    [Plugin] Import ALL from Folder
    77 Posts 20 Posters 74.4k Views 20 Watching
    • Bob JamesB Offline
      Bob James
      @tig said:
      These then don't show up when you next look for them - they have actually be put into a 'Compatibilty Files' folder that you then have the chance to merge back into the intended folder
      I suggest that you go through all of the folders in your ../Sketchup folder to which you are likely to want to add files - e.g. ../Plugins, ../Materials, ../Components and ../Styles - and ensure you have full access-rights to these and all of their subfolders... then there should be no more 'Compatibilty Files' issues at least πŸ€“
      I finally found the "Compatibility Files" location. There is no such folder name per se. For future reference by other users having this problem it is:
      C:\Users\jamesb*AppData\Local\VirtualStore\Program Files (x86)\Google\Google SketchUp 8\Materials*.
      Thank you for your help. I never would have thought of looking for them πŸ‘
      I had my IT people give me permissions and ownership to the SketchUp files, but this did not solve the problem. So I'm just dragging and dropping from the "Compatibility Folders" to the Materials folder at C:\Program Files (x86)\Google\Google SketchUp 8\Materials 🀒
      Seems like there should be a cleaner way to get new materials/textures into SU. πŸ˜’
        Windows 7 even decided to rename the 'compatibility' folder when compared to Vista πŸ˜’
        It wouldn't be so bad if it explicitly told you what it was doing, rather than subtly moving them into a side-folder !!! 🀒
        Your IT guys need to ensure that all suitable users have full rights to read/write/add/change/delete files/subfolders/etc in the various subfolders of Sketchup that they WILL need to access [at least on occasion]... like Plugins, Components, Styles, Materials...
        This is not exceptional - it should be the norm for all [except the most junior/reckless] members of staff... πŸ˜’ πŸ˜’ πŸ˜’
        It's not Sketchup's fault it's your IT guys... 😑
          Camille Morrison
          Hi I am trying to use the dwg/plugin but I don't know how to get it to work, I tried running it from start/run but it doesn't work
            Camille
            What dwg-plugin ?
            The DWG Exporter is one of the types accessed off Sketchup's File > Export menu - that's Pro only though ?? No 'plugin' file is needed as that is an exporter [.dll on PC] supplied with Sketchup itself.
            BUT do you mean this thread's plugin tool...
            Plugins are not 'run' like external apps they [typically a plugin is named 'xxxxxxxx.rb'] go in the Plugins folder and either appear in a menu or are activated in other ways from within Sketchup itself - as explained in the download page for each tool... so for this tool it says...
            Run the tool by typing
            TIG::import_from_folder
            in the [Window >] Ruby Console, or picking ' Import ALL from Folder' from the [Sketchup] File menu.
              mattao987
              Hi TIG,
              Thanks for your plugin with is really useful.
              I'd like to add an optionnal STAGE in your script.
              Once a file is imported, i'd like to create a new layer named by reference to the file name with a suffix.
              Let's say Wonka_Niv1
              Then, Group all the freshly imported items on this new layer.
              Then proceed to the next file.
              Could you be kind enough to assist me?
                @mattao987 said:
                ...I'd like to add an optionnal STAGE in your script.
                Then proceed to the next file...
                What file type are you importing?
                SKP and Others need to be treated differently...
                Obviously none of this 'Layering' stuff will ever work with imported 'Images' !!
                For non-SKP files:
                Provided there is at least one object already in the receiving-SKP, then all imported formats [other than a SKP] will already import as a component named after the file - e.g. "Wonka_Niv1.dwg".
