    Can you get a list of OSX fonts somehow?
    110 Posts 6 Posters 15.4k Views 6 Watching
      driven
      Found the problem, and a massive speed-up...
      > t=Time.now fontList=(/opt/X11/bin/fc-list : file family | grep /Library/Fonts).split("\n").collect { |f| f.split(":")[1] }.collect { |f| f.split(",")[0] }.to_a.uniq.compact.sort[5..-1] fin=Time.now-t puts fontList.length puts fin, Time.now-t puts fontList puts Time.now-t 296 0.049741 0.056441 *...print fonts* 1.440642
      however............ not everyone has X11
        driven
        But, the good news is brew install fontconfig will put it in 'usr/local/bin/fc-list' without all the X11 or hidden system fonts... speed on first run, slower, but still acceptable
        then, the penny dropped that you no longer need grep or one of the collects, so
        t=Time.now fontList=(/usr/local/bin/fc-list : family ).split("\n").collect { |f| f.split(",")[0] }.to_a.uniq.compact.sort fin=Time.now-t puts fontList.length puts fin, Time.now-t puts fontList puts fontList.length puts fin, Time.now-t 274 0.017442 0.023794 ...print fonts 1.363478
        not to shabby
          So you HAVE got fc-list to work after all! πŸ˜„
          Don't you need to include 'file' in the output as well as 'family' and grep for '.ttf' because 3dText needs a /ttf and the 'family only' way might also list .otf fonts etc too, which 3dText might baulk at ?
          Something more like:
          fontList=(/usr/local/bin/fc-list : file family | grep .ttf:).split("\n").collect{|f|f.split(": ")[1].split(",")[0]}.to_a.uniq.compact.sort
          I'm not sure how you deal with the ".ttf:" - it perhaps needs some \ escaping ??
          If the 'grep' inside the MAC OS side is slower than doing a 'next unless f=~/.ttf: /' on the Ruby side, then you can add it into the 'collect' block instead...
            You got data back from fc-list using SketchUp Ruby??? ... but using a full path, that's the only change?
              fontList=(/usr/local/bin/fc-list : family ) returned nothing on my machine.
                driven
                YES... using fontList=(**/opt/X11/bin/fc-list** : file family | grep \/Library\/Fonts), but just to avoid X11 fonts, otherwise, all types [.ttf, otf, ttc] returned, work in SU [tested last weekend], so /Library/Fonts filter is OK.
                it's the core dump size that slows things down
                IF YOU HAVE IT INSTALLED...
                > t=Time.now fontList=(/opt/X11/bin/fc-list : file family `)
                fin=Time.now-t
                puts fin
                138048
                0.055793
                nilBut,**%(#0040FF)[IF YOU HAVE IT INSTALLED...]** > t=Time.now
                fontList=(/usr/local/bin/fc-list : file family )
                fin=Time.now-t
                puts fin
                22832
                0.073191
                nil
                t=Time.now
                fin=Time.now-t
                puts fin
                5921
                0.016585
                nil`
                now I've realised the full path bit, there may be other ways without using fc-list...
                  You are using these paths:
                  That didn't work for me (10.5). But this worked:
                  /usr/X11/bin/fc-list
                  Are any of the paths working across OSX versions?
                    So, because I've had problems even getting the data I've ignored the fact that you've been also getting the filename and grepping out by path. What is the reason for this. So you only get fonts that works in SketchUp?
                      This worked on my machine:
                      <span class="syntaxdefault"><br />data&nbsp;</span><span class="syntaxkeyword">=&nbsp;(`</span><span class="syntaxstring">/usr/X11/bin/fc-list&nbsp;;&nbsp;file&nbsp;family&nbsp;|&nbsp;grep&nbsp;\/Library\/Fonts</span><span class="syntaxkeyword">`)<br /></span><span class="syntaxdefault">fonts&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">data</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">scan</span><span class="syntaxkeyword">(/[^;]+[;]\</span><span class="syntaxdefault">s</span><span class="syntaxkeyword">*(.*)/).</span><span class="syntaxdefault">flatten</span><span class="syntaxkeyword">!<br /></span><span class="syntaxdefault">fonts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">map</span><span class="syntaxkeyword">!&nbsp;{&nbsp;|</span><span class="syntaxdefault">string</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">string</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">split</span><span class="syntaxkeyword">(</span><span class="syntaxstring">','</span><span class="syntaxkeyword">)&nbsp;}.</span><span class="syntaxdefault">flatten</span><span class="syntaxkeyword">!&nbsp;</span><span class="syntaxcomment">#&nbsp;Some&nbsp;lines&nbsp;include&nbsp;multiple&nbsp;fonts.<br />&nbsp;</span><span class="syntaxdefault"></span>
                      Now it's just a matter of reliably finding the path on all the systems.
