and woodworkers.
                              Then to Columbia for Grad school in Architecture. Burned out after a year. Too much $$$$ for living in the city and going to school, and lots of folks who didn't seem to care about the art of actually building...
                              Had a good friend go to RISD for furniture. This would have been in mid 90s. Spent some time there hanging out, fun town. Will be there in 2 weeks visiting and engineer I work with and doing some warranty research on a project I designed a few years ago.
                              Also know a prof down at RISD via some artists I worked for as an assistant in NYC and a by way of a project that I worked on in Jamestown.
                              Small world.
                              • pbacotP Offline
                                artybuild
                                Yeah, but in office work there is such a thing as standardization and efficiency. Hatches developed over time to have the consistent look and are easily identified (basic ones like wood, conc., earth anyway). And, of course it's something when done by hand you need the interns to learn, so it has to be easily defined and copied. It doesn't take an artist.
                                Nowadays we don't really want the "make-work"-let the computer do it. So eventually someone who has developed some nice detail textures will lead the way forward and set the standard. 😠
                                  sonder
                                  artybuild
                                  Man I hope not. I think the beauty of SU textures is they look like real materials. They are not a hatch pattern, and are immediately recognized by all the contractors and laborers. Hatches are a cryptic way to depict materials, that are hopefully going to be gone by the way side. I get a lot of positive feedback on my details, especially from the Spanish speaking work force. In many cases, even the text isn't necessary.....a picture is worth a thousand words. Not sur you can say the same for a hatch pattern.
                                  • bmikeB Offline
                                    bmike
                                    +!!!! on this. Absolutely. At some point our machines will be fast enough and the reproduction quality of prints good and cheap enough to build virtually in the computer with 'real' materials. We are almost there...
                                    I get similar comments when I send off sketches or details, even by using 'simplified' textures and image placement. Makes a whole lot of sense for a foundation contractor to see grey / stone colored materials with steel popping out than some sort of hatch pattern. And I'm not going using as realistic as an approach as Sonder...
                                    • pbacotP Offline
                                      What do you hope not, Nick? Or you hope it is never standardized?
                                      You mean each of us must create his or her own textures and these will always be recognizable by all, even neophytes?
                                      I was hoping your pattern library would be available ($) πŸ˜‰ . (Though I am far from doing such details myself, this might get me there sooner).
                                        sonder
                                        My thought is that a material image (photographic) is more telling than a hatch pattern used to define a given material. I don't think there is a need to standardize images used in defining materials. Concrete can look like concrete in many different images. What I love about SU is the customization allowed by the individual user. We are not bound by standards like this anymore.
                                        Using concrete as an example, just search Google images and you will see hundreds of images of concrete. Most all would clearly be seen as concrete given the context of application to a given foundation model/section/detail. There is no need for a standard pattern any more. I would hate to go back to that, so I really hope that is not something Trimble deems necessary for either SU or LO. I would much rather the focus be placed on getting us even further beyond what has been the industry standard.
                                          sonder
                                          Small world.
                                          I know, crazy. I see you are in Vermont. I went to Kimball Union Academy near White River Junction.
                                          • ccaponigroC Offline
                                            ccaponigro
                                            To hell with the neophytes! (Ok just kidding, well sort of) I think simple hatch patterns will always have a place in architectural drawing. I like to just remove all the color from materials (will someone write me a plug in to change them back and forth from color to monochrome) What I want is copies of everybodies scrapbooks. How come there is no scrapbook warehouse ? (yes I'm lazy)
                                            cfcaia.com
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 18 / 23