                So after line#84:
                model.import(file,false)
                add these lines:
                unless File.extname(list[0]).downcase==".skp" ins=model.definitions[File.basename(file)].instances[0] ins.layer=model.layers.add(File.basename(file, ".*")) end#if
                Note: this uses the imported files 'basename' [e.g. "Wonka_Niv1"], to use the full name with say its '.dwg. suffix use ...add(File.basename(file)) instead
                For SKP imports you will need to edit another part of the code:
                after line#107:
                ins=model.active_entities.add_instance(defn,tr)
                add this:
                ins.layer=model.layers.add(name)
                This uses the imported SKP's name, without any '.skp' suffix [e.g. "Wonka_Niv1"] - but if you want to add one, then change ...add(name) to ...add(File.basename(file))
                This should do what you want... πŸ˜„
                  mattao987
                  I encounter some errors at the script loading ( sketchup launch time )
                  Loading File import_from_folder.rb
                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/import_from_folder.rb:89: parse error, unexpected '}', expecting kEND
                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/import_from_folder.rb:124: parse error, unexpected kEND, expecting '}'
                  end#def import_from_folder
                  /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/import_from_folder.rb:134: parse error, unexpected $, expecting '}'
                  I've tried a BBedit editing and I suspect some bad editing error. ( I am not a programmer as you can see )
                  I've tried to edit the code after sketchup launch and it works one time but only one.
                  Could you help?
                    mattao987
                    Maybe I could use this commandm=Sketchup.active_model;m.start_operation('c');m.active_entities.each{|e|next unless e.is_a?(Sketchup::ComponentInstance);n=e.definition.name;l=m.layers.add(n);e.layer=l};m.commit_operation
                      BUT that only puts component-instances in the active_entities context onto layers named after their definitions. πŸ˜•
                      The original .rb file in the first post in the thread works just fine.
                      I can see you have changed some of it in your example...
                      Why?
                      I'm not going to look farther into it as I don't understand what you are attempting to do...
                      What are you trying to do differently, when compared to the original code ?
                      Obviously you have messed up your version that you you attached, it's broken around line#89 πŸ˜’
                      πŸ˜•
                        driven
                        @tig said:
                        Why?
                        hi Tig,
                        I think he's on a mac, as I just tried to run it and got similar errors.
                        As I only needed one folder of images I pulled the bits out and line fed Ruby Console, to ascertain what worked, oddly it was failing at every return and worked when they were removed? is it a 1.8.5 ruby issue? I cobbled the bits that worked in a new file and ran it fine, if you want to see it I can PM...
                          mattao987
                          Sorry for this long absence, ( a long serie of "bugs" in my working life )
                          I've just tried the editing of the code with BBEdit cos it was not working on my mac.
                          My goal is to achieve a fast import of files exported from VectorWorks through the DWG plug-in.
                          I got a very good answer with your script but I hoped to get it one step beyond
                          (Please pardon me my bad english)
                            driven
                            hi mattao987
                            fill in your profile so everyone knows your on a mac, we are a minority group here...
                            I didn't need much of it, but splitting out the explicit returns made the bits I needed work, I also de-modularised it for a one off run.
                            If you go through and gat the basics to fully work, I'd suggest PM'ing TIG your working version of the basic script, then talk about extra's...
                            Even the initial error reports may help see what's going wrong on mac.
                              driven
                              @Tig
                              I just tested using ruby 1.8.7 and it worked fine
                              editand now it works with 1.8.5............how peculiar
                                mattao987
                                I will try to update my ruby asap.
                                  driven
                                  it's just a button click with the new [soon to be released plugin]
                                  look up the mac ruby thread, I haven't got it handy,
                                  or PM me
                                    pmagans
                                    TIG,
                                    Do you know of any .stl batch importers? I have found two .stl importers but nothing with the batch capabilities.
                                      @pmangans
                                      This tool 'Import ALL from Folder' will batch import STL files - if you have the SketchUp STL import/export tool installed: http://extensions.sketchup.com/en/content/sketchup-stl
                                      However because of that importer's coding I think it is not hash-able - so it will use the last options set in its dialog - and you must answer 'Yes' when prompted for each STL file in imports as that can't be switched off...
                                      Get 'Import ALL from Folder' v1.3 here: http://sketchucation.com/pluginstore?pln=import_from_folder
                                        pmagans
                                        Thanks TIG that worked
                                          bitslapped
                                          I love this plugin. I think a nice addition would be an option to import onto a grid so components are easier to manage.
                                          Thanks TIG
                                            Thanks TIG
                                            Try http://sketchucation.com/pluginstore?pln=components_grid
                                            This arranges installed components on a user chosen 'grid'...
                                            • 1 / 4