                        <span class="syntaxdefault"><br />def&nbsp;get_osx_fonts<br />&nbsp;&nbsp;fc_list_locations&nbsp;</span><span class="syntaxkeyword">=&nbsp;[<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxstring">'/opt/X11/bin/fc-list'</span><span class="syntaxkeyword">,<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxstring">'/usr/local/bin/fc-list'</span><span class="syntaxkeyword">,<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxstring">'/usr/X11/bin/fc-list'<br />&nbsp;&nbsp;</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;</span><span class="syntaxdefault">fc_list&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">fc_list_locations</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find&nbsp;</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">location</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">exist</span><span class="syntaxkeyword">?(&nbsp;</span><span class="syntaxdefault">location&nbsp;</span><span class="syntaxkeyword">)&nbsp;}<br />&nbsp;&nbsp;if&nbsp;</span><span class="syntaxdefault">fc_list</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">nil</span><span class="syntaxkeyword">?<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">'Warning;&nbsp;Could&nbsp;not&nbsp;find&nbsp;fc-list!'<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">return&nbsp;[]<br />&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;data&nbsp;</span><span class="syntaxkeyword">=&nbsp;(`</span><span class="syntaxstring">#{fc_list}&nbsp;;&nbsp;file&nbsp;family&nbsp;|&nbsp;grep&nbsp;\/Library\/Fonts</span><span class="syntaxkeyword">`)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">fonts&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">data</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">scan</span><span class="syntaxkeyword">(/[^;]+[;]\</span><span class="syntaxdefault">s</span><span class="syntaxkeyword">*(.*)/).</span><span class="syntaxdefault">flatten</span><span class="syntaxkeyword">!<br />&nbsp;&nbsp;</span><span class="syntaxdefault">fonts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">map</span><span class="syntaxkeyword">!&nbsp;{&nbsp;|</span><span class="syntaxdefault">string</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">string</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">split</span><span class="syntaxkeyword">(</span><span class="syntaxstring">','</span><span class="syntaxkeyword">)&nbsp;}.</span><span class="syntaxdefault">flatten</span><span class="syntaxkeyword">!&nbsp;</span><span class="syntaxcomment">#&nbsp;Some&nbsp;lines&nbsp;include&nbsp;multiple&nbsp;fonts.<br />&nbsp;&nbsp;</span><span class="syntaxdefault">fonts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">uniq</span><span class="syntaxkeyword">!<br />&nbsp;&nbsp;</span><span class="syntaxdefault">fonts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">sort</span><span class="syntaxkeyword">!&nbsp;</span><span class="syntaxcomment">#&nbsp;(!)&nbsp;Not&nbsp;UTF-8&nbsp;compatible!&nbsp;But&nbsp;better&nbsp;than&nbsp;nothing.<br />&nbsp;&nbsp;</span><span class="syntaxdefault">fonts<br />end<br /></span>
                          driven
                          hi TT,
                          I did PM before I saw this, I would split it into 3 conditional block
                          the first would use /usr/local/bin/fc-list
                          if you revisit http://sketchucation.com/forums/viewtopic.php?f=180&t=48761&p=443899#p441686 you'll see that you don't need to grep /usr/local/bin/fc-list, because it avoids the system and X11 fonts already.
                          second choose last in find /**/bin/fc-list array, for the latest X11 version
                          third default to 'FontBook' it's on every mac....
                            Isn't fc-list on every mac?
                              driven
                              TT... don't you read PM's or the posts... [I am laughing]
                              reminds me of when you answer some of your 'clients'
                              The whole reason I went round in circles is fc=list has never been 'standard' on a mac.
                              a lot of people use to have xcode and it came with that as part of fontconfig for X11,
                              or if you have Wings3D, Gimp, Inkscape or Imagemagics you'd have it, so a few SU'ers will. but they all have FontBook it's a mac core app....
                                driven
                                TO RECAP
                                This is the fastest I can get a usable list from X11
                                if I remove .split[-2] from fontPath it uses /usr/local/bin and is twice as fast, same result... so the one could be used for any fc-list installed, without hardcoding a path.
