    Helix / Spiral With Increasing Pitch
    14 Posts 6 Posters 2.0k Views 6 Watching
    • gillesG Offline
      gilles
      You could try Sketchy FFD.
      404 Not Found
      (sketchucation.com)
      Could you post a pic of what you want?
        dkw1118
        Thanks guys for the replies. I am looking into the suggestions.
        The models will be used to represent extrusion screws but the models will be redrawn in autocad for actual manufacturing. If I can more or less get a good visualization with most of the dimensioning in Sketchup the next stage can be handled by a design engineer. These models I guess are more or less field drawings but I'd like them to be a good representation. I usually do some in 3d iso and then turn some into parallel projection. I've attached 2 pics of the actual parts ... though not the best quality, and a drawing to some the idea of the incremental flite lead / pitch.
        Keith
          Maybe like this with some variations?
            dkw1118
            A good youtube presentation and tutorial.
            Though ... my main question I guess is creating a secondary flute that as it turns and progresses along the screw shaft it smoothly increases pitch or lead. An example might be it increasing 0.150" with each turn ... but doing it in a manner that has no noticeable stop/start points during the pitch increments.
            I am going to play around with all the suggestions I've received.
            I was wondering if someone has had to do this incremental pitch several times and
            had settled on a way to accomplish it.
              One turn helix was made with Draw Helix 14 by Jim
              Maybe something like this 😄
              Does this sufficient, not enough progressive? Too discrete ?
              Maybe you can see also Grow by Tig from just one inclined segment! 💭
              curves.skp
              • jeff hammondJ Offline
                maybe overthinking it some..
                those parts look like they're made using two standard helixes and not a spiral whose pitch increases as you go around (i.e.- the things the fellas are drawing in this thread)
                for this pic, i drew a helix then copy/moved it vertically... selected the second helix and scaled it vertically.. [then skinned it using curviloft]
                  After seeing your drawing, Keith, I would agree with Jeff. I think he's hit the nail on the head.
                    dkw1118
                    I guess looks can be deceiving.
                    Here's how it goes:
                    (1) The primary flite has a lead of 1.75" for a distance of 12.25" then transitions in to a 2.5" lead within a 2.875" span.
                    (2) The primary flite lead remains constant again at 2.5" for a length of 16.25" within what is called a barrier section.
                    (3) The secondary (thinner flite) begins in the barrier section and it's lead is increasing by 0.150" per turn. It ends at the the end of the barrier section just before it "catches up" with the primary flite.
                    (4) The primary flite then transistions back to a 1.75" lead for 13.5".
                    This is pretty normal for extruder screws with barrier sections. This particular screw is small in diameter at only 45mm. Most range between 3.5" to 6" o.d., 8" not uncommon, and up to 15"+. There are many variations on these barrier sections but this probably should give you the basic idea.
                    Keith
                    • mitcorbM Offline
                      mitcorb
                      In any case, it would be in your best interest to model this scaled up, because those incremental distances are very small and could create closure problems on surfaces.
                        dkw1118
                        Thanks all for your comments. Hopefully in a couple of days I'll get a chance to dedicate more time to your suggestions.
                        Keith
                          Here's how it goes:
                          Keith
                          hey Keith,
                          i don't know if those dimensions came from the pics you posted but if these screws do in fact have a variable pitch, i'm sure a ruby could be made to accommodate the shape..
                          i don't know ruby so i messed around with a dynamic component.. the problem is, DCs are very limited so i was only able to get the varying helix with guide points..
                          as the attached dc is now, there is no input for start and end pitch.. it's basically wrapping a 1/4 circle around a 36 segment cylinder (i.e.- going from 0º start pitch to 90º end pitch)..
                          you'd then have to connect the dots manually (or maybe use a ruby?) to get the actual lines in there..
                          if you think it'd be helpful, i could mess around with it some more to get start/end pitch functionality..
                          here's the .skp:
                          there's a guide point at the origin.. select it then open the component options window for entry fields
                            And why not draw some remarquable points following the helix path (each quarter), thean draw a bezier spline (FSpline) from Fredo6 with numerous points on the spline on theses quarters?
                            Like this you will have a soft transition between each changment of pitch!
