    Can you get a list of OSX fonts somehow?
    110 Posts 6 Posters 20.6k Views 6 Watching
      b=["(\n Momo\n)", "(\n Trek\n)", "(\n \"Machine Tool Gothic\"\n)", "(\n \"Machine Tool SanSerif\"\n)"] c=b.map { |f| f[/[("\s]+([^"\n]+)[)"\s]+/m,1] }
      Returns:
      ["Momo", "Trek", "Machine Tool Gothic", "Machine Tool SanSerif"]
        driven
        excellent Thomas,
        when I use it on /Library/Fonts/*.*tf I get a more complete list, but some are linked files so I get
        "could not find /Library/Fonts//儷宋."
        how do I filter those out? [if I can't resolve them]
          driven
          ###################################################################### t=Time.now a=(find -d /Library/Fonts -name "*.t").split("\n").map { |f| f.gsub(" ", "\\ ")} b=(a.collect{|x| mdls -nullMarker missing -raw -name com_apple_ats_name_family #{x}}) c=b.map { |f| f[/[("\s]+([^"\n]+)[)"\s]+/m,1] }.uniq puts c, "\n v2", Time.now-t ######################################################################
          187 fonts from 1 Library in 7.147912 and I still have a couple of commas to remove...
              driven
              `tt,
              that's your browser not recognising the UFT8 apple icon. IE sometimes will show the Windows icon.
              I use it as a line marker for mac only scripts I'm testing, so when I had 3 time now's I could find the end of each easily.
                I use Firefox.
                Firefox understands UTF-8. There's some conversion going on here that mangles the formatting.
                  driven
                  The Apple Logo in Unicode
                  (hea-www.harvard.edu)
                  This is probably fine for Mac-only applications. But it is NOT appropriate, and even WRONG, and it will NOT work properly as a general web page character. The problem is that the unicode value used is one of several that is set aside for private use. That means that each operating system, or application, or implementation is free to use those unicode characters for anything they want. It just so happens that Apple has chosen to use unicode character U+F8FF (decimal value 63743, or on the web as either  or ) as the Apple Logo. But some Windows fonts put in a Windows logo. And some other fonts put in a Klingon Mummification glyph. Or elven script. Or anything they want. And if it isn't defined in your local font, you'll just see a square. So who knows what you might see when I put the character in right here: 
                    Ah - a non-standard. That explains it.
                      driven
                      Found the problem, and a massive speed-up...
                      > t=Time.now fontList=(/opt/X11/bin/fc-list : file family | grep /Library/Fonts).split("\n").collect { |f| f.split(":")[1] }.collect { |f| f.split(",")[0] }.to_a.uniq.compact.sort[5..-1] fin=Time.now-t puts fontList.length puts fin, Time.now-t puts fontList puts Time.now-t 296 0.049741 0.056441 *...print fonts* 1.440642
                      however............ not everyone has X11
                        driven
                        But, the good news is brew install fontconfig will put it in 'usr/local/bin/fc-list' without all the X11 or hidden system fonts... speed on first run, slower, but still acceptable
                        then, the penny dropped that you no longer need grep or one of the collects, so
                        t=Time.now fontList=(/usr/local/bin/fc-list : family ).split("\n").collect { |f| f.split(",")[0] }.to_a.uniq.compact.sort fin=Time.now-t puts fontList.length puts fin, Time.now-t puts fontList puts fontList.length puts fin, Time.now-t 274 0.017442 0.023794 ...print fonts 1.363478
                        not to shabby
                          So you HAVE got fc-list to work after all! 😄
                          Don't you need to include 'file' in the output as well as 'family' and grep for '.ttf' because 3dText needs a /ttf and the 'family only' way might also list .otf fonts etc too, which 3dText might baulk at ?
                          Something more like:
                          fontList=(/usr/local/bin/fc-list : file family | grep .ttf:).split("\n").collect{|f|f.split(": ")[1].split(",")[0]}.to_a.uniq.compact.sort
                          I'm not sure how you deal with the ".ttf:" - it perhaps needs some \ escaping ??
                          If the 'grep' inside the MAC OS side is slower than doing a 'next unless f=~/.ttf: /' on the Ruby side, then you can add it into the 'collect' block instead...
                            You got data back from fc-list using SketchUp Ruby??? ... but using a full path, that's the only change?
                              fontList=(/usr/local/bin/fc-list : family ) returned nothing on my machine.
                                driven
                                YES... using fontList=(**/opt/X11/bin/fc-list** : file family | grep \/Library\/Fonts), but just to avoid X11 fonts, otherwise, all types [.ttf, otf, ttc] returned, work in SU [tested last weekend], so /Library/Fonts filter is OK.
                                it's the core dump size that slows things down
                                IF YOU HAVE IT INSTALLED...
                                > t=Time.now fontList=(/opt/X11/bin/fc-list : file family `)
                                fin=Time.now-t
                                puts fin
                                138048
                                0.055793
                                nilBut,**%(#0040FF)[IF YOU HAVE IT INSTALLED...]** > t=Time.now
                                fontList=(/usr/local/bin/fc-list : file family )
                                fin=Time.now-t
                                puts fin
                                22832
                                0.073191
                                nil
                                t=Time.now
                                fin=Time.now-t
                                puts fin
                                5921
                                0.016585
                                nil`
                                now I've realised the full path bit, there may be other ways without using fc-list...
