    Refer to entities from code
    19 Posts 5 Posters 969 Views 5 Watching
      The API docs are sometimes wrong, .make_unique IS needed if you want to change only one instance of a component, AND it's quite possible to have more than one instance of a group too...
      However you only need to do it if there's more than one instance, so I suggest you change the code to:
      if entity.is_a?(Sketchup::Group) && entity.entities.parent.instances[1] entidades[i-1].make_unique elsif entity.definition.instances[1] ### it's a component-instance entidades[i-1].make_unique end
      Note we have to have two ways to access the object's definition and thereby its instances.
      The instance.definition works for a component-instance, but there's no equivalent for a group, for that we get the group's entities-object's parent - which is actually the definition.
      There is a 'collection' called model.definitions which contains all of the definitions in the model.
      A definition can be a Component, or a Group, or an Image.
      Groups and Images just being special kinds of 'components' if you will...
      There are two tests - d.image? and d.group? - which return true if the 'type' matches; because we aren't looking for an image when we iterate through the definitions I added
      next if d.image? which stops processing the current definition and goes on to the next one.
      Similarly when we iterate the instances and get a match on the 'idd' we set 'hit' to refer to that instance and we break - to stop iterating the instances because we have got match. Also after that the line break if hit stops iterating the definitions, when we have found a match.
      We don't actually need to skip an iteration, or stop it - because it'll carry on to the end of the lists; however, when we get a match we will waste time continuing to look because we won't find it, so it's best to learn how to use next and break to exit 'loops' ans streamline the code to do just what it needs, and no more.
      • jolranJ Offline
        jolran
        Hi, just want to jump in and doublecheck a little.
        So group.make_unique in the case for a group is safe to use then?
        Made a clone(instance) of the userselection group and the group was affected by transformations made (not surprisingly) if not made uniq on the original. But that anoying warning freaks me out in the ruby consol.
          The deprecated warning IS a mistake in the API.
          You CAN safely make a group unique, indeed sometimes you MUST.
          However, you can side step it, by making an empty new-group in the intended entities context and adding an instance of the copy-group into it and explode that inside it, the new-group is then equivalent to the original BUT not connected...
          new_group = some_entities.add_group() new_copy = new_group.entities.add_instance(original_group.entities.parent, original_group.transformation) new_copy.explode
          The 'new_copy' replicates 'original_group' with no 'connections'...
            dacastror
            I'm reading carefully the lines of code and I'm learning TIG proposes several things, another question arises me, suppose that I assign a different name to each dictionary of each entity and I want to find the entity using the name of the dictionary. How can I modify the condition
            " if i.get_attribute("dacastor 666", "id", nil)==idd "?
            (google translator)
              If you have say three different dictionaries you can use something like:
              ` nlist=["dacastor123", "dacastor666", "dacastor999"]###***
              ###... etc
              d.instances.each{|i|
              ###... etc
              nlist.each{|dict|
              if i.get_attribute(dict, "id", nil)==idd
              ###.... etc ### do stuff here
              } ###... etc`
              ***### 'nlist' is an array of possible dictionary names... set up before you start iterating collections of things...
              'dict' refers to each "string" name, inside the 'nlist' [array]...
              Note that the attribute dictionary 'names' AND the 'keys' should not contain 'spaces' or other puncuation - it should start with a-z, then more or 0-9, but you can include an '_'
                dacastror
                TIG thank you very much, I will try that 😄
                I was trying something, but is a bit more complicated:
                idd = "dic1"
                hit = nil
                mod.definitions.each{|d|
                   next if d.image?
                      next if i.attribute_dictionaries.to_a.size<1
                      dictio = i.attribute_dictionaries.to_a
                      if dictio[0].name==idd
                         hit=i
                         break
                   break if hit
                • jolranJ Offline
                  jolran
                  Hah 😄 , yes thats exactly just what I did.
                  I ran into trouble deleting the newly created definition, with something like :
                  gp=Sketchup.active_model.active_entities.add_instance(@su_gp.definition, ORIGIN)
                  Also since @su_gp (in my case) could be either a group or component I had to put in some ifs and nots as well. With entities.parent for groups just like you described.
                  Not a big deal to explode, performance-vise. Feels safer.
                  Thanks for reasuring about the group unique thing. Not gonna use it this time though 😄 .
