    PSP Freeform Pen tool equivalent?
    15 Posts 7 Posters 2.4k Views 7 Watching
    • gonashviliG Offline
      gonashvili
      Hi there
      I've been searching for this for quite a while but still couldn't find a freehand tool that would actually be useful for me, meaning, the lines I draw whether with the native freehand or the 'Tools on Surface' one, are just no good. They both simplify (destroy) my linework. I know its probably not that easy to get it working in Sketchup enviroment as such a 'freeform' line is a bit complex (and needs to be as simple as possible so it won't slow down the pc if it was further processed)
      But still this shouldn't be THAT much of a problem, or?
      Cause right now, I have to convert my line work (I use sketchup for illustration/sketching) from photoshop/illustrator, or better yet from a scanned piece of paper.
      Or if there is such a thing out there please let me know of it!
      Thank you and goodbye
      H.G.
        No matter what you do, in SketchUp curves are broken up into segments. If you can't live with that, you probably ought to be using some other program for your illustrations.
          gonashvili
          Yes I know, Pshop and Illustrator also 'break' them, thing is Sketchup draws them very ugly.
            Ugly curves? Show us.
            I don't seem to run into any problems with ugly curves.
              gonashvili
              Although it looks good, I doubt you drew those curves 'by hand'..
              Maybe I do it wrong, but [curly] linework turns into straight lines with [SHARP CORNERS]when I draw with the native Freehand tool, which makes it absolutely useless, for me at least (the freehand from the Tools on Surface set ain't any better]. If there is a better way of DRAWING [straight into SU] please let me know.
              Hey, I know SU wasn't built for this, though it would be cool if I could draw straight into SU without having to convert/import vectors from other software (which often times gets kinda messy anyway).
              H.
                As I said, if you can't live with the line segments that SketchUp uses to approximate curves, you need to look for another program. That's just the way SketchUp makes them. You might see if the BZSpline tools offer anything that will help. Regardless, you won't get away from the line segments.
                Those curves were hand drawn as much as any curves can be hand drawn in SketchUp. 😒
                • Chris FullmerC Offline
                  I think the answer is that yes, the freehand tool is not very good. It often oversimplifies arcs and curves significantly more than I wish it would.
                  If you're trying to achieve something similar to the pen tool in illustrator, then the bezier tools might be a good one to try. But if you really just want a freehand tool like the one that comes with SU, but does not dumb down curves so much, I'm afraid you might be out of luck. I'm not sure that anyone has written that tool. I think you might try TIG's 2D toolset though. He might have re-written it.
                  • pbacotP Offline
                    For sketching directly as if by hand, Softwares like PS and AI allow accurate tracking and it isn't something SU was made for. I don't see it happening. It requires so much more--different than the current UI.
                    Using Curvizard after drawing, BZ Tools, Artisan (on closed shapes)... Various methods can be used to smooth (and reshape) the curves you've drawn or imported. But probably best to import from a program designed to track your freehand drawings accurately.
                    • jeff hammondJ Offline
                      a visual example using Curvizard as already mentioned in this thread...
                      http://sketchucation.com/forums/viewtopic.php?t=46473
                      • select the janky line...
                      • choose 'smooth contours' in Curvizard..
                      • adjust to your liking.. (my example used the b-spline method with the angle set to 3º )
                      likewise, if you have fredo's bezier tools installed (dave linked to it earlier in the thread)..
                      • right click and choose BZ-convert to -> polyline... (exit)
                      • right click on it again and choose BZ-convert to uniform b-spline..
                      • enter maybe '4' for the order..
                      • default is 30 segments.. type 100s <return> for 100 segments etc...
                      (fwiw, fredo could very likely make a freehand tool that smooths automatically afterwards.. you just have to beg then be sure to hit the paypal button 😉 😄 )
                        gonashvili
                        OK Cheers guys for the input, will have a look at that.... 👍
                        • W Offline
                          watkins
                          It is much easier to 'place' construction points than it is to draw curves using the freehand tool. A possible plugin might do the following:
                          • select the plugin's cpoint tool
                          • place cpoints along the required path
                          • move and adjust the cpoints until everything looks right
                          • select all cpoints along the required path
                          • select the start cpoint
                          • select the end cpoint
                          • select the plugin's curve fit option
                          The plugin then draws a curve through the cpoints, with an edit/curve update option to move the cpoints if needed. The cpoints can then be deleted.
                          One of Fredo6's plugins probably does this already. I need to investigate.
                          Regards,
                          Bob
                            Regards,
                            Bob
                            yeah.. BezierSpline's cubic option does just that (albeit in a different order than you've outlined).. it's similar to 'interpolate curve through control points' as seen in other apps..
                            • pbacotP Offline
                              There are all sorts of ways to make "decent" curves in SU as far as can be expected. I like exploring BZ tools, although I understand them little. But OP's original theme is being able to draw a curve as if sketching by hand.
                                right.. i think using the free hand tool then smoothing with curvizard is going to be the closest to that type of experience right now in sketchup..
                                regarding making that part more automated.. in my non_ruby_minded head, it seems as if all the hard parts are done.. it's just a matter of auto smoothing after using the freehand line tool..
                                that's pretty much how other freehand tools functions in apps such as skitch.. http://evernote.com/skitch/
                                (sort of a rough line but once you release the mouse button, the line smooths)
                                • F Offline
                                  function
                                  has anyone noticed that if you hold shift while using the freehand tool it is more precise? still blocky, but it won't simplify after you've laid the line, and it wont' snap to anything. on top of it, you can't click on those lines after laying them???
