    Stool: How to...
    Scheduled Pinned Locked Moved Organic Modelling
    10 Posts 7 Posters 9.6k Views 7 Watching
    • BurkhardB Offline
      Burkhard
      ...create this seatback?
      Can anybody explain, what is the best way to start such a twisted object.
      I feel a bit helpless with that.
      http://www.ia-plus.de
        leminilab
        do you have a reference name for this stool? Or a bigger reference image maybe?
        • "Live every day as if it were your last and then some day you'll be right."
        • "ThomThom rules!!!"
          See PM
          • BurkhardB Offline
            Burkhard
            Big thanks to you, Rich. More then I expected! Nice solution, have to try this out.
            Thought Artisan is the only solution.
            @leminilab you can find this chair at "team7.at" and called Girado
            for sure...and a happy new year to all
            • Mike LuceyM Offline
              Mike Lucey
              All part of the Premium Membership service πŸ˜‰
              • BurkhardB Offline
                Burkhard
                Really nice Mike.....
                @Rich....I tried what you suggested but reached the limit by setting the hight with vertex tools. The Fall off does not work in a curve, so the wooden back is -like your example- just in the middle ( does not follow the curve ) . I need a constant tapering in the rounding to its ends. Hope I got the right words for it.
                  Some tweaks....
                  • pjbazelP Offline
                    pjbazel
                    @rich o brien said:
                    Some tweaks....
                    [attachment=0:2cc50wdq]<!-- ia0 -->PickPic 2.png<!-- ia0 -->[/attachment:2cc50wdq]
                    Rich, I'm just curious how you added the offset from the front and back face detail, in order to get the edges tighter. I would assume it was JPP out with 'erase original faces' on, but it looks as though the thickness hasn't changed.
                    • panixiaP Offline
                      panixia
                      i suppose he used quadface tools > connect edges
                      with some quite high pinch..
                      • utilerU Offline
                        utiler
                        @rich o brien said:
                        Some tweaks....
                        [attachment=0:1id98krc]<!-- ia0 -->PickPic 2.png<!-- ia0 -->[/attachment:1id98krc]
                        Rcih, did you use FAK there?
                        Just Curious...