                  BTW hope this issue was related to the topic.
                  • Dan RathbunD Offline
                    Dan Rathbun
                    @dacastror said:
                    ... suppose that I assign a different name to each dictionary of each entity and I want to find the entity using the name of the dictionary. How can I modify the condition
                    (google translator)
                    if i.attribute_dictionary(idd)
                    or
                    unless i.attribute_dictionary(idd).nil?
                    I'm not here much anymore.
                      Dan Rathbun
                      you can simply do:
                      def find_inst_by_dict_name(dname)
                        found = nil
                        for d in definitions
                           next if d.image?
                           found = d.instances.find{|i|
                             i.attribute_dictionary(dname)
                           break if found
                        end # for
                        return found
                      end # def
                        You/we are starting to conflate the searching for an object that has a named attribute-dictionary attached to it [and which is uniquely named for one object, and is irrespective of any key/value pairs], and then the original code snippets which were about assigning, and then checking for, the 'value' of a specific 'key' in a named attribute-dictionary [where the key and dictionary are commonly named across several objects, and only vary by the key's 'value'].
                        I suggest you step back and decide what it is you are trying to do and how you do it best...
                          dacastror
                          Thanks Dan, I find it very nice your suggestion, I will give a chance to this
                          Thanks for replying TIG, I really needed to know the two things, I was lost without your help
                          (google translator)
                            dacastror
                            I did this and I get "error", I couldn't see what is wrong
                            mod = Sketchup.active_model
                            definitions = mod.definitions.to_a
                            def find_entity(dname)
                              found = nil
                                 next if d.image?
                                 break if found
                              end # for
                              return found
                            end # def
                            entity = find_entity("dic1")
                            • sdmitchS Offline
                              sdmitch
                              you need to move the
                              statements inside the def since they are not module variables starting with "@".
                              http://sdmitch.blogspot.com/
                                Dan Rathbun
                                I CAN 😳 It is a stupid mistake on my part.
                                def self.find_entity(dname)
                                  found = nil
                                  for d in Sketchup.active_model.definitions
                                     next if d.image?
                                     break if found
                                  end # for
                                  return found
                                end # def
                                  Dan Rathbun
                                  Assume you have a "DiegoCastro" folder:
                                  And in it a "Lib.rb" file for your library methods:
                                  module DiegoCastro
                                    module Lib
                                      def find_entity(model,dname)
                                        found = nil
                                        for d in model.definitions
                                          next if d.image?
                                          break if found
                                        end # for
                                        return found
                                      end # def
                                    end # Lib sub-module
                                  end # Author toplevel namespace module
                                  Then in SomePlugin you do this... (name it whatever.. "diegotest.rb" etc.)
                                  module DiegoCastro
                                    module SomePlugin # <--<< change plugin sub-module name as needed
                                      class << self # proxy class
                                        require('DiegoCastro/Lib')
                                        include(DiegoCastro;;Lib)
                                        def find_inst_by_dict_name()
                                          if @last_dict.nil?
                                            @last_dict = "dynamic_attributes" # initial value
                                          dname = UI.inputbox(['Dictionary Name........; '], [@last_dict], "Find by Dicto Name")
                                          if dname # user did not cancel the inputbox
                                            unless dname.empty? || dname[0].length==0
                                              @last_dict = dname[0]
                                              entity = find_entity(Sketchup.active_model,dname[0])
                                              if entity
                                                UI.messagebox("Found #{entity.inspect}     \nwith dictionary name '#{@last_dict}'     ")
                                                return entity
                                              else # nothing was found because find returned nil
                                                UI.messagebox("No entity found with     \n dictionary name '#{@last_dict}'     ")
                                          return nil
                                      end # proxy class
                                      unless file_loaded?(File.basename(__FILE__))
                                        # create menus here;
                                        @@submenu = UI.menu('Plugins').add_submenu('Diego')
                                        @@submenu.add_item('Find entity by Dicto Name') {
                                        file_loaded(File.basename(__FILE__))
                                    end # plugin sub-module
                                  end # Auhtor module
                                    dacastror
                                    wow thanks Dan, I will take some time to study this code, worth but me several questions arise, I will try to solve the most I can on my own, thank you very much 😄
                                    (google translator)
