    [Plugin] Selection Toys
    594 Posts 121 Posters 381.1k Views 121 Watching
      @dan rathbun said:
      (3) Try to limit any characters in directory names to the UTF-8 character set. (Simple ASCII characters are even better.)
      Limit? What characters are not covered by Unicode?
        @dan rathbun said:
        Always get help from the plugin author first, rather than attempting "shot in the dark" solutions.
        Isn't that what has been done here..? I think you've jumped the gun on a few things here.
        • Dan RathbunD Offline
          Dan Rathbun
          Sorry.. I will bow out of this. 😳
          I'm not here much anymore.
            @caronte01 said:
            My bad... didn't read the list of requirements at first. But, now it is asking for win32api. In installed it in the main plugin folder, and no go.... Does this plugin work on macos?
            Would you by any chance happen to have Organizer installed? That could explain why these files are being loaded.
            Selection Toys uses only a very tiny subset of TT_Lib - the rest of TT_Lib isn't even loaded. the .so file should be inert as there is no other plugin using TT_Lib and certainly not the functionality of the .so.
            Organizer does do some weird things such as load going into subfolders and load the files there, which causes problems as files might be loaded in the wrong order.
            But I still don't get why the .so and registry files are being loaded as the code calling it is wrapped in guards that should prevent them from loaded directly. So it almost seems that something is bypassing this is loading the files directly.
            I'm not quite sure how Fredo's Additional Folders plugin work though - which you appear to be using.
              No worries. Enjoy the jolly times ahead! πŸ˜„
                caronte01
                Hi all.
                Yes, I use dropbox to sync my plugins folder between 2 computers, 1 windows pc that I use at work, and a macbook that I have at home. I've had no issues with this system so far. Almost all plugins work ok, the few that don't, I install locally.
                I had compatibility problems between podium 2 and 000_AdditionalPluginFolders, but uninstalled podium and everything went back to normal.
                No, I don't have organizer installed.
                  caronte01
                  BTW, Happy holidays!
                    Can you try, just for the sake of it an place Selection Toys and TT_Lib into the actual plugins folder and see if that avoids the errors. Then we'd know if it works without Additional Folders handling this.
                      caronte01
                      Hi ThomThom.
                      Test 1: Moved TT_Lib and selection toys to the native plugin folder, left everything else untouched. Got this error:
                      Test 1
                      Test 2: Moved TT_Lib and selection toys to the native plugin folder, removed 000_AdditionalPluginFolders. Selection toys loaded correctly.
                      Test 2
                      Test 3: TT_lib, selection toys and 000_AdditionalPluginFolders in the native plugins folder, dropbox folder left empty. Got this error:
                      Test 3
                      Test 4: Just in case, 000_AdditionalPluginFolders in the native directory, TTlib and selection toys in my dropbox plugin folder Error:
                      Test 4
                      So it is some kind of incompatibility with this two plugins?
                        Hmm... need to check with Fredo on this.
                          In a case like that, you might be better off deleting all of the layers and putting everything back on Layer 0. Then start over with making layer associations.
                          • gonashviliG Offline
                            gonashvili
                            Is there a way to select everything within a particular layer?
                            I've got big mess, components within components with each of them on various layers and I'd like to clean up, reduce the number of layers. It would help to 'see' whats on a particular layer....
                            I mean when I try to remove a layer thinking its empty, the dialog appears [wants to move the contents] and often times I have no idea where to look for them as unclicking the 'Visible' box in the Layers dialog might make it seem like its empty/there's no change, visually...
                            Cheers
                              gonashvili
                              Guess you're right, such a feature would rule though, I think
                                "Select all on Selected Layer" - That means the layer the selected entity is on.
                                  Version 2.2.2
                                  • Added Select Active with Materials
                                  • Removed dependency from TT_Lib
                                  • Repackaged as RBZ
                                  • cottyC Offline
                                    cotty
                                    Thank you for the update.
                                    (I will not ask how to install it πŸ˜‰ )
                                    my SketchUp gallery
                                      caronte01
                                      Hi Thomas,
                                      Installed the new version. It now works, no conflicts or errors!
                                      Thanks a lot!
                                      Santiago
                                        Mra
                                        Thanks for the amazing plugin. I was wondering if for future that some extra things could be implemented although I ponder if this is impossible with SketchUp.
                                        Basically Maya has some sweet tools in this regard;
                                        Select an edge ring
                                        Select a path of edges between two edges
                                        Maya User's Guide
                                        (download.autodesk.com)
                                        Just an idea.
                                          driven
                                          like TT other plugin?
                                          [web 100%,600:uxxl934f]http://www.thomthom.net/software/vertex_tools/[/web:uxxl934f]
                                            Select an edge ring
                                            Maya User's Guide
                                            Just an idea.
                                            Check out QuadFace Tools: http://extensions.sketchup.com/en/content/quadface-tools
                                            It doesn't have Select path between two edges yes, but it's on the todo list.
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 29
                                            • 30
                                            • 24 / 30
