    Refer to entities from code
    19 Posts 5 Posters 1.1k Views 5 Watching
    • jolranJ
      jolran
      Hah 😄 , yes thats exactly just what I did.
      I ran into trouble deleting the newly created definition, with something like :
      gp=Sketchup.active_model.active_entities.add_instance(@su_gp.definition, ORIGIN)
      Also since @su_gp (in my case) could be either a group or component I had to put in some ifs and nots as well. With entities.parent for groups just like you described.
      Not a big deal to explode, performance-vise. Feels safer.
      Thanks for reasuring about the group unique thing. Not gonna use it this time though 😄 .
      BTW hope this issue was related to the topic.
      • Dan RathbunD
        Dan Rathbun
        @dacastror said:
        ... suppose that I assign a different name to each dictionary of each entity and I want to find the entity using the name of the dictionary. How can I modify the condition
        " if i.get_attribute("dacastor 666", "id", nil)==idd "?
        (google translator)
        if i.attribute_dictionary(idd)
        or
        unless i.attribute_dictionary(idd).nil?
        I'm not here much anymore.
        • Dan RathbunD
          Dan Rathbun
          @dacastror said:
          I was trying something, but is a bit more complicated:
          you can simply do:
          def find_inst_by_dict_name(dname)
            found = nil
            for d in definitions
               next if d.image?
               found = d.instances.find{|i|
                 i.attribute_dictionary(dname)
               break if found
            end # for
            return found
          end # def
            You/we are starting to conflate the searching for an object that has a named attribute-dictionary attached to it [and which is uniquely named for one object, and is irrespective of any key/value pairs], and then the original code snippets which were about assigning, and then checking for, the 'value' of a specific 'key' in a named attribute-dictionary [where the key and dictionary are commonly named across several objects, and only vary by the key's 'value'].
            I suggest you step back and decide what it is you are trying to do and how you do it best...
              dacastror
              Thanks Dan, I find it very nice your suggestion, I will give a chance to this
              Thanks for replying TIG, I really needed to know the two things, I was lost without your help
              (google translator)
                dacastror
                I did this and I get "error", I couldn't see what is wrong
                mod = Sketchup.active_model
                definitions = mod.definitions.to_a
                def find_entity(dname)
                  found = nil
                     next if d.image?
                     break if found
                  end # for
                  return found
                end # def
                entity = find_entity("dic1")
                • sdmitchS
                  sdmitch
                  you need to move the
                  statements inside the def since they are not module variables starting with "@".
                  http://sdmitch.blogspot.com/
                  • Dan RathbunD
                    Dan Rathbun
                    I CAN 😳 It is a stupid mistake on my part.
                    def self.find_entity(dname)
                      found = nil
                      for d in Sketchup.active_model.definitions
                         next if d.image?
                         break if found
                      end # for
                      return found
                    end # def
                    • Dan RathbunD
                      Dan Rathbun
                      Assume you have a "DiegoCastro" folder:
                      And in it a "Lib.rb" file for your library methods:
                      module DiegoCastro
                        module Lib
                          def find_entity(model,dname)
                            found = nil
                            for d in model.definitions
                              next if d.image?
                              break if found
                            end # for
                            return found
                          end # def
                        end # Lib sub-module
                      end # Author toplevel namespace module
                      Then in SomePlugin you do this... (name it whatever.. "diegotest.rb" etc.)
                      module DiegoCastro
                        module SomePlugin # <--<< change plugin sub-module name as needed
                          class << self # proxy class
                            require('DiegoCastro/Lib')
                            include(DiegoCastro;;Lib)
                            def find_inst_by_dict_name()
                              if @last_dict.nil?
                                @last_dict = "dynamic_attributes" # initial value
                              dname = UI.inputbox(['Dictionary Name........; '], [@last_dict], "Find by Dicto Name")
                              if dname # user did not cancel the inputbox
                                unless dname.empty? || dname[0].length==0
                                  @last_dict = dname[0]
                                  entity = find_entity(Sketchup.active_model,dname[0])
                                  if entity
                                    UI.messagebox("Found #{entity.inspect}     \nwith dictionary name '#{@last_dict}'     ")
                                    return entity
                                  else # nothing was found because find returned nil
                                    UI.messagebox("No entity found with     \n dictionary name '#{@last_dict}'     ")
                              return nil
                          end # proxy class
                          unless file_loaded?(File.basename(__FILE__))
                            # create menus here;
                            @@submenu = UI.menu('Plugins').add_submenu('Diego')
                            @@submenu.add_item('Find entity by Dicto Name') {
                            file_loaded(File.basename(__FILE__))
                        end # plugin sub-module
                      end # Auhtor module
                        dacastror
                        wow thanks Dan, I will take some time to study this code, worth but me several questions arise, I will try to solve the most I can on my own, thank you very much 😄
                        (google translator)