                                  You are using these paths:
                                  That didn't work for me (10.5). But this worked:
                                  /usr/X11/bin/fc-list
                                  Are any of the paths working across OSX versions?
                                    So, because I've had problems even getting the data I've ignored the fact that you've been also getting the filename and grepping out by path. What is the reason for this. So you only get fonts that works in SketchUp?
                                      This worked on my machine:
                                      <span class="syntaxdefault"><br />data&nbsp;</span><span class="syntaxkeyword">=&nbsp;(`</span><span class="syntaxstring">/usr/X11/bin/fc-list&nbsp;;&nbsp;file&nbsp;family&nbsp;|&nbsp;grep&nbsp;\/Library\/Fonts</span><span class="syntaxkeyword">`)<br /></span><span class="syntaxdefault">fonts&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">data</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">scan</span><span class="syntaxkeyword">(/[^;]+[;]\</span><span class="syntaxdefault">s</span><span class="syntaxkeyword">*(.*)/).</span><span class="syntaxdefault">flatten</span><span class="syntaxkeyword">!<br /></span><span class="syntaxdefault">fonts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">map</span><span class="syntaxkeyword">!&nbsp;{&nbsp;|</span><span class="syntaxdefault">string</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">string</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">split</span><span class="syntaxkeyword">(</span><span class="syntaxstring">','</span><span class="syntaxkeyword">)&nbsp;}.</span><span class="syntaxdefault">flatten</span><span class="syntaxkeyword">!&nbsp;</span><span class="syntaxcomment">#&nbsp;Some&nbsp;lines&nbsp;include&nbsp;multiple&nbsp;fonts.<br />&nbsp;</span><span class="syntaxdefault"></span>
                                      Now it's just a matter of reliably finding the path on all the systems.
                                        <span class="syntaxdefault"><br />def&nbsp;get_osx_fonts<br />&nbsp;&nbsp;fc_list_locations&nbsp;</span><span class="syntaxkeyword">=&nbsp;[<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxstring">'/opt/X11/bin/fc-list'</span><span class="syntaxkeyword">,<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxstring">'/usr/local/bin/fc-list'</span><span class="syntaxkeyword">,<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxstring">'/usr/X11/bin/fc-list'<br />&nbsp;&nbsp;</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;</span><span class="syntaxdefault">fc_list&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">fc_list_locations</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find&nbsp;</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">location</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">exist</span><span class="syntaxkeyword">?(&nbsp;</span><span class="syntaxdefault">location&nbsp;</span><span class="syntaxkeyword">)&nbsp;}<br />&nbsp;&nbsp;if&nbsp;</span><span class="syntaxdefault">fc_list</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">nil</span><span class="syntaxkeyword">?<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">'Warning;&nbsp;Could&nbsp;not&nbsp;find&nbsp;fc-list!'<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">return&nbsp;[]<br />&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;data&nbsp;</span><span class="syntaxkeyword">=&nbsp;(`</span><span class="syntaxstring">#{fc_list}&nbsp;;&nbsp;file&nbsp;family&nbsp;|&nbsp;grep&nbsp;\/Library\/Fonts</span><span class="syntaxkeyword">`)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">fonts&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">data</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">scan</span><span class="syntaxkeyword">(/[^;]+[;]\</span><span class="syntaxdefault">s</span><span class="syntaxkeyword">*(.*)/).</span><span class="syntaxdefault">flatten</span><span class="syntaxkeyword">!<br />&nbsp;&nbsp;</span><span class="syntaxdefault">fonts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">map</span><span class="syntaxkeyword">!&nbsp;{&nbsp;|</span><span class="syntaxdefault">string</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">string</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">split</span><span class="syntaxkeyword">(</span><span class="syntaxstring">','</span><span class="syntaxkeyword">)&nbsp;}.</span><span class="syntaxdefault">flatten</span><span class="syntaxkeyword">!&nbsp;</span><span class="syntaxcomment">#&nbsp;Some&nbsp;lines&nbsp;include&nbsp;multiple&nbsp;fonts.<br />&nbsp;&nbsp;</span><span class="syntaxdefault">fonts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">uniq</span><span class="syntaxkeyword">!<br />&nbsp;&nbsp;</span><span class="syntaxdefault">fonts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">sort</span><span class="syntaxkeyword">!&nbsp;</span><span class="syntaxcomment">#&nbsp;(!)&nbsp;Not&nbsp;UTF-8&nbsp;compatible!&nbsp;But&nbsp;better&nbsp;than&nbsp;nothing.<br />&nbsp;&nbsp;</span><span class="syntaxdefault">fonts<br />end<br /></span>
                                          driven
                                          hi TT,
                                          I did PM before I saw this, I would split it into 3 conditional block
                                          the first would use /usr/local/bin/fc-list
                                          if you revisit http://sketchucation.com/forums/viewtopic.php?f=180&t=48761&p=443899#p441686 you'll see that you don't need to grep /usr/local/bin/fc-list, because it avoids the system and X11 fonts already.
                                          second choose last in find /**/bin/fc-list array, for the latest X11 version
                                          third default to 'FontBook' it's on every mac....
                                            Isn't fc-list on every mac?
                                            • 4 / 6