                                 fontPath=(`find /*/*/bin/fc-list`).split[-2]
                                fontList=(`#{fontPath}  ; file family | grep \/Library\/Fonts`).split("\n").collect { |f| f.split(";")[1] }.collect { |f| f.split(",")[0].strip}.to_a.uniq.compact.sort[5..-5]
                                the .sort[5..-5] cleans out the dot files at top and some other cruft the the bottom...
                                EDIT: I missed a .strip that stop them running... leading whitespace.
                                on test a couple are getting through that shouldn't
                                *** macFonts group Error! *** i = 38 chunk = 4 font = Bitstream Charter Error #<TypeError: reference to deleted Group> Error: #<TypeError: (eval):282:inname=': reference to deleted Group>
                                (eval):299
                                (eval):282
                                (eval):274:in times' (eval):274
                                  I've become so confused on this whole topic. πŸ˜•
                                  fontPath=(find ///bin/fc-list).split[-2]
                                  That command was very slow on my mac.
                                  Can you be sure this is the same on all machines? I'm hesitant to use magic numbers.
                                  OSX is giving me headackes in regard to this plugin. I'm tempted to just drop it all together. Taking too much time.
                                  At the moment I'm looking at first attempting fc-list, if it's installed. (Might have to do a search - so I have to cache that.) Then fall back to AppleScript and FontBook - also slow so it also needs a cache list (meaning the list won't automatically keep in sync.)
                                  sigh
                                  And that's not including the crashing...
                                    driven
                                    TT, maybe you want to move this, but
                                    I was looking for a UFT8 font filter and came across a simple test code for checking console encoding.
                                    I thought Ruby Console was UFT8, but it's not?
                                    I made a little test script, and ran it both from console and from plugins.
                                    same result from both...
                                    >  msg = (`perl -Mcharnames=;full -CS -wle 'print "\N{EURO SIGN}"'`).to_s
                                     puts msg
                                     rply = (`locale`).to_s
                                     puts rply
                                     result = UI.messagebox msg, MB_YESNO
                                     if result == 6 # Yes
                                       UI.messagebox("Sketchup dosen't use UFT8, it uses \n" + rply)
                                    N{EURO SIGN}
                                    LANG=
                                    LC_COLLATE="C"
                                    LC_CTYPE="C"
                                    LC_MESSAGES="C"
                                    LC_MONETARY="C"
                                    LC_NUMERIC="C"
                                    LC_TIME="C"
                                    LC_ALL=
                                    for comparison Terminal.app results
                                    %(#008000)[johns_iMac at upstairs in ~
                                    $ locale
                                    LANG="en_US"
                                    LC_COLLATE="en_US.UTF-8"
                                    LC_CTYPE="en_US.UTF-8"
                                    LC_MESSAGES="en_US.UTF-8"
                                    LC_MONETARY="en_US.UTF-8"
                                    LC_NUMERIC="en_US.UTF-8"
                                    LC_TIME="en_US.UTF-8"
                                    LC_ALL="en_US.UTF-8"
                                    $ perl -Mcharnames=:full -CS -wle 'print "\N{EURO SIGN}"'
                                      It's UTF-8.
                                      Test example:
                                      'ΓΈ'.unpack('C*')
                                      Returns:
                                      [195, 184]
                                      Which is the correct byte values in UTF-8 encoding.
                                      195 indicate the Latin1 page 184 points to ΓΈ on that page.
                                      Don't know what the data you got from them commands where. But just by looking at the test data byte per byte you can tell it's UTF-8.
                                        driven
                                        yes that does return correctly,
                                        which is why I can't understand why some thing get lost in transition...
                                        same font Stix(NON-Unicde)
                                        Top happens from Ruby Console as well as WebDialogs
                                        Bellow is the Built in Tool
                                          hm... I've not have any problems with it.
                                          Do you see this in the 3d text plugin I sent you?
                                            driven
                                            Top one... I was being discrete
                                            ` > a = "2ζ’–μ£Ί".unpack('C*')
                                            b = a.pack('C*')
                                            c = puts a.inspect
                                            puts b.inspect
                                            [50, 230, 146, 150, 236, 163, 186]
                                            "2ζ’–μ£Ί"
                                            nil`
                                            the puts should read [0, 50, 100, 150, 200, 250] "2ζ’–μ£Ί"
                                            • 6 / 6
