    Refer to entities from code
    19 Posts 5 Posters 1.2k Views 5 Watching
    • jolranJ
      jolran
      Hi, just want to jump in and doublecheck a little.
      So group.make_unique in the case for a group is safe to use then?
      Made a clone(instance) of the userselection group and the group was affected by transformations made (not surprisingly) if not made uniq on the original. But that anoying warning freaks me out in the ruby consol.
        The deprecated warning IS a mistake in the API.
        You CAN safely make a group unique, indeed sometimes you MUST.
        However, you can side step it, by making an empty new-group in the intended entities context and adding an instance of the copy-group into it and explode that inside it, the new-group is then equivalent to the original BUT not connected...
        new_group = some_entities.add_group() new_copy = new_group.entities.add_instance(original_group.entities.parent, original_group.transformation) new_copy.explode
        The 'new_copy' replicates 'original_group' with no 'connections'...
          dacastror
          I'm reading carefully the lines of code and I'm learning TIG proposes several things, another question arises me, suppose that I assign a different name to each dictionary of each entity and I want to find the entity using the name of the dictionary. How can I modify the condition
          " if i.get_attribute("dacastor 666", "id", nil)==idd "?
          (google translator)
            If you have say three different dictionaries you can use something like:
            ` nlist=["dacastor123", "dacastor666", "dacastor999"]###***
            ###... etc
            d.instances.each{|i|
            ###... etc
            nlist.each{|dict|
            if i.get_attribute(dict, "id", nil)==idd
            ###.... etc ### do stuff here
            } ###... etc`
            ***### 'nlist' is an array of possible dictionary names... set up before you start iterating collections of things...
            'dict' refers to each "string" name, inside the 'nlist' [array]...
            Note that the attribute dictionary 'names' AND the 'keys' should not contain 'spaces' or other puncuation - it should start with a-z, then more or 0-9, but you can include an '_'
              dacastror
              TIG thank you very much, I will try that 😄
              I was trying something, but is a bit more complicated:
              idd = "dic1"
              hit = nil
              mod.definitions.each{|d|
                 next if d.image?
                    next if i.attribute_dictionaries.to_a.size<1
                    dictio = i.attribute_dictionaries.to_a
                    if dictio[0].name==idd
                       hit=i
                       break
                 break if hit
              • jolranJ
                jolran
                Hah 😄 , yes thats exactly just what I did.
                I ran into trouble deleting the newly created definition, with something like :
                gp=Sketchup.active_model.active_entities.add_instance(@su_gp.definition, ORIGIN)
                Also since @su_gp (in my case) could be either a group or component I had to put in some ifs and nots as well. With entities.parent for groups just like you described.
                Not a big deal to explode, performance-vise. Feels safer.
                Thanks for reasuring about the group unique thing. Not gonna use it this time though 😄 .
                BTW hope this issue was related to the topic.
                • Dan RathbunD
                  Dan Rathbun
                  @dacastror said:
                  ... suppose that I assign a different name to each dictionary of each entity and I want to find the entity using the name of the dictionary. How can I modify the condition
                  (google translator)
                  if i.attribute_dictionary(idd)
                  or
                  unless i.attribute_dictionary(idd).nil?
                  I'm not here much anymore.
                  • Dan RathbunD
                    Dan Rathbun
                    you can simply do:
                    def find_inst_by_dict_name(dname)
                      found = nil
                      for d in definitions
                         next if d.image?
                         found = d.instances.find{|i|
                           i.attribute_dictionary(dname)
                         break if found
                      end # for
                      return found
                    end # def
                      You/we are starting to conflate the searching for an object that has a named attribute-dictionary attached to it [and which is uniquely named for one object, and is irrespective of any key/value pairs], and then the original code snippets which were about assigning, and then checking for, the 'value' of a specific 'key' in a named attribute-dictionary [where the key and dictionary are commonly named across several objects, and only vary by the key's 'value'].
                      I suggest you step back and decide what it is you are trying to do and how you do it best...
                        dacastror
                        Thanks Dan, I find it very nice your suggestion, I will give a chance to this
                        Thanks for replying TIG, I really needed to know the two things, I was lost without your help
                        (google translator)
                          dacastror
                          I did this and I get "error", I couldn't see what is wrong
                          mod = Sketchup.active_model
                          definitions = mod.definitions.to_a
                          def find_entity(dname)
                            found = nil
                               next if d.image?
                               break if found
                            end # for
                            return found
                          end # def
                          entity = find_entity("dic1")
                          • sdmitchS
                            sdmitch
                            you need to move the
                            statements inside the def since they are not module variables starting with "@".
                            http://sdmitch.blogspot.com/
                            • Dan RathbunD
                              Dan Rathbun
                              I CAN 😳 It is a stupid mistake on my part.
                              def self.find_entity(dname)
                                found = nil
                                for d in Sketchup.active_model.definitions
                                   next if d.image?
                                   break if found
                                end # for
                                return found
                              end # def
                              • Dan RathbunD
                                Dan Rathbun
                                Assume you have a "DiegoCastro" folder:
                                And in it a "Lib.rb" file for your library methods:
                                module DiegoCastro
                                  module Lib
                                    def find_entity(model,dname)
                                      found = nil
                                      for d in model.definitions
                                        next if d.image?
                                        break if found
                                      end # for
                                      return found
                                    end # def
                                  end # Lib sub-module
                                end # Author toplevel namespace module
                                Then in SomePlugin you do this... (name it whatever.. "diegotest.rb" etc.)
                                module DiegoCastro
                                  module SomePlugin # <--<< change plugin sub-module name as needed
                                    class << self # proxy class
                                      require('DiegoCastro/Lib')
                                      include(DiegoCastro;;Lib)
                                      def find_inst_by_dict_name()
                                        if @last_dict.nil?
                                          @last_dict = "dynamic_attributes" # initial value
                                        dname = UI.inputbox(['Dictionary Name........; '], [@last_dict], "Find by Dicto Name")
                                        if dname # user did not cancel the inputbox
                                          unless dname.empty? || dname[0].length==0
                                            @last_dict = dname[0]
                                            entity = find_entity(Sketchup.active_model,dname[0])
                                            if entity
                                              UI.messagebox("Found #{entity.inspect}     \nwith dictionary name '#{@last_dict}'     ")
                                              return entity
                                            else # nothing was found because find returned nil
                                              UI.messagebox("No entity found with     \n dictionary name '#{@last_dict}'     ")
                                        return nil
                                    end # proxy class
                                    unless file_loaded?(File.basename(__FILE__))
                                      # create menus here;
                                      @@submenu = UI.menu('Plugins').add_submenu('Diego')
                                      @@submenu.add_item('Find entity by Dicto Name') {
                                      file_loaded(File.basename(__FILE__))
                                  end # plugin sub-module
                                end # Auhtor module
                                  dacastror
                                  wow thanks Dan, I will take some time to study this code, worth but me several questions arise, I will try to solve the most I can on my own, thank you very much 😄
                                  (google translator)
