    Flatten Plane / Match plane
    30 Posts 4 Posters 1.6k Views 4 Watching
      stevo7122
      Makes sense. I typically use 3ds Max and it has a planar tool that operates very close to how I want my flatten plugin (It will also disturb any faces that are attached to the surrounding edges and re-orient the face...). Flattening two faces to the same or average plane does come at a price I.E. "disturbing" the surrounding edges and anything attached. Fortunately for me In my situation their isn't a lot of surrounding faces to deal with. Basically I just want to click on two faces and click the flatten tool to bring the second face on to the same plane as the first (Making the two faces coplanar)so I can remove the edge that joins the two. If I had the ultimate wish list I would have a plugin that would allow me to select the bounding edges of an area and flatten any edges contained with in that area thus leaving the surrounding edges undisturbed...I will try both your methods and see if I can't get something working.
        How would that work? Leaving the border edges intact while keeping everything on the inside plane? To what plane?
        Got sample model or screenshot?
          stevo7122
          It would be some what difficult to achieve however the idea would be to use the first edge or triangle clicked to create a refrence plane to match all the selected faces to.
            What are you trying to make with this? Sample model or screenshot would help.
              stevo7122
              Actually the mesh optimizer is what I was wanting to have the ability to preserve the selected edges and remove the interior edges. Which vertex tools are you referring to? Are those available as a plugin? Also how are you storing face1 and face2 in your example. The one thing I can't figure out is how to refrence the selected face. I know you can set selection = sketchup.active_model.selection but how do you get the currently sellected face from that? I know how to test to see what is selected by checking the entity.typename == "face" but how do I store the selected face in a a variable I.E. face1 = currently selected face...
              Thanks,
                stevo7122
                Found your vertex tools thomthom I might have to give those a try this weekend. Sketchup is definately lacking in the vertex department and those tools look really awesome. Tig in your example would I replace the n0=Z_AXIS.clone with the plane of the second face? If so How do I get the second face from the selected model?
                Thanks,
                  So you are in fact flattening the outer edges? When you say preserve you just want to not erase it - but you can modify it so everything becomes planar?
                  It's really help if you posted some visual examples.
                  301 Moved Permanently
                  (www.thomthom.net)
                  # Assuming only one face is selected;
                  sel = Sketchup.active_model.selection
                  face1 = sel[0]
                  # Assuming only two faces are selected;
                  face1, face2 = sel.to_a
                  Sketchup.active_model.selection is an Enumerable object.
                  Sketchup.active_model.selection.to_a will give you an Array.
                  I take it you are quite new to scripting? Are you familiar with Enumerable and Array?
                  #typename is horribly slow. Use #is_a? instead. Have a look at this article for more info: http://www.thomthom.net/thoughts/2011/12/never-ever-use-typename/
                    stevo7122
                    I think I figured it out. I actually needed to set n0=selection[1].normal I.E. the normal of the other plane...One last quick question is their a way to remove the conjoined edge between the two triangles after I make them coplanar? Im sure in the api you can find the conjoined edge is their a delete function that you would perform?Thank you both for all of your help.
                      After you are sure they are now coplanar... and ignoring that they might have different materials etc... try something like...
                      es0=face0.edges; face1.edges.each{|e|e.erase! if e.valid? && es0.include?(e)}
                        stevo7122
                        thomthom I just purchased your vertex tools and will give them a try. I do have one last issue. It seems that no matter which order I select to flatten the two triangles it always flattens to the plane of the same triangle. What i'm wanting is to flatten to the plane of the first selected triangle depending on which order I select. Using Tig's code below I removed the z axis and set it equal to the normal of the first plane:
                        ` #Set m = to the active Model
                        m=Sketchup.active_model;
                        m.start_operation('f');
                        #Get the first plane and store it in f
                        f=m.selection[0];
                        #n0=Z_AXIS.clone;
                        #Get the normal of the second plane and store it in n0
                        n0=m.selection[1].normal;
                        #set n1 = to the first planes normal.
                        n1=f.normal;
                        #Set c equal to the cross vector of the first plane.
                        c=n0.cross(n1);
                        set a equal to the angle between the first and second faces.
                        a=n0.angle_between(n1);
                        t=Geom::Transformation.rotation(f.vertices[0].position,c,-a);
                        m.active_entities.transform_entities(t,f);
                        m.commit_operation`
                          stevo7122
                          Shouldn't this work given that f is equal to the first plane selected or am i not understanding something?
                            You've swapped the faces' normals over.
                            Redo the code more logically
                            f0=selection[0] f1=selection[1] n0=f0.normal n1=f1.normal
                            etc
                            The cross, angle, transformation etc should then go smoothly...
                            Then you won't get so confused.
                            Incidentally, the selected objects are 'faces' NOT 'planes'...
                            You can only have 2 faces selected, for this to be foolproof...
                              stevo7122
                              I think my issue is i'm not actually capturing the first triangle being clicked anywhere I'm just enumerating the selected model and incidently just reversing the code. I think I need to some how determine which triangle was clicked first I.E. f0 or f1 and then adjust accordingly.
                                stevo7122
                                Technicallly the first face clicked should be f0=m.selection[0] If I were to select two faces...correct?
                                  **selection=Sketchup.active_model.selection** f0=selection[0] f1=selection[1] n0=f0.normal n1=f1.normal
                                  etc etc
                                  With selections, arrays etc the first element is index 0, second index 1 etc...
                                  So when you select two faces.
                                  The selection has two elements - [0] and [1]
                                  These are the faces referred to as f0 and f1 above...
                                  From these we get their 'normals' [vectors - drawn perpendicular from their 'planes'] - n0 and n1...
                                  That's also why you can't Select any other things and hope this'll work, as there's no code in there [at the moment] to 'extract' the just the two faces from everything else that you might have selected... but then that's the subject for a separate thread... πŸ˜‰
                                    stevo7122
                                    Right. However in the array will the first position = the first item clicked? For example if I select one face the first array position[0] should contain that face. And in another instance if i click on the first face then the second face will the position[0] still be the first face I clicked on or will the second face be in that position as it changes how the model is enumerated? For some reason when I use the code no matter which face I click on it always flattens the same face regardless of the first face clicked. Currently as it stands if I click the first face and then the second face it will always flatten the first face to the second face....Basically to test the code I will select 1 face then select the next face and it will flatten. However If I perform an undo to reset the faces to the original position and select a different face as the first one it will still flatten the same face regardless of which order I clicked on.
                                    ` f0=m.selection[0]; #first face selected
                                    f1=m.selection[1]; #second face selected
                                    n0=f0.normal; #first plane normal
                                    n1=f1.normal; #second plane normal
                                    c=n0.cross(n1);
                                    t=Geom::Transformation.rotation(f0.vertices[0].position,c,-a);
                                    m.active_entities.transform_entities(t,f1);
                                    m.commit_operation;`
                                      stevo7122
                                      As an edit I just realized I think my comments should be #first face normal and #second face normal not #first plane normal etc...
                                        stevo7122
                                        I have been doing some debugging of sorts and if you do a puts f0.normal and a puts f1.normal then select face1 then face2 (look at the two values and the order they are outputted) then perform an undo and select face2 then face1 it produces the same values in the same order. Shouldn't the order be reversed if I clicked on a different plane first in each instance?
                                          stevo7122
                                          Sorry I meant to say clicked on a different face first...For some reason I keep wanting to say plane..
                                            edge.erase!
